Alright, I received my compressor after its trek from Canada to here. It seems to have been right side up, upside down, or on its side through various parts of its journey so I am concerned that the oil may have drained into the accumulator which might make for problems starting it up later when I finally do.
So that said, how do you change the oil on one of these? Do you just drain it into the accumulator (assuming the suction line is accessible to the oil chamber) and then pour it out from there involving some tipping and rotating, etc? I was considering contacting Tecumseh to ask them where in the casing I might drill a hole to drain such oil and install a drain port.
