Results 1 to 21 of 21
Thread: Flow issues with new water blockes
    Jan 2010
    Houston, TX
    I recently got a pair of EVGA 3g GTX 580's and EK water blocks. The are replacing 3x GTX470's and Koolance water blocks.
    My problem started with the 470's and the Koolance blocks (I have a previous thread). The flow was seeming to get restricted and my flow meter would seem to "stick". I would give it a tap and it would start spinning. My flow was about 4.9 - 5.2lpm. I could feel the preasure building before the blocks and the lack of preasure after the blocks, which is where my flow meter is (Koolance FM17). note: My original loop had just 2 blocks and a XSPC 240 Rad and the problem started when I added a third block and swapped the 240 for a 360 Rad.
    I opened up my blocks a couple of times and had to clean trash from the first block. I also emptied and flushed the Rad the first time this happened, and yes I cleaned it with hot water during the initial installation, but the problem persisted.
    Now I have replaced the 3x GTX470's with 2x GTX580's and EK EN Nickel Acetal Blocks with back plates and a FC Parallel Bridge. My flow started at about 7.2lpm and then dropped to 4.9 -5.2lpm after about a day.
    Also I drained the loop about a week ago when I removed the 470's and installed the 580's to run them before installing the blocks. I connected the hoses but didn't put water in, I just disconnected the pump.
    What's the best way to fully flush and clean my loop and would a filter help or would it be too restrictive(koolance makes one)?
    Any ideas on where the trash is coming from? I appears to be the same color as my tubing which is Red Primochil 1/2".
    One more note: my temps don't seem to be noticably affected.
    Loop contains: XSPC Dual bay Res w/pumps, Liang DDC 3.25, XSPC 360 Rad, 2x EK FC Water blocks
    HAF 932-ASUS Rampage Formula III-i7 980x-12G G-Skill Sniper 1600 C9-GTX970 4g SLI-Corsair AX1200i PSU-Dual Loop WC
    Thermaltake W200-Rampage V Edition 10-i7-6850k-G-Skill TridentZ F4-3200C14Q-GTX1080Ti Strix SLI-Corsair AX1500i-Dual Loop WC
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    Are you shure you cleaned the rad enough? Sometimes it can take alot of time and work to get it all out. Are you running any additives in the loop?
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
    Jan 2010
    Houston, TX
    No, now I am not sure, at the time I thought I was. My other loop has a 360 Rad also but I haven't had any issues with it.
    Just PC Nuke in distilled water.
    Xtreme Mentor
    Oct 2007
    USA
    Aha, your temps are fine right? Under load testing? Seem to be within the temps what lots of us see with somewhat of the same setup?
    I really hate to say this, but maybe you need to quit worrying about your flow rate. The flow rate sensors we use for water cooling a PC, unless your one to buy a $200 flow tube (think Skinneelabs.com) are pretty worthless.
    Cleaning a rad properly. Fill the rad full of water that was boiling and let sit 5 minutes. Fill the rad. Let sit 10 minutes. Drain 1/3 or so. Shake it, do the rad dance for a few minutes. Drain into a glass bowl. Let sit 15 minutes. Inspect bowl. Any stuff? If so, redo, redo, till spotless.
    My Koolance 470 SLI blocks at the ONE year tear down were rather spotless. My rads have been around a few years tho, and I invented the 'Rad dance' term. So my rads were clean. One of my 470 blocks after a year. They look pretty darn clean eh? Distilled, Petras PHN Nuke, Ianh kill coils.
    First 'Rad dance' coin. Never got to see a vid of a 'dance, I need to make one, my fat assed 53 YO shakin a rad, LOL.
    http://www.overclockers.com/forums/s...d.php?t=592874
    So I'm not sure what the problem is. Your temps are fine right?
    There are VERY accurate PC based flow systems availible at many industrial sites, the PCI card interface and the software is easy to use I'm sure. The sensors are pretty small too. They could fit into a PC case if you have enough $400++ money.
    Never used a flow meter on many diff configs, my component temps are fine. Get rid of the stoopid thing.
