Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: GIGABYTE X79-UD7 Review W/ 3960X
    I am Xtreme
    Dec 2004
    France
    Welcome, its a bit after NDA, and if you've decided on Sandy Bridge-E as your next platform, or your just interested in the new boards, today I have a good bit in store for you.
    X79-OC... OOPS I meant UD7 Review.
    To introduce the X79 platform, we must start with the CPU, for starters Intel will be launching their 3960X and 3930K, the 3 in the first digit is for 3rd Generation Core i7 Processor, so the 3960 is like a 960, compare it to Bloomfield, with 960 and 930, so these processors will have predecessors. So let's start with the CPU, on die we have a PCI-E controller much like Sandy Bridge, but with 40 PCI-E 3.0 lanes. 6-Cores along with cache and a system agent with an IMC. The IMC is quad channel, but also supports dual or triple channel. So as long as you put more than 1 stick of memory in there, it will optimize the memory channels. You can even mix two different sets of memory, and set their timings and voltages independently.
    This platform is really feature packed, and it seems like most board makers are bringing out their A game, so let's see what GIGABYTE has to offer for X79. Can they produce another X58A-OC or even something better?
    1. Box + Acessories
    2. Board and Layout
    3. Digital PWM with a new VRM
    4. A Closer Look at the ICs
    5. BIOS
    6. Included Software
    7. Test Setup and the Board in Action
    8. Benchmarks
    9. Conclusion
    Box + Accessories:
    Nice white box, like an Apple product, personally I don't like Apple, but GIGABYTE did a nice job with the packaging.
    Now if you're thinking, "That is a lot of accessories" you and I would be thinking the same thing.
    Here is a close up of the Wifi/BT module:
    The board:
    The backpanel:
    That two color button is for the BIOS switch, you can select whether you want to use the main or backup BIOS, also the small black button is for ClearCMOS.
    Board and Layout
    Yea the socket is really huge, but you can also see that the DIMMs are close as well, this is to reduce trace length. That is why we see DIMMs on either side of the board. On boards with more than 4 DIMMs its recommended to OC with the first 2 on either side.
    You can also see that the socket has holes built into its bracket, these are standard sized, so you can screw things down into them. I was able to get my Antec Kuhler 920 and Hyper 212+ to fit without issue, I haven't tried other heatsinks, but most should fit.
    Now here is something I found out when I took off the bracket, you can actually puncture a piece of plastic and make a through-hole:
    Here is the bottom half:
    Now you can see that there is good spacing between the bottom of the memory slots and top of the first PCI-E 16x slot, this allows for overclockers to insulate the GPUs easily, and leave room for the memory, and changing memory out. It does also make this board ATX-XL, but as i am told not the full XL length.
    A lot of you are wondering about the area with the buttons:
    OK so we have a whole OC area over here, infact other than the backpanel with the ClearCMOS, and the dualBIOS switch, you can just handle everything from right here. We have two sets of +/- buttons, the ones to the left are for the multiplier and the ones on the right are for BLCK. The "Gear" button allows for the BLCK steps to be changed from 1mhz to 0.1mhz. We also have a Port80H LED POST Code display with codes in the back of the manual. Power and reset buttons are located here as are the voltage read points. Some connectors for the voltage read points are included, enough for every connector to be read at the same time. Also note that there are pads if you only have one DMM. You can also see a USB 3.0 connector, located north of the PCH to be closer to a USB 3.0 front panel bay, like the one included. That SATA power receptacle is for extra PCI-E power, and there is one more too a bit south.
    Moving down south we have a lot of SATA connectors, but you see 4 missing, those were SAS ports for SATA6G, and Intel removed it from the PCH before launch.
    The four gray are Marvell SATA6G, the 4 black are Intel SATA3G, and the 2 white are Intel SATA6G. You can also see a nice PCH heatsink, it actually says GIGABYTE OC on there, so maybe it really is an X79-OC?
    Located right above the front panel connectors is a 2-pin ClearCMOS jumper, just short these two pins out and accomplish what the backpanel button does without having to actually reach back there.
    We see some good spacing between slots here, but what is most odd is lack of PCI slots. As they are not native to the PCH X79, and haven't been for a while, manufacturers have to add PCI on there own if they want. A lot of users actually welcome to move to make PCI obsolete, personally I don't mind having PCI.
    Ok now we take that heatsink off!
