Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 136
Thread: Raid 0 - Impact on NAND Writes
    Xtreme Mentor
    Feb 2009
    Here I experiment with raid 0 to see the impact on writes to nand with a 128K and 4K Stripe.
    The Set Up
    Frankenstein R0
    Vertex 2 and Vertex 3
    User capacity 74.5GiB
    Test files size: 74.43 GiB (4MB block size)
    Work load: 4K random full span 100% incompressible
    Drive in steady state
    Stripe: 128K SMART readings before starting:
    Vertex 2
    E9 41216
    EA 44672
    Vertex 3
    E9 41600
    EA 41552
    SMART readings after:
    Vertex 2
    E9 42112
    EA 44864
    Vertex 3
    E9 41923
    EA 41726
    Amount of data written = 279,135.94MiB + 76,216.32MiB = 355,352.26MiB/ 347.02GiB
    Nand Writes to Vertex 2 = 896GiB
    Nand Writes to Vertex 3 = 323GiB
    Total writes to Nand = 1,219GiB
    Host Writes to Vertex 2 = 192GiB
    Host Writes to Vertex 3 = 174GiB
    Total writes to Host = 366GiB
    Ratio between nand writes and host writes = 1:0.30
    Speed at end of run = 10.03MB/s
    Stripe: 4K SMART readings before starting:
    Vertex 2
    E9 42,112
    EA 44,864
    Vertex 3
    E9 41,936
    EA 41,734
    Vertex 2
    E9 43072
    EA 44992
    Vertex 3
    E9 42,252
    EA 41,903
    Amount of data written = 268,862 MiB + 76,216.32MiB = 345,078.32MiB/ 336.99GiB
    Nand Writes to Vertex 2 = 960GiB
    Nand Writes to Vertex 3 = 316GiB
    Total writes to Nand = 1,276GiB
    Host Writes to Vertex 2 = 128GiB
    Host Writes to Vertex 3 = 169GiB
    Total writes to Host = 297GiB
    Ratio between nand writes and host writes = 1:0.23
    Speed at end of run = 12.75MiB/s
    Stripe: 128K SMART 4k random full span. 50% OP - readings before starting:
    Vertex 2
    E9 44,096
    EA 45,760
    Vertex 3
    E9 43,131
    EA 42,670
    Vertex 2
    E9 44,224
    EA 45,888
    Vertex 3
    E9 43,268
    EA 42,789
    Amount of data written = 206,573.44MiB + 3,7785.6MiB = 238.63GiB
    Nand Writes to Vertex 2 = 128GiB
    Nand Writes to Vertex 3 = 137GiB
    Total writes to Nand = 265GiB
    Host Writes to Vertex 3 = 119GiB
    Total writes to Host = 247GiB
    Ratio between nand writes and host writes = 1: 0.93
    Speed at start of run = 48.95MB/s
    Speed at end of run = 37.71MB/s
    ASU Endurance App (Client not enterprise workload) Drives SE’d. Stripe: 128K SMART readings before starting:
    Vertex 2
    E9 43,392
    EA 45,248
    Vertex 3
    E9 42,529
    EA 42,170
    Vertex 2
    E9 43,648
    EA 45,440
    Vertex 3
    E9 42,717
    EA 42350
    Amount of data written = MiB = 356.13GiB
    Nand Writes to Vertex 2 = 256GiB
    Nand Writes to Vertex 3 = 188GiB
    Total writes to Nand = 444GiB
    Host Writes to Vertex 3 = 180GiB
    Total writes to Host = 372GiB
    Ratio between nand writes and host writes = 1:0.84
    Speed at end of run = 66.34 MiB/s
    Single Drive - Vertex 2 4k random full span. 14.65GB user space, 22.62GB OP- readings before starting:
    E9 44,224
    EA 45,888
    E9 44,480
    EA 46,080
    Amount of data written = 206,555.08MiB + 14,899.2MiB = 216.26GiB
    Ratio between nand writes and host writes = 1:0.75
    Speed at end of run = 31.12 MB/s
    Single Drive Vertex 3 4k random full span no OP- readings before starting:
    E9 43,268
    EA 42,789
    E9 44,010
    EA 42,926
    Amount of data written = 82,850.78MiB + 57139.20MiB = 136.70GiB
    Nand Writes to Vertex 2 = 742GiB
    Host Writes to Vertex 2 = 137GiB
    Ratio between nand writes and host writes = 1:0.18
    Summary
    TRIM is not effective if you have a 4K random full span work load.