    Lastly, are you doing the 6M and the annual cleaning?
    http://www.overclockers.com/annual-w...build-journal/
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Mar 2008
    Well first of all what are your temps under full load? That'll be your first indicator of whether or not there's really an issue.
    "The flow was seeming to get restricted and my flow meter would seem to "stick". I would give it a tap and it would start spinning."
    Is this still happening? If so, it sounds more like there's a potential issue with your flow-meter (maybe it's got some gunk in the spinner or something). Your flowrate should be pretty constant, even if your blocks are plugged up and blocking flow it shouldn't vary (just be low overall).
    You'll probably have to do another breakdown and check your blocks for gunk, but it does sound more like a flow-rate-reading problem rather than an actual flow-rate problem (if your temps really are OK).
    Jan 2010
    Houston, TX
    Yep, my temps have been fine, even under load. That's why I haven't been terribly concerned, However, I found red trash in my first 470 block(They were in series) when I cleaned them. I haven't done the "Rad Dance" though, at least not yet
    So what's the best way to get everything spotless again?
    Feb 2009
    Quote Originally Posted by Megalamaniac View Post
    If I were you I would buy a filter, plug it with quick-disconnects and be done with it (then you can just unplug the filter, clean it, and plug it back without having to fill and bleed your loop again).
    Something like:
    Quote Originally Posted by NKrader View Post
    im sure bill gates has always wanted OLED Toilet Paper wipe his butt with steve jobs talking about ipad..
    Mini-review: Q6600 vs i5 2500K. Gpu scaling on games.
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    Quote Originally Posted by Conumdrum View Post
    lol but i saw a 52 YO run around a office building tring to get everyone he met drunk. :P
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Jan 2010
    Houston, TX
    Temps haven't broken 60c under full load
    Actually I replaced the flow meter when I installed the 580 blocks. The previous flow meter was doing the same thing, "sticking", but I think I killed it trying to use it on my bigNG (unsupported junk) while my TMS200 (slightly less junk)was being RMA'd. Both were vertical with the spinner at the bottom(flow is going up).
    Thats the filter I was looking at.
    My radiator is on a Rad Box attached to the back of my case so it's not that difficult to remove. It's the blocks I'm not to keen on opening, don't want to screw with the warranty with them being so new.
    So I might just be chasing my tail and the flow dropped slightly as the air works itself out? What about being able to feel the difference in preasure when I squeeze the tubing before and after the blocks, I can feel less after.
    I don't dance, I just stand there with my arms folded, could be my whole problem.
    Apr 2006
    Hong Kong
    I have the old style PA rads from thermochill, you know, flux monsters. I thought I had cleaned it well the first 3 or 4 times I put up, tore down my loop - nope. I was still cleaning stuff out of that rad 6 months down the line.
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Jun 2007
    Mission Viejo, California United States
    Also be aware of the EKWB silver plating problems that comes off pretty quickly, a forum member brought this to my attention yesterday after having my EK VGA block installed for over a year now and I have a bunch of nickle plating throughout my loop! My VGA block is now a copper block, I'll be RMA'ing it when I build my Sandy Bridge E in three months. If your EK part number says EN then those are the newer ones that aren't supposed have plating issues.
    * My Case Labs STH10 Build Log *
    Computer System:
    CPU = Intel i7 3770K
    MOBO = Asus Maximus V Extreme
    GPU = EVGA GeForce GTX 480 @ 880MHz|1760MHz|4200MHz @ 1.125v
    RAM = 8GB Dominator GT's
    SSD = Samsung 830 Series 256GB
    PSU = SeaSonic X-1250W
    SC = X-Fi Fatality Pro
    CASE = Case Labs STH10
    LCD = NEC MultiSync 1970GX 19"
    OS = Windows 7 Ultimate 64-bit
    Watercooling System:
    CPU = EK Supremacy Nickel+Acetal
    GPU = EK FC-480 GTX Nickel+Acetal
    MB = EK-FB Asus M5E Nickel+Acetal
    RES = EK-RES X3 250
    PUMP = Dual Koolance PMP-450's w/ EK-D5 Dual Top CSQ
    RAD = Dual HWLabs SR-1 560's w/Gentle Typhoon 1850rpm Fans
    LIQUID = Distilled Water w/Petra's Pure Silver Killcoil
    Jan 2010
    Houston, TX
    I DID get the new EN versions. I almost didn't but after spotting a post about the old ones I did a little research. I then realized the vendor(who will remain unamed) I was about to buy from had old stock. I then got the EN's from Performance PC's.