    Here are the heatsinks:
    Digital PWM and the new VRM:
    So GIGABYTE switched to Digital, so what does that mean? It means that the Intersil Analog VRD 12 PWM has been changed to an International Rectifier Digital VRD12 PWM. Well the move to digital has two very big differences, first of all Digital PWMs offer much more control over every aspect of the voltage regulator, from the phase control to the LLC, the PWM even has built in NVM to store profiles. Settings can be changed real-time through software, and updated through the BIOS as well. Now this is the new 8-Phase IR PWM:
    IRF3567
    The second big difference is that the error feedback loop is digitalized, and this means much higher precision.
    Its 8 phases is 6+2, on this board all its 8 phases are used for just the CPU cores, but on the Assassin 2 its 4 phases for CPU cores and 1 of those +2 phases for the QPI/VTT VR. For comparison, the 8-Phase Chil PWM used on the Maximus 4 Extreme was 7+1 phases, on the Extreme all phases were used for the CPU Cores, but on the Gene the extra 1 phase was used for the iGPU, and 4 phases for the CPU Cores. There is a lot in common between ASUS and GIGABYTE PWMs right now, as International Rectifier bought Chil Semiconductor recently, and has since been putting out Digital PWMs with Chil technology, basically the same product under a different name. So now we have to look to the Rampage 4 Extreme and look to see what its VRM looks like without a heatsink, as the PWMs are basically the same.
    Anyways GIGABYTE is using all digital 16+2+2+2+2 phases for the CPU Core+QPI/VTT+System Agent(IMC)+DDRA/B+DDRC/D
    A lot of power. All of it Digital. GIGABYTE has employed two other 3+2 phase Digital PWMs.
    IRF3570
    GIGABYTE has switched away from DrMOS, as the doubling technology from Chil and IR consists of a solution that has integrated drivers on the doubler IC, this allows for better control of phase dropping while doubling as well as better monitoring. In theory at least. Here is how it works:
    Each doubler has two drivers built in, so its 3 chips in one, a doubler and two drivers, single PWM input and double driver output.
    GIGABYTE has also switched away from their older Low RDS(ON) MOSFETs, and has switched to much higher rated IR MOSFETs,
    IRFH8318for the low-side and IRFH8330 for the high-side.
    Now GIGABYTE is also using the POSCaps we saw on the X58A-OC, in the same amount as well, we have 19 of them at 470uF, the rest are on the back with the rest of the MOSFETs. POSCAP isn't just any normal tantalum capacitor, they are a brand name tantalum made by Panasonic, and they are supposed to have lower ESR and handle temperatures better than typical tantalum capacitors.
    All in all a very well redone VRM, with Digital PWM and very nice component selection:
    A closer look at the ICs:
    Its not really an IC, but these dual connectors definitely can carry in some power.
    Now this is the VR for the first memory slots:
    The chip with the white dot is another IRF3750 3+2 phase PWM, really only 2+1 are being used, 2 for the two memory phases and the +1 for the QPI/VTT phases. the +1 is doubled by the same doublers as are used for the CPU VRM, and the 2 directly goto some new DrMOS type power stages. These are IRs pride and joy power stages, they are DrMOS direct competitors, these in particular offer 40A consistently at 400khz and with pretty high efficiency. IRF3553 40A power stages. These are also used for the other two memory slots and for the 2 System Agent phases. Each memory slot can get 40A a pop, that is a TON of power for a single stick of memory, almost impossible to pull half of that per DIMM, for comparison the UD5 has 1 of these for 4 DIMMs.
    System Agent VR:
    The second IR3570 3+2 phase PWM uses 2+2 of its phases, 2 for another two memory phases and 2 for the System Agent VR, basically the System Agent, and the twi memory VRs are clones. Just think about how much power is being given to the System Agent power plane, compare it to LGA1155 and its surprising upgrade. So is the spec, both QPI/VTT and System Agent voltage can each handle 24A and 1.4v during OC, that is what Intel claims.
    Here is an up-close of these power stages:
    PCI Lane Distribution:
    There are a total of 40 PCI-E 3.0 lanes, all of which can be used for the slots, and they are. The first 16X and second 16X(8X electrical) slots are directly wired to the CPU, the first 8X of the 3rd 16x slot is directly wired. The second 8X of pins of the 3rd 16X slot and the last 16X(8X electrical) slot have their lanes switched by NXP PCI-E 3.0 switches.
    To carry in some good transition, we have the switches above, along with our dual BIOS. GIGABYTE's new UEFI and 3D BIOS need a large 64MBit ROM, and we have two of them.