    Over provisioning had a significant impact on reducing wear whilst at the same time increasing write speeds
    With a R0 4K array it took around 431GB of writes for the drive to get to a steady state when running the ASU client workload. Write speeds progressively fell by 26%. (See post #20)
    When running the 4K random write work load, write speeds dropped by 50% after 2 minutes and started to fluctuate. After a further 4 minutes writes speeds dropped by 50% again and fluctuated more. (See post #42)
    Read speeds were significantly impacted when the drive was in a degraded state. (134MB/s on a R0 array) Steady state performance came out at around 290MB’s for reads.
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    could that be throttling at all? doiubt it with the low usage so far though. Very interesting testing! subbed
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
    Xtreme Mentor
    Feb 2009
    100,000 MiB and write speed is now 8.34mb/s. (I don't think it has anything to do with LTT).
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    wow that is terrible tbh. Now, do you feel that might have something to do with the inability of SF to handle incompressible data effectively, or just reflective of results with most SSDs?
    There is an effect on the performance of the write speed of typical SSDs during long testing scenarios with writes, that is where enterprise devices shine, they are truly optimized for it. Here is an article, and a snip, that i have had in my read list for awhile now. I am going to do some variant of this type of testing for a future review of lightning 6gb/s devices.
    This is with single devices, the raid array responses will be vastly different of course.
    www.itworld.com/storage/187659/review-enterprise-solid-state-drives
    Xtreme Mentor
    Feb 2009
    I’m using a special enterprise version of Anvil’s app. The write speed seems to have levelled out now. This is a torture test for sure. Without TRIM or idle time the drive is incurring the max read-modify-write penalty. A single drive with TRIM did not behave this way.
    I don’t know if I could bring myself to inflict this kind of test on my Intel’s. On the other hand it would be interesting to see how they performed in a R0 set up.
    The real reason to do this however is to see how many writes end up on each SSD. When I’ve done with 4K I’ll run the normal version of Anvil’s app to see if a mainly sequently loads makes any difference.
    Xtreme X.I.P.
    Apr 2008
    Norway
    There will be an option to fill the drive using 4KB blocks (instead of 4MB) and that really makes a difference for some of the drives.
    Hardware:
    Xtreme Mentor
    Feb 2009
    Write speed has improved a little. It's now 10.08mb/s with 268,750MiB of data. As it is taking so long I'm tempted ot break up the array and check the SMART values
    Xtreme X.I.P.
    Apr 2008
    Norway
    That would be interesting
    Please do a HDTune Benchmark using 4MB block size, seq reads should have taken quite the dive vs in fresh state.
    Hardware:
    Xtreme Mentor
    Feb 2009
    Any special settings on HD Tune? Full or partial? Fast or accurtate?
    Xtreme X.I.P.
    Apr 2008
    Norway
    Just the 4MB block size (found in settings) and a full span read test -> Benchmark tab
    Hardware:
    Xtreme Mentor
    Feb 2009
    HD Tune said it would not run with an active partition so I deleted it but it still would not run. After reinstating the partition AS SSD gave me:
    Write 14.06
    Read 134.00
    Going to break the array up now to check the writes
    Xtreme X.I.P.
    Apr 2008
    Norway
    The reads are just as important (if not more so) as the writes and the test shows that it's highly degraded, I'd say 134MB/s is as expected from such an exercise. (unfortunately)
    HDTune won't let you run a write test with an active partition but the read test should work, otherwise there is something seriously wrong.
    edit:
    Next time you should try deleting the file from the Endurance app and then Fill the drive it using 4MB blocks and then do a HDTune read test. It should show how quickly it restores performance, reads in particular.
