Page 9 of 11 FirstFirst ... 67891011 LastLast
Results 201 to 225 of 275
Thread: Project "Little Angel": My return to water cooling!
  1. #201
    Dec 2008
    Jerusalem, Israel
    very nice progresses! keep it up.
    what you used to hook all the sleeving together?
    [SIGPIC][/SIGPIC]
    EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
    3X GTX580, Corsair AX1200, Lian Li PC-Z70
    3X Dell U2311H, Liliput 7" touchscreen monitor
  2. #202
    Mar 2008
    Quote Originally Posted by arkadur View Post
    Thank you!
    I used nylon thread
    Thanks to: - [ Aquatuning | Atlas Informática | NZXT | ProSilentPC | Seasonic | IzarMicro ] -
  3. #203
    Mar 2008
    More pics!
    I've decided to keep the GPU power cables like this:
    Final version? What do you think?
    Bottom radiators are connected via bitspower fittings, no tubing...
    Big Teaser
  4. #204
    Dec 2008
    Jerusalem, Israel
    this is the brass fittings? or the golden one?
    [SIGPIC][/SIGPIC]
  5. #205
    Mar 2008
    Hello arkadur.
    They are golden fittings
    I've sleeved the SATA cables, so time for new pictures.
    There you have a total of 7 SATA cables.
    4 are for the HDD's, 2 for SSD's and 1 for the DVD drive.
    My first option is to use this bitspower fittings as SLI link between the waterblocks.
    I decided to go paralel but I might change the bitspower fittings with the EK link if it looks better... I will have to wait when I test my loop before I decide which one I finally use.
    First real picture of how things are looking inside the Little Devil
    Bonus picture.
  6. #206
    Jan 2010
    Stunning, SoMBrA! I really like the fresh gold there!
    About the GPU's; the EK Link is big and bulky, but the Bitspower D-plugs are 1) much easier to remove/dismantle the whole thingy and 2) much more minimalistic and clean. Also it causes less angles and better flow (thou microscopic amounts?). Use the BP's!
    Exellent job on the wires/cables!
  7. #207
    Mar 2008
    Quote Originally Posted by Edited View Post
    Thank you Edited.
    I will keep the BP's then
    I've finished my 24pin cable!
    That was the last wiring + sleeving job that was left!
    I think It looks pretty
    Black VS White!
    I've been doing some test with white and black tubing and I would like to know what you guys think in order to make a final decision.
    I'm liking the black tubing option but still wanted to ask
    The problem I have with black tubing is that the wall is thinner than the black (even though both are Primochill Primoflex Pro...)
    Black VS White face to face...
    Which option you like the most? Thanks
  8. #208
    Jan 2009
    Awesome looking build.
    Regarding the black vs white combo, I would definitely drop the 3rd option out of the picture, but that's just me. Not sure which one of the first two is better though... Prolly the black one.
  9. #209
    Dec 2010
    Vienna - Austria
    I would prefer black.. it looks better. What about black Tygon?
    Intel i7 980X Sixcore - Gigabyte X58A-UD9 - 4x EVGA GTX 580 @ 4-Way SLI - Antec TruePower Quattro 1200 OC - Lian Li P80
  10. #210
    Nov 2010
    Brazil
    black tubing... looks fantastic with gold fittings
    PC:
    MOBO: Maximus VI Extreme
    CPU: Core i7-4770k
    RAM: 2x4gb Dominator Platinum 2133
    GPU: GeForce GTX Titan
    Greetings from Brazil!
  11. #211
    Nov 2008
    the white tubing seems to bring the gold fittings out more .
    But the black also looks nice....
  12. #212
    Jul 2011
    Lipetsk, Russia
    Black tubing is very nice
    i5 2500k @ 4.5ghz | Gigabyte Z68X-UD3P | 8Gb Mushkin 2000Mhz | Palit GTX470 | Aerocool 1000W | Aerocool X-Predator
    XSPC Raystorm | Koolance VID-NX470 | Coolgate 360 | D5 Vario + EK-D5 X-TOP v2 | PrimoFlex Pro LRT 16/10
  13. #213
    Mar 2008
    Quote Originally Posted by fr0wn3r View Post
    Quote Originally Posted by xFEARx3 View Post
    Quote Originally Posted by LeoAndrade View Post
    Quote Originally Posted by dietje1908 View Post
    Quote Originally Posted by Mefist0 View Post
    Thank you everyone for the feedback!