    That is the typical iTE8725 which is found on most GIGABYTE LGA1155 boards, on those boards it provided LLC and DVID, on this board it provides precision overvoltage or something along those lines.
    ITE8728F provides PS/2:
    ITE8728F provides SuperIO capabilities like fan, voltage, and temp monitoring and fan control, if that wasn't enough GIGABYTE added a second SuperIO:
    This Winbond SuperIO adds MUCH more fan and temperature monitoring, as well as the auto-OC button on the backpanel.
    This motherboard has 7 fan headers!
    Here are the dual clock generators:
    The mother of all chipsets, the PCH X79, the most extreme consumer chipset:
    Dual Marvell SE9172 provide SATA6G, 4 extra ports with RAID:
    Audio, well how about an upgrade!
    ALC898 is a 110 dB SNR HD and Blu-Ray capable 7.1 audio codec. Its an upgrade from the ALC889.
    Did you upgrade us again GIGABYTE? Indeed with Intel NIC:
    Now this is the Intel PHY that was released earlier this year, and used on some LGA1155 boards. Now I heard a lot of people ask for this, and here it is.
    Finally to finish up this section, let's do a 3 in one:
    We see a new name to the motherboard USB 3.0 game, the Fresco Logic FL1009, two of these provide a total of 4 USB 3.0 ports. At least we know the DMI wont be clogged, but here I have a theory on why we see X79 boards with less USB 3.0, and here it is, people don't really have more than 2 USB 3.0 devices. personally I have one, and its a USB 3.0 stick, and its pretty cool. To be honest if it wasn't a review sample I would not have bought it, only because it costs too much. Personally I would like to see some more USB 3.0, luckily there are a lot of PCI-E 1X slots if in the future you decide to add more.
    There is also in the picture above the only analog PWM on the board, a single phase Intersil used on all LGA1155 GIGABYTE boards, it controls the IR MOSFETs.
    Included Software:
    BIOS Walk Through:
    Test Setup and the Board in Action!:
    Here is an OC guide for the board from Dinos22:
    Now Digital comes with new LLC, so here is how it works:
    I only had a few hours to OC, and it wasn't hard hitting 4.8ghz, but I had to leave C1E on for some reason. I was told BIOS engineers only have had a few weeks to work with the new boards, and they are working hard to get it in perfect condition. There are some minor issues, but for the most part there were no stupid boot loops, and OC recovery works (most of the time), and most everything works as usual. There are a few things that can be improved, and will definitely be, I do have a lot of hope, as so far its pretty neat BIOS. Very snappy, and keyboard is very responsive.
    So this I hit pretty easily:
    But more to come along with an SBe OC guide! No worries people, it will be out soon, I just need some more time.
    BUT there are some HUGE changes:
    vAbsolute for VCC(Vcore) is 1.4v instead of 1.52v on SB? but SVID still goes to 1.52v.
    VCCSA(system agent) has SVID.
    VCCSA and VCCIO can go upto 1.4v comapred to 1.2v on SB
    VCCSA seems to be the IMC voltage, so use it for memory OC instead of VCCIO.
    BenchMarks:
    Conclusion:
    All in all I was impressed by the BIOS, while I might enjoy the simplicity of non-UEFI, I do like all the control I have. Of course there is always room for improvement. What I really enjoyed were all the UD7's features. I used some low rated memory, but I was able to get some mixed kit up to 2400 in the BIOS, and I will see if I can get that to work and bench a bit. Of course I do have an OC guide on the way, and there should be some nice results in there. This board really is well decked out, and GIGABYTE has really given their whole lineup some polishing. They upgraded the audio, they upgraded the NIC, they upgraded the BIOS, and they upgraded the PWM and it seems like they gave all their boards the full treatment. The amount of spacing on this board is immense, and the feel of it reminds me of my X58A-OC which was sitting idle while I was messing around with its new younger brother the X79-UD7. The new Digital PWM and the new VRM components are very nice to say the least. I am not missing the 24-phase power, as this VRM seems to do the job not only well enough, but also packs one heck of a punch into 1/4 the area of the 24 phase while giving me more and better control over its aspects. LLC isn't broken, and I have faith in a lot of its controls.
