Actually, it's probably not all that extreme, but mehhh....it's my first (own) foray into SSD benchmarking.
Up for testing is a OCZ Vertex 3 240 GB SATA-3 SSD and an OCZ RevoDrive 3 240 GB PCIe x4 SSD.
Unfortunately, I don't have any other really newer systems that I can use for benchmarking (and my daily driver is occupied right now), so I had to use one of my older Socket F Opteron-based systems. So, that being said, that does NOT give it the full potential for these drives, BUT for relative and comparative purposes; it should be ok.
I'll know more once I start beating/kicking the crap out of it when I start running my FEA simulations on/with it.
Note:
I did NOT know that the Revodrive ONLY works with Windows 7 x86/x64. So, I have installed Windows 7 Ultimate x64 on a Hitachi 1 TB 7200 rpm SATA drive right now so that I can run the benchies/tests on the SSDs without the OS being ON said SSDs. I don't think that that makes a difference, but it's an important note, I think. Also, the Hitachi 1 TB is on the LSI1068E SAS 3Gbps controller, so I took it off the NFP3600 so that way the OS I/Os should be independent of the benching I/Os.
So that's the Vertex 3.
And here's the RevoDrive 3.
Two things:
1) Remember that the Vertex 3 240 GB SATA SSD is on a 3Gbps SATA-2 controller (I think). I forget if the NFP3600 is SATA-II or SATA-I. If it is just SATA-I, then the data rates that it's getting -- it's probably hitting the limits of it, so it isn't that surprising. I CAN put it on the SAS 3Gbps controller instead, but I wanted to make sure that I would be able to pass the TRIM command to them after testing because I know that the SAS controller won't.
2) The RevoDrive 3 240 GB PCIe x4 SSD card is designed with Gen2 PCIe slots in mind, but I think that my board is PCIe gen1 only, so it only gets half the theorectical bandwidth. (And it doesn't really matter that it's physically plugged into an x16 slot, despite the x4 connector).
So, again, the RevoDrive isn't tested to it's full potential either. But, you can see the huge difference. Even if the Vertex 3 is on SATA-3 6Gbps, it can only cap off at the 6 Gbps limit, while the RevoDrive 3 is already beyond that with a Gen1 PCIe slot.
Here's the h2benchw result for the Vertex 3. I LOVE this benchmark because it is the ONLY one that has a "swap" application/test profile which mimicks swap behavior and for me, that's a key/critical factor of performance. (Most poeple probably wouldn't really care, but when my record is a 90 GB swap file on a system with 128 GB of RAM; it matters. It matters GREATLY!)Capacity: CHS=(29185/255/63), 468857025 sectors = 228934 MByte
Interface transfer rate w/ block size 128 sectors at 0.0% of capacity:
Sequential read rate medium (w/out delay): 99516 KByte/s
Sequential transfer rate w/ read-ahead (delay: 0.71 ms): 110602 KByte/s
Repetitive sequential read ("core test"): 91401 KByte/s
Sequential write rate medium (w/out delay): 89806 KByte/s
Sequential transfer rate write cache (delay: 0.78 ms): 98928 KByte/s
Repetitive sequential write: 90594 KByte/s
Sustained transfer rate (block size: 128 sectors):
Reading: average 101811.4, min 98033.1, max 110715.8 [KByte/s]
Writing: average 90492.5, min 89426.0, max 92453.0 [KByte/s]
Random access read: average 0.24, min 0.14, max 0.36 [ms]
Random access write: average 0.26, min 0.15, max 2.52 [ms]
Random access read (<504 MByte): average 0.20, min 0.10, max 1.44 [ms]
Random access write (<504 MByte): average 0.19, min 0.07, max 0.90 [ms]
Application profile `swapping': 62307.9 KByte/s
Application profile `installing': 145727.0 KByte/s
Application profile `Word': 96627.1 KByte/s
Application profile `Photoshop': 95646.6 KByte/s
Application profile `copying': 142564.1 KByte/s
Application profile `F-Prot': 79350.6 KByte/s
Result: application index = 96.8
And here's the RevoDrive 3 h2benchw results. Interesting to note that despite it's HUGE sequential transfer rate (STR) advantage, when it comes to swap; it doesn't amount to much. An additional 15 MB/s, but the cost differential is about $100 or so at the time of purchase.Capacity: CHS=(29186/255/63), 468873090 sectors = 228942 MByte
Sequential read rate medium (w/out delay): 197683 KByte/s
Sequential transfer rate w/ read-ahead (delay: 0.36 ms): 217136 KByte/s
Repetitive sequential read ("core test"): 157648 KByte/s
Sequential write rate medium (w/out delay): 210014 KByte/s
Sequential transfer rate write cache (delay: 0.34 ms): 252936 KByte/s
Repetitive sequential write: 254520 KByte/s
Reading: average 189797.7, min 178997.9, max 212594.1 [KByte/s]
Writing: average 211219.4, min 206216.6, max 255300.0 [KByte/s]
Random access read: average 0.25, min 0.14, max 1.55 [ms]
Random access write: average 0.26, min 0.15, max 2.57 [ms]
Random access read (<504 MByte): average 0.24, min 0.10, max 2.65 [ms]
Random access write (<504 MByte): average 0.25, min 0.09, max 2.59 [ms]
Application profile `swapping': 78163.8 KByte/s
Application profile `installing': 232000.1 KByte/s
Application profile `Word': 197252.4 KByte/s
Application profile `Photoshop': 176655.2 KByte/s
Application profile `copying': 271686.0 KByte/s
Application profile `F-Prot': 102337.5 KByte/s
Result: application index = 157.5
Hopefully this info helps for those who might find it useful/good-to-know.
