NM I think I got what I was looking for....
something about resistance and capacitance of a circuit..
All along the watchtower the watchmen watch the eternal return.
They don't, it's a sensor bug.
Silverstone Sugo SG08 | Enermax Modu82+ 625W | ASRock Z77E-ITX | Intel Core i5 3570K /w Indigo Xtreme + CoolIT ECO II ALC + Noctua NF-P14 FLX | 2x4GB Samsung M378B5273DH0-CH9 /w Xilence Heat Pipe Duo | Sapphire HD7870 GE | Kingston HyperX T3 120GB | 2TB Samsung Spinpoint F1
lol this is the best thread in xtreme overclocking ever
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
Spectating;
2010; GOOC 2010 Many thanks to Gigabyte!
it gest hot because it is sexy
Vishera 8320@ 5ghz | Gigabyte UD3 | 8gb TridentX 2400 c10| Powercolor 6850 | Thermalight Silver Arrow (bench Super KAZE 3k) | Samsung 830 128gbx2 Raid 0| Fractal case
because they can
Oh brother
Sent from my T7575 using Board Express
basically, the objects you are forcing electrons through are not perfectly smooth on the atomic scale so the electrons take a weird route and deposit some energy into the object because they have to change direction and speed
( this is partly the reason some electronics can be improved with more conductive materials, such as gold, silver )
if you want it really simple it gets hot from friction, essentially
now, what i think you really mean is why is my cpu hot, and that's probably because the heat-sink is dusty or the voltage is too high
im still scratching
CPU's get hot because reasons.
Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
if your cpu gets hot, you're doing it wrong
Where courage, motivation and ignorance meet, a persistent idiot awakens.
because there is electron flying though the dies and because it's speed and that creates fraction and that creates heat cuz it's energy needs to be released
Come on everyone / this person's asking a serious questions that deserves an honest answer... Most newer CPU's get hot because they have plutonium circuits which require allot of voltage... This causes allot of heat which requires extra cooling...
Windows 7 64 Bit
BenQ FP241W Black 24" LCD
Mountain Mod Case w/ Base
Asus Rampage III Black Edition
i9-990x @ 4.58GHz - 1.36v Temps (Idle 23C - Load 48C)
12GB Corsiar Dominator GT (PC3 15000) @ 9-9-9-24 1T - 1.65v
Sapphire 5870 x3 "OC" w/ EK Water Block Temps (25C-49C)
EK-Supreme / 4 Alphacool Laing DDC-Pump Ultras + Extras
Power Supply / 2x Silver Stone DX1000
Western Digital 1.0TB x 3
Crosair SSD 128GB x 2
World Community Grid!
Windows 7 Ultimate x64
Cooler Master HAF 932
Intel i5 750 @ 3.8Ghz LC Fuzion V2
ASUS P7P55D Pro
2GBx2 GSKILL F3-16000CL9D-4GBRH
eVGA GTX 470 SC Koolance Full Cover
Corsair VX 550
Dell 2209WA & 2709W
Razer Lycosa & Cooperhead
The same reason why a wood chuck chucks wood and gets hot chucking all day long. If you were a wood chuck you would know why CPUs get hot too.
Support Your Local Sheriff - At high noon
My Heatware http://www.heatware.com/eval.php?id=63611
The pump Maverick, BMaverick ... has a massive hoard of a Laing DDC pump stash
Cpu are allways hot, some are well cooled and then are warm...
Cpu as for many years are known as cpu, but latley i can call cpu Spu=support processor unit.
Nowdas we got even "audio processing" inside graphics processors=gpu that can take extreme calculations away from Cpu.
You do realize that space between atoms is thousands times greater than size of electron right ?Originally Posted by evoted
There is no friction on that scale.
Not a single close answer in this thread. Enthusiasts
I guess here: http://www.allaboutcircuits.com/vol_1/chpt_2/5.html
In lamens terms the resisters required to produce the 0/1 series of instructions @ a transistor level have to have resisters up to them to deliver the power required to each one. Adding resistance to control the power flow to precise levels generates heat in addition to when the actual circuit switches for its clock speed. When the flow of power is cut off the excess has to go somewhere either in terms of heat, light or magnetism same with the other power that was wasted to get your previous 1.25v down from your AC power source or DC power source ie 12v. The higher the power power a chip needs the higher the flow has to be and the higher the flow the more power that is wasted getting it down it and the wasted power is turned into heat.
NZXT Tempest | Corsair 1000W
Creative X-FI Titanium Fatal1ty Pro
Intel i7 2500K Corsair H100
PNY GTX 470 SLi (700 / 1400 / 1731 / 950mv)
Asus P8Z68-V Pro
Kingston HyperX PC3-10700 (4x4096MB)(9-9-9-28 @ 1600mhz @ 1.5v)
Heatware: 13-0-0
