Has anyone seen this?
http://www.frozencpu.com/products/14...RADI180X3.html
Seems like a nice rad.
Dimension: 580 x 180 x 35 mm
(compared to SR-1 560mm: 605 x 153 x 55.9 mm)
width shouldn't be a problem, since almost all cases are wider than 180mm. As for length it is even slightly shorter than shortest 560, so should fit inside some cases where 4x140 barely didn't fit.
As for surface:
3x180 = 97200
4x140 = 78400
There are some nice 180mm fans already, for example from silverstone.
Also this rad seems perfect for LC in FT02, 2cm shorter than sr1, fits with buffer, can use stock fans, fact that it is slim, should not be a problem vs long gpu.
