Page 10 of 11 FirstFirst ... 7891011 LastLast
Results 226 to 250 of 275
Thread: Project "Little Angel": My return to water cooling!
  1. #226
    Jun 2012
    Greece - Athens
    Yeah.. its pretty much.. well.. awesome
  2. #227
    Mar 2008
    Thank you Pinwmpires!
    I did some work tonight, not the best picture so please forgive me!
    I was planing how to connect the top radiator to the Aquaero 5 since I bought the waterblock aswell... Loop is getting busy!
    I couldnt just "throw" a pipe down because other devices will interfere with the fittings / tubing so I had to reroute the loop outside the 5 1/2 "cage"
    My friend Michael inspired me with his holes for wire management! Thank you barfastic
    It was really hard to measure from the inside to make it a perfect straight "pipe"...
    Measurement was done from the inside but the hole must be done from the other side because my drill is way too big to do it from the inside!
    DONE, fingers crossed...
    Outside looks good, not sure if I was accurate enough...
    Just perfect!
    Very happy with the result!
    Now need to repeat the process at the Aquaero 5 bay...
    Done!
    Now I need to link the holes, I will build a bitspower bridge!
    More tomorrow
    Thanks to: - [ Aquatuning | Atlas Informática | NZXT | ProSilentPC | Seasonic | IzarMicro ] -
  3. #228
    Jan 2010
    BITSPOWER BRIDGE SOUND AWESOME! Need a cutout in the panel just for that, so everyone can see!
    Awesome work as usual. SoMBrA!
    Proud owner of a Lian Li A05NB
    Hardware | Intel Core i5 2500K @ 4,2 GHz | ASUS Maximus IV Gene | XFX Radeon HD6970 XXX | Corsair AX 750 | Intel X25-M 80GB Gen.2 | Western Digital Black 2x1TB |
    Watercooling | EKWB Supreme HF Cu Nickel | EKWB FC-6970 Ni+Ac w/ black backplate | Swiftech MCP355 w/ Bitspower DDC Ultra Tank | TFC Xchanger 240 w/ pull Scythe GT AP-15 | Tygon R-3603 3/8ID, 1/2OD w/ Bitspower fittings and rotary adapters |
    Running Windows 7 Ultmate
  4. #229
    Mar 2008
    Quote Originally Posted by Edited View Post
    Thanks Edited!
    Let me introduce you my bridge!
    Some fittings to make the bridge
    All together... now into the case
    Perfect fit!
    Now I need to link the bridge with the Aquaero 5...
    Will try to do that tomorrow!
  5. #230
    Jan 2010
    Holy fuggin batman thats neat!
  6. #231
    Mar 2008
    Thank you my friend!
    I'm following your work also but post some pictures soon!
  7. #232
    Xtreme Lurking Champion
    Jul 2009
    That does look very neat.
    But why not use Crystal Links? Might have been cheaper also? This might be my personal preference though, I like to see the liquid in the loop.
    Great work non the less, hope mine eventually turns out half as good!
  8. #233
    Mar 2008
    Quote Originally Posted by Acesi7 View Post
    I did not use Crystal Link because I did not have any hehe.
    Also I think Crystal links are very nice but if you plan to use Dye and I'm not...
    Good luck with your build, if you need any help you know where to find us!
    Update time:
    I've managed to hardpipe with bitspower fittings from the wall adapters to the Aquaero 5 waterblock
    Bitspower puzzles!
    Done!
    Finally I had to use some extra bitspower fittings as "spacers" because It was impossible to use 19/13 fittings (they were way too big and the waterblock screws were intefering)
    I think some crystal link to finish the connection would look good, but since I'm not using any dye I will stick to fitting + tubing to close the loop (from Aquaero 5 to the reservoir)
  9. #234
    Mar 2008
    I'm waiting for some critical parts to finish the build, while waiting I will show you how my EK reservoir is going to look...
    Golden stop fittings of course!
  10. #235
    Mar 2008
    Hello everyone!
    I have some updates!
    I planned this midplate long time ago and I already had it at home for almost 2 months but I couldn't use it because still had to measure where to fit the reservoir + pump + SSD's etc..