    Now the board should have some more USB 3.0, and it can also have some extra DIMMs, and then it can also not be ATX-XL. Those three things will deter a lot of users from buying this board, and if you are one of them GIGABYTE and others have other boards to offer. This board is definitely a benching board, built for extreme overclocking, with a very nice feature set. Sure it might live on a test bench, but it can also live out its days inside a nice decked out case (an expensive ATX-XL case at that), and be a fully functioning member of the community. While it has that benching board feel of the X58A-OC it also feels like a 24/7 board like the Z68X-UD7. You might say its a mix of the two but with some extra spice thrown in. This really is how GIGABYTE's LGA1155 UD7 should have been, and I am just glad that GIGABYTE is eventually making the change. One thing that might throw a lot of new users off is the immense amount of PWM options in the BIOS, but there is hope as the 3D BIOS does offer much easier and managed control over the PWM settings. This board is how a proper high-end platform should be done, from its performance to its build, it really is one heck of a board. Its also really fun to work with as well.
    MSRP prices:
    Assassin2 $ 429.99 – available later
    X79-UD7 $ 389.99 – available later
    X79-UD5 $ 349.99 –
    X79-UD3 $ 269.99 –
    Also GIGABYTE is upgrading their warranty to 5 YEARS on the boards listed above!
    I am Xtreme
    Jul 2007
    Montevideo - Uruguay
    very nice review mate !!! hope giga turns good again on this new platform !!!
    cheers
    Sergio
    24/7 - 5930K 46.5HT + ASUS R5E + DDR4 4x4GB 3100C15 1T + 2x 1TB SSD + 1x 3TB HDD + 4 SLI GALAXY GTX780 HOF + SEASONIC P-1200 all Water Cooled
    TRig - 4770KHT + ASUS M6E + GeIL 2x8GB 2666CL11 + GeiL Zenith 240GB SSD + GALAXY 750Ti HOF + CM 1200W + Raijintek Triton Liquid Cooler
    Mar 2010
    Awesome job, thank you very much.
    Aug 2008
    Atlanta
    The updated digital PWM and VRM looks promising. I'm also glad to see a more useful implementation of LLC control for this platform.
    Haswell/IB/SB on a Dimastech Bench table.
    Jun 2007
    Srbija Vojvodina Pancevo
    awesome review
    No volts, no nothing
    [SIGPIC][/SIGPIC]
    I am Xtreme
    Sep 2006
    Any test with Hypers Sin ?
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Nice review can u test Hyper and BBSE too?
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    I like this users reviews! What temps under load after OC? CPU, VRM? Thx.
    ROG Power PCs - Intel and AMD
    Jan 2008
    Bonnie Scotland / Sunny England
    Tempted... Cheaper than the Asus but the lack of slods and Intel Sata ports upsets me... 4x SSD's in RAID0 here and until I buy a RAID card (or get my xmas pressy) then I'm a bit held back
    PROJECT :: The Xtreme (WET) Dream!!!
    PERSONAL H2O BESTS :
    E8600 @ 4.8GHz
    E6750 @ 4GHz QX9650 @ 4.6GHz
    i7 920 @ 4.6GHz
    PERSONAL AIR BESTS :
    Sempron140 @ 4Ghz (Stock Cooler)
    i7 3960x @ 5.4ghz (Air Cooler)
    Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
    Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
    Swift_Wraith : "could someone please check bex for a penis?"
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Nice review Sin!
    Quote Originally Posted by Leeghoofd View Post
    +1
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
    Oct 2008
    Lake Bodom
    Hmm...no molex connector on board or did I just not see it? Wouldn't this initiate a 24-pin connector melt we have seen on X58? When running 3- or 4-way SLI? Or has something changed with X79?
    Core i7 Extreme 4960X @ 4.5 GHz, Asus Rampage IV Black Edition, 32 GB Corsair Dominator GT DDR3-1866 MHz, GTX 780 3-way SLI, Corsair AX1200, Corsair 700D, Corsair H100i, Corsair Force GT 180GB, Windows 8 Pro, Asus VG278HR
    Core i7 Extreme 990X @ 4.4 GHz, Asus Rampage III Black Edition, 12 GB Corsair Dominator GT DDR3-1866 MHz, EVGA GTX 580 "Black Ops" SLI, Corsair AX1200, Corsair 650D, Corsar H100, Samsung 830 256GB, Asus ROG Thunderbolt, Windows 7 Pro
    Nov 2006
    Bar,Montenegro
    Always like to read your reviews, lots of interesting information to be found in it...
    I am Xtreme
    Dec 2004
    France
    Quote Originally Posted by andressergio View Post
    cheers
    Sergio
    Thanks man, i hope so too.
    Quote Originally Posted by El Maño View Post
    Thank you!
