I need to pick up a 4GB kit of DDR2 for the second rig in my sig (OCZ is out for RMA), but I'm having some trouble deciphering the IC's in these 4GB kits. Most of the information on Ramlist seems to be from 2GB kits.
Anyways, from what's left of DDR2, which would you guys recommend to be the best?
Not necessarily looking to overclock, just want a good quality kit that I don't have to worry about crapping out. Here are the kits I'm looking at:
Wintec Ampx - http://www.newegg.com/Product/Produc...82E16820161183
Team Elite - http://www.newegg.com/Product/Produc...82E16820313076
Mushkin Silverline - http://www.newegg.com/Product/Produc...82E16820146692
HyperX - http://www.newegg.com/Product/Produc...82E16820104001
Typically I like G.Skill ram, but it's $60 and I really don't want to spend that much for DDR2. I'm open to other suggestions as well. Thank you.
