Everything is at stock speeds and settings right now in the BIOS. Yet, instead of only clocking up to 3.5ghz, which is the default turbo speed when all cores are under load, it goes to 3.8ghz when ALL cores are loaded.
That isn't right, am I correct? Both my previous 2600k didn't do this, yet, I don't know what to do because everything is left at STOCK settings in the BIOS.
The normal Turbo speed for the 2600k when the 4 cores and 8 threads are under load is 3.5ghz. 3.8ghz is the Turbo speed for single threaded load, correct? Then something is wrong with mine.
What gives?
