Results 1 to 25 of 25
Thread: [HELP] Unable to degrade my CPU !!
    I am Xtreme
    Jan 2005
    I need help!
    I've had this 2600K since march now and I just can't get it to degrade. I've ran this chip under ln2, with regular air cooling, air cooling without using any mounting gear. I gave it upto 1.75V, ran Vantage with it at high speeds and high voltage ... nothing seems to help. In fact, I did a public demo last weekend and I matched the same MHz like I did 7 months ago.
    Is my CPU undegradable?
    I think I will RMA this one because it can't degrade. Everywhere on the power user forums I read that CPUs are supposed to degrade over time, but this one just doesn't have this function!! WTF Intel?! I cannot believe they would do things like this. All CPUs should have the same function. Period!
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
    Xtreme Mentor
    Jun 2008
    France - Bx
    Shame on you Intel ...
    Jan 2009
    Italia
    are you joking?
    Sep 2008
    Croatia
    i haerd they will release "degrade DLC" next month
    Jan 2010
    Germany
    Awesome
    Quote Originally Posted by massman
    Using a mouse to adjust BIOS settings is like driving a car with automatic transmission. Even if you break all speed records, it's still incredibly gay.
    I am Xtreme
    Jan 2005
    Thanks for the support guys! I really can't believe this is happening to me .
    Quote Originally Posted by Andrea deluxe View Post
    are you joking?
    I knew from the moment I posted that people wouldn't believe my story. It's hard to believe stories that are posted on internet forums.
    But, no, I am not joking. This CPU just can't degrade. It's really frustrating to see so many people with perfectly degradable CPUs post about their adventures here and on other forums while I just sit here with no adventures at all. Hitting the same max clocks over and over again ...
    By the way, I have also tried running with only 1 core enabled as I read that was the key to success on some forums. But nope; still the same max frequency. FML.
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    List it on Ebay, but don't mention the whole truth about the chip, it's the only way to get rid of it
    you sigged that?
    why?
    ______
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    Serious, wtf? You are complaining because you have a RELIABLE, robust, piece of hardware? Your logic is unfathomable.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Dec 2008
    Jersey
    That is very unfortunate. Fortunately for me none of my chips have experienced this non-degradation. All of mine have degraded quite well.
    Jun 2005
    Glasgow-ish U.K.
    LOL PJ... I know a guy in Latvia who can help with problem CPUs like this one
    you sigged that?
    why?
    ______
    Jun 2007
    Quote Originally Posted by massman View Post
    ... I gave it upto 1.75V
    There's your problem right there, you need to give it 1.750001V for it to start degrading! :P
    Intel 6700K @ 4.3 GHz
    Gigabyte GA-Z170-HD3 DDR3
    4x4GB Corsair DDR3-2800
    GTX980Ti MSI Lightning
    Samsung 950 Pro 512GB
    4 x Intel 80GB x25-m SSD's RAID0
    Enermax Revolution 85+ 1250W
    Jun 2004
    ? I don't get this, you want a chip to degrade??? isn't that a bad thing? of course, correct me if I'm wrong or missed something here.
    Home PC: Intel i7 4770K @ 4.6ghz l Asus Maximus VI Hero l Corsair Dominator Plantinum 2400mhz (4x4GB) l Asus GTX 690 l Samsung 840 Pro 256gb l 2 x WD Black 1T storage drive l WD MyBook 500gb External l Samsung SH-S203N DVD l Creative X-Fi Titanium HD l Corsair AX1200 PSU l Planar SA2311W23 3D LCD Monitor l Corsair 800D Case l Windows 7 Ultimate 64 bit l Sennheiser HD-590
    Water Cooling Setup: Swiftech 320 Radiator (3 X Gentle Typhoons 1450rpm 3 x Gentle Typhoons 1850 rpm) l Swiftech Pump w/XSPC Res Top l Heatkiller 3.0 CPU Block l Heatkiller GPU-X GTX 690 "Hole Edition" Nickel l Heatkiller Geforce GTX 690 GPU Backplate l Koolance 140mm Radiator l Danger Den 1/2ID UV Green tubing l EK EKoolant UV Green Liquid
    -Impossible is not a word
    Technician
    Jun 2002
    Merseyside, UK
    I the have exact same problem. My old 2500k ran for literally months at 1.55v 5.1ghz heavily stressed and still does. What a POS! I ended up having to sell it instead. And you know what? My new one wont degrade at 5ghz 1.54v either, so I guess i'll have to sell that too rather than RMA it. This binning process is definitely not what I was led to believe. I was expecting one a week til I found a gem ffs!
    Dec 2007
    Earth
    LOL.. He's being sarcastic people!
    Although CPU's can/do degrade. I've experienced it with many. Not my SB yet but I expect it at some point.
    The type of degradation I have seen the most happens like this (speaking CPU's in general not just SB):
    System runs stable for weeks, months or years at some overclock lets say 4ghz. It then starts to fail, bumping voltage higher, or lowering clocks will bring it back to stable.
    The part that gets confusing to most is you can actually get it back to the original overclock after some time, but it will soon loose stability again.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Jan 2008
    just send it to me ... I think I can make it degrade for you
    Aug 2006
    Kalamazoo, MI
    I need help!
    <snip>
    Boy, am I glad I'm not you...
    XIP
    Nov 2004
    NYC
    Usually un-degrade-able cpu is also water/moisture proof...A drop of moisture on the socket probly will help it fly back to its maker
  18. #18
    Pie assassin
    Nov 2007
    Where lights collide
    9v > 1.75v
    Current Status - Testing & Research
  19. #19
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    5.5ghz on WCG for while
  20. #20
    Jan 2004
    North America
    Dude! get the hammer.
  21. #21
    Jan 2009
    Hell, this thread is a nominee for the best thread ever!
    Look it the other way, you have to admire it's will to survive. It's special!
  22. #22
    NooB MOD
    Jan 2006
    South Africa
    Quote Originally Posted by Ket View Post
    Your inability to detect sarcasm is unfathomable.
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
  23. #23
    Banned
    Jul 2004
    Scotland
    Glad you said it!
    (Beware he does not call you a Troll then report you!)
  24. #24
    Jan 2007
    uk
    Quote Originally Posted by PiLsY View Post
    Well can not understand this you should all be happy with these cpu that good,for me it would be like going into a shop and buying something defective and then say oh that was great must go get me another one.
    ASUS P8P67.rev3
    i5 2500k
    2x2 G Skill F3-17000CL9-2GBXL
    XFX Radeon HD 6870
    psu: corsair 600 watts
    creative xfi extreme music
  25. #25
    Sep 2007
    Coimbra - Portugal
    My personal experience:
    WC + Prime + 4.5Ghz + 2cores + 1.8v lcc xtreme = ( 20min ) = shutdown to never come back. Temps were hitting ~70ºC.
    But that 5.7Ghz 56x CPU ain't bad why would you want to send it back to his maker ? I would do that ona 54x or 53x...
