Current Status - Testing & Research
This is getting realy interesting
yeap, i hope people are picking up on the tweaks and are re-benching. its always great to see efficiency progression in threads like this
on a side note:
107.2 bclk gets me into the 7:00:8XX range, so scaling is moving along just as expected
@ cheapseats
read gets better with tighter tfaw, when you are too tight, it drops as does the 32m efficiency.
Stelios, please take a look at easy tune one more time. The behavior I am seeing is the bclk slider reports the same as what is set in bios, however the .2 loss is apparent when you click the cpu tab. I cant confirm for the boards you have, but thats what Im seeing with P67A-UD7 B3 and Z68XP-UD4. I suspect it has something to do with some skew options that arent visible in bios.
hmm Zen, can you test tFAW 16 performance again but on XP ?
if tRRD 4 = min, then 4*tRRD 4 = min 16 clock window..
you can't change 'four activate window' into '3.25 activate window'
some new runs with your 25/26 RTL
note still old aida version (it's showing around +150Mb/s read, +1Gb/s copy, but latency same as newer version)
107.3 6m59.797
108.1 6m56.844
these 2 also 25/26 with tRAS 13 (was 14), tRFC 34 (was 36), tRC 18 (was 25)
107.2 6m59.906
108.1 6m56.687
Maximus V GENE [0086] :: 3770K L212B244 :: H70 :: EB3103A (PSC)
CL|WCL|RTL performance (SB) : 32M scaling charts : PSC WCL > CL performance bug
Nice runs! Good to see RTL is working out for you
I will re-bench it tonight... but I im 99.999% sure there was a gain when I tested previously. Normally I'd agree with you, but trrd x 4 = 4 I think aida is bugged.
will try to run off 107.2 XP, but the board is being weird.... 107.2 takes some patience and fanagalling. should net me 7:00 time.
I see why now gtx2 are truly worth the money. trc stops at 28 for me, 31 is optimal. trfc stops at 35, 36 is slow 37 is optimal. tras 14 is as low as it goes. im only giving 1.65v... i dont want to fry hypers at low clocks... though they are worthless to me at high clocks so i may throw that into the continuous testing/tuning
*edit*
TFAW13
TFAW16
so mabye it doesnt make sense, im going off of what ive tested. tfaw below 16 = gain. my 32m is very consistant +-.02 every time. sorry, dont have aida on the xp hd to show timings but i assure you only tfaw was changed. i can install it to show tfaw change and re-run with pretty much the same results if you really really really want me to.
I'm glad i dicided to open this thread, learning some tips and tweaks
Keep on the good work.
Research is the key for WR on SPi32M
|Asus Maximus 4 Extreme B3_ Bios 1904 / 3202
|Intel i7 2600K / 3770K Corsair H80
|G-Skill F3-18400CL8D-4GB PIS @ 2133mhz 6-9-6-24- 1T 1,71v
|MSI Lightning 580GTX 1,5GB
|OCZ vertex_60Gb FW_1.6
|Corsair 750W AX
[testing...] "Dude, BSOD is something that... doesn't suit me!"
see sig (not there yet, but some day... im fairly confident in my 2d ability)
lets see some re-benching! Counter CS, you should be at my times, all the info is given in this thread pretty much, dont let the cas4 fool you
anybody care to share some os tweaks? i will if you will
@ loud
we are using 1:5 ala 1333 strap. i will switch to gskill blue on giga right now to see where things are at.
*edit*
now i wonder if tras12 is doable on my "good" sticks. bsod at windows boot 1.5v
*edit edit*
not going to be as fast as hypers. subs are higher, rtl is 27/28
