Interesting discussion, particularly in regards to test methods.
I have always been frustrated by the rather inconsistent mounting results I've been able to achive despite taking every effort to be careful.
I have also previously tried to reduce mounting mechanism variables by utilizing one set of hardware (Same backplate/springs/thumbnuts).
I've also been criticized (Manufacturers included) for NOT using the OEM mounting hardware with the thought that not doing so is not testing the whole package mounting system. I guess I tend to agree with that now, but it doesn't help reduce variables any. Unfortunately as already mentioned, many or most mounting systems do not fix the mounting pressure. I also agree that "Mechanical Contact" has become what separates the very minor differences in blocks and the mounting mechanism is perhaps more important than the block internals.
So should we be testing blocks or mounting mechanisms, and how can you test mounting mechanisms if there is no real way to define what the users will do when systems do not fix mounting pressure?
Finally comes the other variable I don't think any reviewer will capture and that is sample variance and IHS shape differences as previously noted. I have tried testing multiple block samples and have found differences. Unless you test 10 blocks over 10 mounts over 10 different processors, you're still probably only good to .5C.
It's not perfect, just one tested condition with one block with one processor giving an approximate result. Don't like it, go home and do your own testing...