    I'm going with black tubing all the way, just want to make sure It doesn't kink!
    I was worried about black Tygon with the plasticizer problems some users experienced...
    I've tested black tubing against white led light and looks great... Will post more soon!
  14. #214
    Jan 2010
    I can't decide if I like black or white tubes the best. Hmm.
    Fantastic work!
    Proud owner of a Lian Li A05NB
    Hardware | Intel Core i5 2500K @ 4,2 GHz | ASUS Maximus IV Gene | XFX Radeon HD6970 XXX | Corsair AX 750 | Intel X25-M 80GB Gen.2 | Western Digital Black 2x1TB |
    Watercooling | EKWB Supreme HF Cu Nickel | EKWB FC-6970 Ni+Ac w/ black backplate | Swiftech MCP355 w/ Bitspower DDC Ultra Tank | TFC Xchanger 240 w/ pull Scythe GT AP-15 | Tygon R-3603 3/8ID, 1/2OD w/ Bitspower fittings and rotary adapters |
    Running Windows 7 Ultmate
  15. #215
    Hackintosh Lover
    Aug 2009
    Between London & Eastbourne, United Kingdom
    Looks amazing!! I prefer White tubes...
    Why Not Try a Hackintosh for A Change?? Steps HERE!!
    Want to installing Mountain/Lion from a DVD or USB on you Apple PC?? Steps Here!
    Super Stable aKa 24/7
    Winners of EURO 08 | World Cup 10 | EURO 12
    Quote: Killin' Tube Kinks One Coil At A Time
    Hackintosh Lover
    "Dumb people" shouldn't use "Smart Phones"
    New Personal Wallpapers Selection
  16. #216
    Nov 2009
    Without a doubt black tubing looks much better!
  17. #217
    Mar 2008
    Minor update!
    I just realized that to black tubing to work white led should be used to give some ambient light to the interior of the case.
    I will use this led strips mounted on a white PCB
    I will also use this alu profile so I can slide in the PCB (50~60cm) and give a nice touch to the whole setup.
    Led, profile and the cover, all together!
    I'm waiting for some stuff that I think I will recieve today, I will try to update tonight or tomorrow...
    Also I'm going to finish the setup of the led (wiring + sleeving) and connect them to the Aquaero 5
  18. #218
    Mar 2008
    So finally leds are installed and wires sleeved.
    Let me show you the result
    One of the strips was attached to the top of the case.
    This is a smaller version of the top bar, without the alu profile, that I installed at the back of where the hard disks are installed.
    You can see the light but no the led strip!
    From far...
    Zoomed!
  19. #219
    Jun 2012
    Greece - Athens
    Pure awesomeness at its best..! Cant get enough of your pictures!
  20. #220
    Jan 2010
    Love how the lightening looks! Good job!
  21. #221
    Mar 2008
    Quote Originally Posted by Pinwmpires View Post
    Thank you, I've also seen your work and it's plain great
    Thank you Edited... Not "much" work left to do, just missing some parts...
    I have good news, finally the bullets are GONE for ever (hopefully!)
    I'm really happy with my new motherboard block
    I'm very happy with the overall quality BUT I think the packaging was not good enough, you can see some damage on the mosfet block.... but it could be worse!
    Can't wait to put some nice fittings and start planing the loop
    More pics soon!
  22. #222
    Jan 2010
    Love BP's design and look, but I do agree on the packaging, it could have been alot better.
    What is left to do now, SoMBrA? A list plz ^^
    Regards
  23. #223
    Mar 2008
    Edited I will try to give you a list as soon as I know what is left to do
    I've already installed to blocks to the motherboard!
    Fittings added too, enjoy!
    Still planing the tubing route but I think I got it already... will update with final picture!
    I've shorten some tubes already, this was just for testing.
  24. #224
    Jun 2012
    Greece - Athens
    I love the tubing route.. do you plan on keeping it this way?
  25. #225
    Mar 2008
    Yes, I do, check "final" version!
Tags for this Thread
