As expected, complete annihilation for the 4100. Tests at max clocks for both should be interesting but my money is on the good old 955BE.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
This thread fails, in both the OP and many people who are replying. People should know by now that the new architecture was designed to have less performance at the same clock. Why is it then a "big surprise" to see it doing what it was intended?
Rig 1:
ASUS P8Z77-V
Intel i5 3570K @ 4.75GHz
16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
Nvidia GTX 670 4GB SLI
Rig 2:
Asus Sabertooth 990FX
AMD FX-8350 @ 5.6GHz
16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
AMD 6950 with 6970 bios flash
Yamakasi Catleap 2B overclocked to 120Hz refresh rate
Audio-GD FUN DAC unit w/ AD797BRZ opamps
Sennheiser PC350 headset w/ hero mod
Is it true AMD is going to EOL Phenoms and the X6's at end of this year?
BTW, Just noticed egg has em
AMD FX-4100 Zambezi @ NewwEgg $129.99
It's a "big surprise" because both the single thread performance and the multithread performance are lower than the previous generation, Phenom II and it seems that event than PH I(multithreasd).
And it's more disturbing because BD has larger cache, and a much better IMC almost on pair with Intel's Lynnfield,
i5 2500K@ 4.5Ghz
Asrock P67 PRO3
P55 PRO & i5 750
http://valid.canardpc.com/show_oc.php?id=966385
239 BCKL validation on cold air
http://valid.canardpc.com/show_oc.php?id=966536
Almost 5hgz , air.
Hold on buddy, nobody here seems to be surprised afaik, my reply even starts with: As expected...bla bla. It's just that these are the first benches most (including me) see done with a "4 core" Bulldozer cpu.
I can't see how this fails in any way.
I think we'd better be gratefull theoldtimer saved us buying this "thing" instead of calling it a fail.
Well AMD messed up marketing these things big time. When I read heavily about its uarch back in January, my first thought was..."damn I hope AMD markets the 2 module as a dual core, 3 module as a triple core and 4module as quad" because it would have a perceptibly better public image if they had done so.
Its obvious in its current design BD cores really hurt when sharing their shared parts of the pipeline, as shown in some tests done on this forum, actually when the shared cores are disabled and only 1 is enabled...the cores perform exceptionally! as seen in the post on this forum. Its when sharing kicks in that hampers the execution units badly. Someone should compare disabled "cores / module" (of a FX4100) against say a dual core stars, you will see single thread it does outshine stars. It should have been marketed as a true improvement over SMT not a catchup game to being a true 8 core processor.
Ugh AMD ... only if you would have done it differently.
The uarch can scale extremely well w/ clock speed, their next challenge is process refinement and bringing the power consumption as low as possible..basically the same thing the P4 was faced with. Lets hope this doesnt turn into another P4 =/
Right now it sure seems like one.
I think BD originally was targeted around 4+ghz base frequency and a 5ghz turbo w/ a lower power envelope but it didnt go as AMD had planned this time around.
Lian Li Black Mid Tower
PCP&C 500watt Silencer
Core i3 550 @ 4ghz 1.176v
4GB Gskill Ripjaws 1600 @ 1820mhz 8-9-8-24 1.59v
Asrock P55M-PRO
Scythe Mugen 2
ASUS HD6950 1GB @ 890mhz / 150mhz mem (for mining) | default clocks for gaming..
Razer Barracuda AC-1 sound card.
Pioneer 115D DVDRW
what would be the point of calling it a "dual" something if it is being sold for more money then the old gen (faster) quad core anyway?
it wouldn't look any better, it should have higher performance, or a lower price,
Well if it was a dual marketed processor, they could get away w/ a higher price than older dual cores because, it performs way beyond them. Thats the whole idea behind CMT but they tried to get away w/ marketing a CMT based uarch as "true cores" rather than not full cores. If they had said this new "core" has up to 160% more throughput than a traditional "core" then performance would be off the charts in most cases therefore would live up to its name and price.