    Quote Originally Posted by PolRoger View Post
    Yes its nice that its working correctly, but I still want more levels. It goes from 100 to 80 to 60 to 0, where did 40 and 20 go? 0 is the strongest, a bit too strong, and 60 is about right for OCing, but itd be nice to have a 20 or 40 or 30. BTW .8mohm is Intel's load line slope, so its a slope, so a slope of 0 would be a horizontal line, correct? well then that would signify droop under load, as in none. As the slope increases the droop increases. I just hope newer users understand that 100% is the most droop.
    Quote Originally Posted by D0m|nat0R View Post
    awesome review
    Thanks!
    Hey, if I had hypers i would test them, but to be honest I only started collecting nice kits for about a year, and really only have bad kits. I did order a kit though last night to use in my OC guide, IDk what is in it, but it should OC well. Some memory on this platform OCes extremely well, I think they are BBSE or PCS kits, not sure tho.
    Quote Originally Posted by hiwa View Post
    Same answer as above, ill do my test the memory I have on hand, and post the results.
    Quote Originally Posted by FlanK3r View Post
    I will measure soon, but the VRM area gets hot, and that is about it, for me the CPU wasn't that hot actually.
    Quote Originally Posted by RCG_Bex View Post
    The lack those extra 4 SAS/SATA6G ports has made a bunch of people sad, . At least this platform is more fun to OC than SB.
    Quote Originally Posted by miahallen View Post
    Nice review Sin!
    +1
    Thanks man
    Quote Originally Posted by xarot View Post
    Two SATA power connectors, equivalent to two molex connectors, just these are simpler and don't get in the way.
    Quote Originally Posted by Perica_Barii View Post
    Thank you!
    Xtreme Legend
    Mar 2005
    Australia
    I put together an OC guide with an UD7 board. It's pretty straight forward like SB, you dont need to be a rocket scientist to figure it all out quick but still hope it helps
    Team.AU
    Got tube?
    GIGABYTE Australia
    Jul 2006
    Marseille, Fance
    Giga 3D Bios seems to be nice Is it a copyrighted feature from Gigabyte ?
    The Devil's Reject
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by noobzed View Post
    it probably still won't stop those guys making identical copies over time LOL
    Team.AU
    Got tube?
    GIGABYTE Australia
    Xtreme Mentor stasio's Avatar
    Jan 2008
    Malaysia
    Hey guys,
    any beta BIOS available?
    Btw,
    Easy Tune6 (Intel X79) B11.1110.1
    http://download.gigabyte.eu/FileList..._intel-x79.exe
    Need a Gigabyte latest BIOS?
    Z370 AORUS Gaming 7,
    GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
    GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
    G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
    2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
    Evga GTS 450 SC, Gigabyte Superb 720W
    XSPC RayStorm D5 EX240 (Liquid Ultra)
    NZXT Phantom 630 Ultra Tower
    Win 7 SP1 x64;Win 10 x64
  18. #18
    XIP
    Nov 2004
    NYC
    Can't find retail in US
  19. #19
    I am Xtreme
    Dec 2004
    France
    wait 2 days.
    @Dinos i added your video to my review in the section.
  20. #20
    XIP
    Nov 2004
    NYC
    They gotta put this one on retail channel in a hurry...Newegg already jacked up RIVE price by $20
  21. #21
    Mar 2010
    Now I only need to find a case big enough to house this XL-ATX board
    It might be a serious problem. I would buy this mobo straight away but I can't find a proper case I can buy here.
  22. #22
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by stasio View Post
    Hey guys,
    Btw,
    i'll email you shortly with a full list of bios files you can put on TT support site
    Team.AU
    Got tube?
    GIGABYTE Australia
  23. #23
    Xtreme Legend
    Mar 2005
    Australia
    you just need to find a case with a space for a spare slot if you know what i mean
    Team.AU
    Got tube?
    GIGABYTE Australia
  24. #24
    Jan 2008
    Malaysia
    Quote Originally Posted by dinos22 View Post
    Thanks.
  25. #25
    Xtreme Guru
    Jul 2004
    dude if I could sell all this bulldozer crap and start over. It took me way too long to edit this video on 8120@4ghz.
    you did a great job with the review. I wish it came out a month ago, I bet that thing can render vids in an 8th of the time it took me to make this. it took 3 min for this crap.
    Dinos22 provided the footage. (he just doesnt know it yet) sshhhhh.
    http://youtu.be/Q55bYcirwiQ
