+ Reply to Thread
Results 1 to 18 of 18
Thread: My little ITX build with A8-3800
    Xtreme Member qcmadness's Avatar
    Oct 2007
    Hong Kong
    3
    Configuration:
    AMD A8-3800 APU (2.4/2.7GHz, 1MB L2 cache x4, 65W TDP)
    Integrated AMD Radeon HD6550D (400 shader, 600MHz)
    Asrock A75M-ITX
    Corsair DDR3-1600 4GB x2 @ CL9-9-9-24
    OCZ Vertex 2 60GB
    Hitachi 500GB 5400rpm
    Panasonic DVD-Writer Slim-size
    Antec ISK-300 150W PSU
    Components:
    Environment:
    Info:
    Storage speed:
    Power consumption:
    ACPI off:
    BIOS:
    Windows idle:
    CPU full load:
  2. The Following 3 Users Say Thank You to qcmadness For This Useful Post:
  3. #2
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (HotWeather)
    100
    that nice ITX !!!
    i5-2500K + Asus P8P67 Deluxe + Mushkin Blackline 8GB - 2133C10 (Hynix BFR) + Asus HD7970 DirectCU2 TOP + Samsung S22A300B
    EK SupremeHF + EK VGA HF + Swiftech 655 + XSPC ResTop + BlackIce GTX360 + LamptronFC2 + NMB-MAT 130CFMx3 Antec 1200W OC Version
    Compaq CQ20 / Lenovo Y450 / Note II / Tab Plus / iPhone 5 / iPad 3
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120
  4. #3
    Xtreme Addict wez's Avatar
    May 2004
    Aland Islands
    24
    How you like that Asrock board, no issues so far?
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
  5. #4
    Oct 2007
    Hong Kong
    3
    Quote Originally Posted by wez View Post
    No issue so far
  6. #5
    Xtreme Mentor Lightman's Avatar
    Nov 2005
    In Car (across Europe)
    140
    Really nice ITX system.
    I'm just waiting for my A6-3650 to finish rebuilding my HTPC but in uATX form factor. Should be fun to tweak and then enjoy for both movies as well as some gaming
    RiG1: i5 2500K @4.5GHz (bad clocker), MSI Z68A-GD65 G3, 2x4GB Corsair Venegence 5.11 PC14900, HD6970 2GB, Samsung SS805 100GB SLC SDD (OS Drive) + 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 1TB Samsung F3, Hiper 4M880
    RiG2: HTPC AMD A10-5800K APU, 2x4GB Kingstone HyperX 2133C11, Gigabyte F2A85XM-D3H, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
    SmartPhone Samsung Galaxy Note II
    XBOX360 Elite paired with 55'' Samsung LED 3D TV
  7. #6
    Mar 2006
    Hellas
    0
    I'm looking for such a system like yours. Really nice low consumption by Llano. If only we knew when the unlocked cpus are going to be available..
  8. #7
    Registered User pumero's Avatar
    Oct 2005
    Austria
    0
    I have this ASRock board at work and discovered one issue:
    It comes without a backplate and there are parts in the area where a backplate would usually sit. Considering that many good coolers require a backplate for installation, this is a problem one should keep in mind.
    I'm also wondering how qcmadness installed the cooler, since the AC model seems to rely on a backplate as well.
    Power Rig: Core i7-3930K, Gigabyte GA-X79-UD3, 16GB Corsair DDR3-1600, GeForce GTX560 Ti
    Timekiller and Media Rig: Apple Mac Mini 3.1, C2D 2.0GHz, 4GB Kingston DDR3-1066
    HTPC: Core i5-655K, Zotac H55-ITX, 2GB DDR3, Silverstone PT-09 w/ 120W Power Brick
  9. #8
    May 2009
    0
    How's the voltage control in BIOS? and have you tried undervolting the CPU? -- as I'm sure you're aware, Llanos have very liberal vCore applied to them... Ive been lurking around the buy button at newEgg for awhile for this board
  10. #9
    Oct 2005
    Austria
    0
    Quote Originally Posted by mrgerbik View Post
    The options are good, with a range of 0.6V - 2.0V possible.
    Considering this is an ITX mainboard, I think ASRock did a great job as there are many options you would expect on a "big" board only.
  11. #10
    Oct 2007
    Hong Kong
    3
    Quote Originally Posted by pumero View Post
    this CPU HS comes with a backplate itself
  12. #11
    Xtreme Member SBB's Avatar
    Nov 2008
    Lincoln, UK
    11
    Which cooler is this?
    Don't worry guys, i'm s**t at games but I have 500fps!
    AMD FX-8120 4429MHz 1.4v 24/7
    Gigabyte 990FXA-UD3
    Xigmatek Aegir cooler push/pull
    8GB Corsair Vengeance 2133MHz 9-9-9-24
    XFX 7950 Double D @ 1075/1375 1.085v 24/7
    Samsung 830 256GB SSD
    Fractal Arc Midi Case
    Novatech Black Edition 850W Modular PSU
  13. #12
    Oct 2005
    Austria
    0
    Quote Originally Posted by qcmadness View Post
    Yes, I saw it on the photo.
    So you just put the backplate on top of the SMD components on the back.
    Possible if you are careful: obviously yes
    A good idea: definitely not, especially if you want to use a better (heavier) cooler
  14. #13
    Apr 2008
    0
    Quote Originally Posted by SBB View Post
    Second photo
  15. #14
    Oct 2007
    Hong Kong
    3
    because isk-300 is limited in space, i cannot put any cooler which is bigger than 1u
  16. #15
    Nov 2008
    Lincoln, UK
    11
    What settings are you using to overclock? I bought one of these but im having no luck overclocking it
    Gigabyte 990FXA-UD3
  17. #16
    Nov 2008
    Lincoln, UK
    11
    ARGH now I have a black screen, and no POST, even after clearing the cmos and trying outside the case
    Gigabyte 990FXA-UD3
  18. #17
    Oct 2007
    Hong Kong
    3
    No OC...
  19. #18
    I am Xtreme BeepBeep2's Avatar
    Jan 2009
    Ohio
    361
    @SBB
    Who overclocks Llano in a Mini-ITX system? O_o
    I'd be undervolting the CPU and reducing power consumption by a large margin.
    Very nice build qcmadness
+ Reply to Thread