For the case of thuban vs 8150...well the 8150 if marketed as a quadcore, would make it look better because .. for a hexcore comparison they should make a 6 module CPU =)
Asrock P55M-PRO
Scythe Mugen 2
Pioneer 115D DVDRW
I reinstalled the FX4100 this afternoon then looked in every part of the bios that I knew of for a way to unlock more modules/cores but I didn't find any setting for that. The ASRock motherboard is new to me though so if you know of an Fkey that will open up more bios setting I'm willing to give that a go? I can control the processor modules I have in bios though just nothing about enabling more that I can find. Sorry Royalk.
This does exist, there are cryo pumps for semiconductor fabricatin equipment, but use He. They phase change He to cool a cold plate to collect water vapor for faster pump downs or super low pump downs for vacum systems.
http://en.wikipedia.org/wiki/Cryopump
I believe there are also LN2 phase change systems also, but I don't know of any off the top of my head.
RussC
My Rig
PII955-C2 3.8GHz, 2.5MHz NB
GSkill 2x2GB DDR3-2400@900MHz
M4A87T Antec 900 Case, Custom Mods x5Fans
Custom Water Cooling: 15x12 3-Core Radiator
4xSunon 4.5W Fans, DD12V-D5 Laing Variable Pump
DD MC-TDX Water Block
700W OZC ModX Power Supply
GB HD6970OC2 Video Card
2x150GB Raptor Raid
I agree with this. It is more comparable to a dual core than a quad in actual design. AMD should have marketed it and priced it as such. The FX-8120/50 should have just been called quad cores with 8 threads as well. Unfortunately they're as power hungry as an 1100T (at much much higher clock speeds though).
I did try some max MHz runs using the ambient water cooling and one is a little faster than the one below but the settings and vcore are better in this one so I'll just post this one instead not that much difference in speed (5160MHz) anyway. I've tried a bunch of different settings along with vcore to 1.7v but this is about it for this chip at least under these test conditions.
I don't have anything that really works that well to clock it up in windows so all the overclocking is done in the bios and then of course it has to load windows.
Sorry to let everyone down along with AMD but this appears to be about as fast as I can get it to run under ambient water cooling. Maybe the only thing holding it back is me but I have not doubt my friend chew* could get it to run faster maybe a lot faster using ambient water cooling.
Strix X470-F, 1.2.0.6b | 5800X3D + Galahad 360, 3xP28 | 4x8GB Flare X 3200C14 @3200C14 1T+GDM | Strix 2070S A8G @1830/1750 | SB Z | SN750 500GB, MX500 1TB, DT01 2TB | O11D XL: 6xNB PL-2 | RM750
The Phenom II X4 965 sells for the same price ($129.99) on Newegg.com. AMD needs to call these things dual cores and quad cores QUICK!
I may try the FX4100 cold Dumo, I’m still trying to make up my mind. I needed to prove to myself what it would or wouldn’t do with room temp cooling before I moved on to cold or to another processor.
@ FlanK3r and Beep. Yeah the FX does like Winrar. In the chart below the 955be is running @4446MHz as before in the first post. The FX4100 is @4.5GHz or when shown as FX41-49+ it is the FX4100 running at 4977MHz.
~1~
AMD Ryzen 9 3900X
GigaByte X570 AORUS LITE
Trident-Z 3200 CL14 16GB
AMD Radeon VII
~2~
AMD Ryzen ThreadRipper 2950x
Asus Prime X399-A
GSkill Flare-X 3200mhz, CAS14, 64GB
AMD RX 5700 XT
Thanks charged for taking the time.
Could you try games with 2CU/4C vs. 2CU/2C vs. 1CU/2C "modes"? There are 9-11% difference between the last two (being 2CU/2C the better).
http://www.overclock.net/amd-general...ock-speed.html
Unfortunately, there are no tests with the stock 2CU/4C mode here. But perhaps some games would gain from running their threads "alone", especially those with two threads.
More info here.
