Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Thread: "BATTLEFIELD 3" PC Case Mod
    Jul 2009
    Mnpctech.com
    Here is the "BF3" theme case mod in anticipation of Battlefield 3: BF3 release on 10.25.2011 by Electronic Arts. Fractal Design's Arc Mid tower case was chosen for the project.
    Fractal Design "Arc" Midi Tower Case.
    Fractal design Arc Mid tower fully dismantled for custom paint.
    The name badge in the bezel was filled with Evercoat's Everglass" Fiberglass "short hair" filler.
    After sanding the filler with Medium Grit sandpaper..
    Scuffing surface of steel chassis parts, plastic bezel with Red Scothbrite Pad, to create paint adhesion for the Primer.
    Dissected and Magnified each segment from camouflage pattern on 8.5" x 11" paper. Each segment was traced and cut in cardboard for individual stencils.
    RUSTOLEUM Specialty series "camouflage" paints. I purchased these from Home Depot
    Camouflage paint job is finished.
    Camouflaged motherboard tray? Yes, the entire interior was painted.
    For a rugged military look, we chose these recessed PC case handles, http://www.mnpctech.com/BlackRecessedHandle.html
    The recessed PC handles are ready for installation and spring loaded, so they don't flop while transporting your PC.
    Using stencil included with handles along with measuring square to determine exact location for the recessed PC handles
    Using 1.5" Dremel reinforced cutting wheel to cut opening for recessed PC handles
    Using 1/4" drill bit for mounting holes of the recessed handles.
    Cutting 3/16" thick aluminum Diamond Plate to use as accent plates for the handles.
    Khaki base coat applied to the Diamond Plate accent plates.
    Recessed PC handles and diamond plate installed and painted.
    and check out Mnpctech's new fan grill for 200mm / 230mm cooling fans, http://www.mnpctech.com/200mm_230mm_fan_grill.html
    Airbrushed effect of side panel being peeled back by <a Mnpctech custom painter, Brad Galvin.
    Brad's weapon of choice, Iwata's HP-CH airbrush gun.
    Glowing effect airbrushed on the BF3 Marine.
    Black outline airbrushed on BF3 Marine. A flat clear will be applied over the finished mural.
    with Brad's guidance, I airbrushed the bullet holes and scratched paint effects on the access panel. I started with the easy task of filling the BF3 stencil on the left side panel.
    To create bullet holes in http://www.mnpctech.com/acrylic_colo..._windows1.html
    #9901 Dremel Attachment, Tungsten Carbide Cutter for Engraving
    Using Dremel to create bullet holes...
    The illusion of bullet holes, created in the custom paint and made in the cast acrylic PC window sheet
    Just a few more details to take care of, then we can install the system!
    Apr 2008
    Singapore
    wow that is awesome!
    Intel Core i7 2600K @ 4.60GHz 1.42v
    ASUS Maximus IV Extreme w/ 3604 BIOS
    MSI N780GTX Lightning @ 1254/6502 w/ 331.40 BETA
    2x4GB G.Skill Ripjaws-X F3-12800CL7D-8GBXH @ 1600MHz 7-8-7-24-1T 1.6v
    Corsair AX1200 1200W
    Samsung 840 PRO 256GB SATA III (OS)
    Corsair Force GT 120GB SATA III (GAMES)
    Creative Sound Blaster Z w/ Corsair Vengeance 1300 Headphones
    Max Keyboard Durandal G1NL Red Backlit Mechanical Keyboard
    SteelSeries Sensei Fnatic Edition w/ Razer Goliathus Speed Edition (Large)
    ASUS VG278H
    Windows 8 Professional 64-bit
    Corsair Obsidian 800D
    EK Supreme HF Acetal/Nickel + XSPC RX240 w/ 2x GentleTyphoon AP-15 + XSPC X2O 750 Reservoir/Pump + PrimoChill PrimoFlex PRO LRT Tubing 1/2" ID, 3/4" OD + XSPC
    1/2" ID, 3/4" OD Compression Fittings
    Jan 2009
    Italia
    im cumming
    NooB MOD
    Jan 2006
    South Africa
    One word : WOW!
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    I am Xtreme
    Dec 2008
    France
    Outstanding! I especially like the airbrushed image job!
    Donate to XS forums
    NooB MOD
    Jan 2006
    South Africa
    Is there any small chance that you have a video of the airbrushing? It's crazy!
    Jan 2008
    Bonnie Scotland / Sunny England
    Om nom nom
    PROJECT :: The Xtreme (WET) Dream!!!
