Ok so i have been a bit bored of the htpc section and thought id come spice things up a bit, cause im really bored OGM haha.
Anyway figure why not bring up a subject that could be relevant to our equipment and technology that we use today, so let the battle begin.... i mean discussion.
Preamps were designed in their original days as a first stage amplification as all or most sources were a low line level output of around 10mv and were amplified to a more acceptable voltage of 1v+, this would ensure that the Power amp which is the second stage amplification delivers the current sufficient enough for a acceptable output.
So the first stage and second stage phase were important for a sufficed power output, but this is not all that the preamp was made for, it has to also adjust the impedance to match with the power amplifier because the low level line output is not the same and can cause distortion so its important to match the signals as best as possible to avoid this. There are other things a preamp does but i dont think its relevant in this discussion as they are too minor.
So impedance matching how important do you think it is ?, do you think pre amps are still needed because of this requirement or should it be nothing to worry about (from a audiophiles perspective).