    Here is the first hole, this will help me to connect the pump + reservoir combo with the lower section
    First cut done, now planing how to connect the lower section with the top section again to continue with the loop.
    Also need to do some holes to allow GPU wires to connect to the graphic cards...
    More cutting for this evening!
  11. #236
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Very nice work all around and the bridge idea is great.
  12. #237
    Mar 2008
    Thank you theseeker!
    Midplate ready!
    Trying some fittings to see which ones fits better
    Midplate to radiator closeup pics
    Second bottom radiator has a flow meter and inline water temperature sensor!
    Tomorrow more!
  13. #238
    Jan 2008
    Bonnie Scotland / Sunny England
    Wetter than the fifty shades series
    I really need to finish unpacking and do mine
    PROJECT :: The Xtreme (WET) Dream!!!
    PERSONAL H2O BESTS :
    E8600 @ 4.8GHz
    E6750 @ 4GHz QX9650 @ 4.6GHz
    i7 920 @ 4.6GHz
    PERSONAL AIR BESTS :
    Sempron140 @ 4Ghz (Stock Cooler)
    i7 3960x @ 5.4ghz (Air Cooler)
    Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
    Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
    Swift_Wraith : "could someone please check bex for a penis?"
  14. #239
    Mar 2008
    Hey Bex, we are here waiting for your build!
    I hope to see some updates anytime soon!
    More pictures of one of the custom pieces I was waiting!
    Front
    Back
    Heatsink... what for?
    50mm fans connected in series
    Doing some tests with cables
    Sleeved!
    So this is the final design for the Dual 35x pedestal and I really love it!
    I plan to add a sensor between the pumps and the heatsink and see what temperature reading I get!
    More coming soon! :rock:
  15. #240
    Jan 2010
    Getting neater and neater! I'd love to have your budget roof lol!
    Good work, SoMBrA!
  16. #241
    Nov 2008
    sick I love your designs , kudos
  17. #242
    Mar 2008
    Good work, SoMBrA!
    Thank you Edited!
    Since this was a long term project it allowed me to spend some extra money hehe
    Quote Originally Posted by dietje1908 View Post
    Thanks diestje!
    Here is the last custom piece I ordered.
    I wanted a housing for my dual PSU starter so we decided to work on something unique, and after all the hard work and e-mails this is what he made, enjoy:
    I will put those holes you see there in a good use, I will show you later.
    This is the PCB that I will install inside the enclosure.
    Ready to be installed
    Installed!
    Ready to be connected!!
  18. #243
    Sep 2005
    Dublin, Ireland
    Hey could you link to the wire you used for the PSU you told me on the "other" forum but I couldn't see it anywhere =)
  19. #244
    editor22
    Guest
    Great to see it all coming together
  20. #245
    Mar 2008
    Hello Editor22, nice to see you around here
    I've just installed the PCB, hope you like it
    About the wire I bought it at chilledpc.co.uk long time ago
    The custom piece is fixed directly to the radiators (into the fan threads) and the rad sits on top of the two radiators.
    Those big holes are to allow tubing to pass and will help me to fix the tubing in place and avoid "dancing tubing" inside the case
    Here the connector and the extenders ready to recieve the tubing!
    The end is near, stay tuned! :rock:
  21. #246
    Jan 2010
    Fantastic way to route the tube! Stunned!
  22. #247
    Mar 2008
    Some more pictures while I have everything else ready:
    When you awake the little angel, this happens:
    I promise to post more pictures, all my pictures are teasers and I know lol
  23. #248
    Nov 2008
    And the awesomeness continues !! LOOKING GREAT
  24. #249
    Mar 2008
    Thanks my friend
    After so loooooooooooong and lots of hours and money I can say that Little Angel is almost finished, 90% that is, let me show you some picture before I show everything else but need to repaint some stuff
    Hope you like them as much as I did taking them
    Thanks for following the work, the end is near
  25. #250
    I am Xtreme
    Dec 2008
    France
    The last shots look incredible. Well done!
    Donate to XS forums
Tags for this Thread