    Hardware:
    Xtreme Mentor
    Feb 2009
    First post updated with results. 4K stripe comming up next (after a couple of HD Tune read benchmarks).
    Sep 2009
    Quote Originally Posted by Ao1 View Post
    Can you not read SMART while in RAID0?
    Xtreme Mentor
    Feb 2009
    Now running with a 4K stripe. I let the drive idle for a few hours and formatting the drive would have generated a trim operation, but the write speeds were still heavily degraded when I started the test. The sequential test file speed came out at 15.41MB/s (compared to 100.34MB/s when I ran the 128K stripe), although the 4K stripe seems to work a bit better with the 4K work load. 100,000MiB in and its sitting at 13.75MB/s (compared to 8.34MB/s with the 128K stripe).
    The graph shows the slowdowns that occur as the drive tries to clear a path ahead of writing.
    When I’m done with this run I will S/E the drives and then see how long it takes to get to a fully degraded state.
    Quote Originally Posted by some_one View Post
    Sadly no and I can’t find a way to get around it.
    Sep 2009
    Have you tried smartmontools?
    What does running "smartctl --scan" show?
    Xtreme Mentor
    Feb 2009
    First post updated. The 4K strip was marginally faster, but the ratio between nand/host writes was worse, which may have been attributable due to the fact that the drive was in a degraded state on this run.
    Drives S/E’d and running 4K random to see how long it takes for the drive to degrade. (It started to degrade after 5 minutes. Currently 227 seconds in and avg writes speeds are at 14MB/s.
  18. #18
    Xtreme Mentor
    Feb 2009
    OK, disks secure erased, reset in raid 0 with a 4K stripe.
    Avg to fill the drive = 144.37MiB/s.
    Fully degraded state within 362.45 seconds & 24.15GiB (+ test file 74.43GiB)
  19. #19
    Feb 2006
    Stuttgart, Germany
    Interesting tests, yet somehow predictable. 4K writes full span with no static data should lead to WA around 10-20 and maybe even higher degradation than what you see. For such a scenario, only larger spare area should help. I believe trim is useless, because there would be no complete free block to be cleared. You could do SE and decrease partition size after to simulate extra spare area.
  20. #20
    Xtreme Mentor
    Feb 2009
    ASU Standard Endurance Test 12GiB free. 100% incompressible.
    Total Time: 1.25 hours
    R 0 4K Stripe. MB/s from fresh to steady state
  21. #21
    Xtreme Mentor
    Feb 2009
    Quote Originally Posted by sergiu View Post
    I think there might have been some static data when I ran the same test on a single drive. Can’t remember but will check later, however the single drive with trim performed significantly better. Avg MB/s after 0.7TiB of data = 28 compared to 13 with a 4K stripe.
    I'm running the same tests with the normal version of the endurance app now so let’s see what happens then.
  22. #22
    Xtreme Mentor
    Feb 2009
    Anvil, here is a HD Tune run straight after the endurance app run above. (4MB)
  23. #23
    Apr 2006
    Hong Kong
    Could someone put the results that have so far been observed into more layman terms? I'm having a bit of trouble following.
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
  24. #24
    Xtreme Mentor
    Feb 2009
    Quote Originally Posted by CedricFP View Post
    Moved to 1st post
  25. #25
    Feb 2006
    Stuttgart, Germany
    With static data around, ratio between spare area and usable area for 4K full span is higher which would lead also to better performance. Trimming might have helped because of the file size (4MiB which is equal to 512 or 1024 pages) possibly at the cost of higher WA. But for 100% 4K writes full span where drive would be seen as a single file in which pages are constantly overwritten, I cannot see how trim will help, as each overwritten page would free only one. But who knows, maybe with trim help, wear leveling algorithm would choose better candidates for erasing.