    I also want to give Performance PC's a . I ordered back plates and because of EK's labeling I ended up with GW back plates instead of GTX ones. I brought it to their attention and they immediatly shipped out the right ones and offered to refund cost of shipping wrong ones back. GREAT Customer service!!!
    Jan 2010
    Houston, TX
    My flow has been pretty consistant and my pumps have always been about 4800 RPM. Thhe other day I noticed my GPU loop has dropped about .8 LPM and my pump RPM to 3990 - 4020 or about 1000 RPM.
    Should I be concerned?
    I have a vacation coming up soon and I plan on cleaning my loops. I was even contemplating dropping my XSPC Dual Res w/pump for the single bay Koolance Dual Res w/pump,(I could use the space) or I could get two and two more pumps and do some redundancy for each loop. Overkill?
    Jul 2006
    I thought rad cleaning was as simple as tap -> rad -> drain, turn on hot water... go do whatever then come back later and flush with distilled?
    Apr 2011
    North Queensland Australia
    Quote Originally Posted by Panthols View Post
    Me too lol
    -PB
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
    Jan 2010
    Houston, TX
    Well looks like My pump died. When I teurned on my machine today the pump wouldn't start. I drained the loop and pulled it (water was clean, no trash) and it looks OK but it won't spin unless I give it "help" by spinning the impeller myself to get it started. Guess I'm getting another pump.
    Id the Swiftech 355 and the Koolance 400 the same as the Danger Den 3.25? I see a little difference in specs but they appear to be the same pump (except about $20 diffence)
    Xtreme Mentor
    Sep 2007
    Dallas
    The PMP-400 is a DDC3.25, so a little more powerful than a MCP355. The Swiftech MCP35X is a 3.25 with PMW control. Personally, I use a PMP400 and a MCP355 with a Heatkiller Dual top and they work great with the loop in my sig.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
  18. #18
    Jan 2010
    Houston, TX
    I figured they were all the same. I'm guessing the specs vary because of creative calculating for marketing purposes.
    Whatever the case I've already got 2 PMP-400's being overnighted. Now I will have a spare pump. I also went ahead and ordered the single bay dual pump res from Koolance to replace my XSPC dual pump res.
    I hooked up both loops in series on the single pump (just moved a hose and added a tee)so I can see if I prefer it that way instead of the dual loop as before. My GPU's are slightly cooler but my CPU is slightly hotter. I'll check it for a couple of days and see if I like it.
    Any ideas on what's wrong with my pump and is it fixable? Would a PCB repair kit fix it? Didn't find any trash in it and the bead that the impeller spins on looks good(shiny and no pits).
  19. #19
    Jun 2007
    Most probably the PCB is fried since that's the hottest place in the pump, how long did your pump last you?
    Computer System:
    RES = EK-RES X3 250
  20. #20
    Jan 2010
    Houston, TX
    Quote Originally Posted by Systemlord View Post
    Bought the pump in April of 2010 so it's only a 1 1/2 years old.
    Like I mentioned above, if I spin the impeller by hand I can get it to run but it won't start on its own. Any way to check voltages on the PCB or know what I'd be looking for to check it?
    Found these. Anyone ever use them?
    http://www.ebay.com/itm/Laing-DDC-pu...25491327905900
  21. #21
    Jun 2007
    I would rather buy a new pump than mess with anything from Hong Kong, you never no what your going to get!
    Computer System:
    RES = EK-RES X3 250