    PERSONAL H2O BESTS :
    E8600 @ 4.8GHz
    E6750 @ 4GHz QX9650 @ 4.6GHz
    i7 920 @ 4.6GHz
    PERSONAL AIR BESTS :
    Sempron140 @ 4Ghz (Stock Cooler)
    i7 3960x @ 5.4ghz (Air Cooler)
    Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
    Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
    Swift_Wraith : "could someone please check bex for a penis?"
    Dec 2007
    Texas
    Oh man, I'm in love!
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Xtreme Addict Evantaur's Avatar
    Jul 2011
    Finland
    simply awesome
    I like large posteriors and I cannot prevaricate
    Dec 2006
    Bravisimo!
    Intel I7 2600K @ 4800 MHZ | Corsair H80
    Asus Maximus IV Gene-Z
    16 GB Corsair Vengeance LP DDR3 1600
    eVga GTX 480
    Creative X-FI Titanium HD
    Crucial M4 128GB SSD | Crucial M4 64GB SSD| 1 TB Samsung F3
    Silverstone TJ08-E | Corsair AX850
    HEAT: http://heatware.com/eval.php?id=20134
    Apr 2011
    Texas
    it looks awesome
    Don't ever think you have the best rig, there's always better.
    Love will tear us apart
    Mar 2006
    wrigleyville.chi.il.us
    Nice work! Posted in the BF3 Clubhouse at TechPowerUp forums.
    Dark Star IV
    i5 3570K | Asrock Z77 Extreme4 | 8GB Samsung 30nm | GTX 670 FTW 4GB + XSPC Razer 680 | 128GB Samsung 830
    Apogee HD White | 140MM UT60/120MM UT45/120MM ST30 | XSPC D5 V2
    Feb 2009
    Nice work. It looks great!
    I am Xtreme
    Feb 2007
    Who is this project for?
    "Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
    Mar 2010
    I am Xtreme
    Feb 2007
    Quote Originally Posted by El Maño View Post
    better than the nooooooooooooooooooooooooooooo picture
    color red illidan's Avatar
    Mar 2005
    Bill great work!
  18. #18
    Oct 2008
    Nice work man...
    CPU: Q6600 MOBO: Maximus Formula RAM: 4gb VGA: 4850 HDD: C300 64gb TELA: 22" CASE: CM 690II Advanced | PSU: 750z-af
    Steam | Xfire | BFBC2
    www.hallaor.com
  19. #19
    Jul 2009
    Mnpctech.com
    Thanks for the comments guys!
    Painting the machined aluminum bullet thumbscrews to look more authentic.
    The surface is first prepped, using red scotch brite pad to scuff the bare aluminum
    Is that a "cribbage board" for thumbscrews?, drilling holes in a piece of wood, works great for holding thumbscrews for paint. The threads were taped off.
    For maximum paint adhesion, we use SEM brand self etching primer for the base coat
    A couple coats of grey self etching primer
    for holding the bullet thumbscrews, tape the bullet thumbscrews to paint stick
    Paint entire bullet first copper color first, mask off the tip after cured, then paint the shell brass color.
    After the paint has cured, I dry brushed the shells with "Antiquing Gel" by Home Decor. "Dry brushing" means you are painting with a brush that is almost 100% dry. It's an easy way to create a weathered effect or highlights. These are machined aluminum bullet thumbscrews
    After 2 hours, the "Antiquing Gel" had cured. The final coat is a "Flat" Clear coat aerosol paint by KRYLON
  20. #20
    Jan 2008
    Oooooooooooooooooooo-i-ooooooooooooooo!!!!!
    E8600 @ 4.8GHz
    i7 920 @ 4.6GHz
  21. #21
    Apr 2011
    Texas
    wow great job on the bullets, i cant wait to see this build complete
  22. #22
    Sep 2008
    Croatia
    beautiful
  23. #23
    Sep 2006
    Portugal
    F*ck*ng Awesome!!!!!!!!!!
    Love it!
  24. #24
    Jul 2009
    Mnpctech.com
    Thank you!!! More detailing ahead..
    I'm adding lil weathering beneath rack handles
    rack handles for bezel, give it more "field equipment" look
    I torn-up scotch-brite pads are great for adding blotchy or speckled paint effect..
    After I airbrushed over the Orange paint areas.... I also shaded over the "BF3" text...
    Ok, now it's Break time, Who is open at 11pm? hmm White Castle SLIDERS!
    We need more Billet Bullet Thumbscrews! these will be lodged in the window holes...
    More to Come.......
  25. #25
    Mar 2010
    Sweden
    That is one slick looking case, wow! Will there be a video of the case once its done?
    | Corsair Carbide Air 540 | Asus Sabertooth Z77 | Intel Core i7 3770K | 16GB G.Skill Sniper | Asus GeForce GTX Titan | 500GB Samsung 840 | Asus Xonar Essence STX | AOC G2460P 144Hz
