Hello Guys, some time ago a friend here at Xs suggested to make a new table starting from his little renders and ideas, that idea basicly was to take a normal Easy Table and make it littler, more efficent and removing the watercooling addons, that table in the end like suggested is not related to wc stuff but more related to offices/labs/reviewers and all people that does not need wc but a compact, easy to assemble and to use platform...
down here you can see the pics of the render done from Friend here at XS ( i promised him the first sample...and this will be done, once first arrive )
that was the earlier render to Suggest the way to go...and from this we go to another end...i will resume some specs and final pics will be ready very soon...
-supporting 2 x 5,25" drive 3 x 3,5" drive (optional one more) 1 ssd or 1 hd 3,5" in "On The Fly" use
-motherboards up to 4 way sli
-psu up to 220 mm long
-rear cpu hole
-light weight
-6 custom powder coating color
-no need the Use of Hand Tool...all parts and screws have knurl
-25mm High Spacers for High Air circulation under Motherboards
-1 FlexFan 120 V2.0 included
-noise dumping antivibration mounting
-EasyGo Fastener for the Motherboard ( check here for more specs: http://www.xtremesystems.org/forums/...syGo-Fasteners)
- and many other features that i'm sure first reviewers will discover...
more to come in next 1-2 weeks...
