Been having some great fun with this system the last week. Thought I'd post a few scores
System:
Tyan B8812F48W8HR
4 x 12 Core AMD Opteron 6168 processors (1.9 GHZ)
64GB Kingston DDR3 1333MHZ ECC RAM
8 x 600GB Seagate 15.700rpm SAS drives
LSI MegaRAID SAS 9261-8i RAI card
Windows 2008 Server R2 Enterprise Server
Unfortunately my graphics card doesn't even begin to do this system justice so no 3D testing
Node interleaving and NUMA and can have quite a big effect on performance in certain tests.
Some of the better results achieved are as follows:
Cinebench 11.5
Single CPU - 0.58 points
Multi-CPU (48 threads) - 23.94 points
MP Ratio - 41.64x
Best results were achieved with Node interleaving enabled (i.e. non Numa mode)
YCruncher 10 000 000 000 test (10 000 000 000 chart)
2,121.99 seconds
Again the best results were achieved in non Numa mode.
ECC memory mode also made a huge difference on some of the synthetic benchmarks like Sandra.
Sandra Memory Bandwidth
ECC mode - good
Numa disabled
Benchmark Results
Aggregate Memory Performance : 26.21GB/s (25.85GB/s - 26.21GB/s)
Integer B/F iSSE2 Memory Bandwidth : 26.17GB/s (25.85GB/s - 26.17GB/s)
Float B/F iSSE2 Memory Bandwidth : 26.25GB/s (25.86GB/s - 26.25GB/s)
Results Interpretation : Higher scores are better.
Performance vs. Speed
Aggregate Memory Performance : 20.12MB/s/MHz
Integer B/F iSSE2 Memory Bandwidth : 20.09MB/s/MHz
Float B/F iSSE2 Memory Bandwidth : 20.15MB/s/MHz
ECC mode - Good
Numa enabled
Benchmark Results
Aggregate Memory Performance : 59.63GB/s (47.68GB/s - 59.63GB/s)
Integer B/F iSSE2 Memory Bandwidth : 59.65GB/s (47.6GB/s - 59.65GB/s)
Float B/F iSSE2 Memory Bandwidth : 59.6GB/s (47.75GB/s - 59.6GB/s)
Aggregate Memory Performance : 45.77MB/s/MHz
Integer B/F iSSE2 Memory Bandwidth : 45.79MB/s/MHz
Float B/F iSSE2 Memory Bandwidth : 45.76MB/s/MHz
ECC mode - Basic
Numa enabled
Benchmark Results
Aggregate Memory Performance : 96.66GB/s (92.75GB/s - 96.66GB/s)
Integer B/F iSSE2 Memory Bandwidth : 96.62GB/s (92.38GB/s - 96.62GB/s)
Float B/F iSSE2 Memory Bandwidth : 96.71GB/s (93.13GB/s - 96.71GB/s)
Aggregate Memory Performance : 74.20MB/s/MHz
Integer B/F iSSE2 Memory Bandwidth : 74.16MB/s/MHz
Float B/F iSSE2 Memory Bandwidth : 74.24MB/s/MHz
Sandra Cache and Memory
ECC - Good
Numa enabled
Benchmark Results
Cache/Memory Bandwidth : 615.5GB/s (342.32GB/s - 615.5GB/s)
Speed Factor : 27.20
Results Interpretation : Lower scores are better.
Cache Information
Integrated Data Cache : 1.69TB/s
L2 Cache : 974GB/s
Cache/Memory Bandwidth : 331.73MB/s/MHz
Performance vs. Power
Processor(s)/Chipset(s)/Memory Power : 394.40W
Cache/Memory Bandwidth : 1598.08MB/s/W
iSSE2 Cache/Memory Results Breakdown
Data Item Size : 16bytes
Buffering Used : No
Offset Displacement : Yes
Detailed Benchmark Results
1kB Data Set : 1.71TB/s (547.2GB/s - 1.71TB/s)
4kB Data Set : 1.7TB/s (544.17GB/s - 1.7TB/s)
8kB Data Set : 1.7TB/s (804.13GB/s - 1.7TB/s)
16kB Data Set : 1.7TB/s (827.3GB/s - 1.7TB/s)
32kB Data Set : 1.71TB/s (793.31GB/s - 1.71TB/s)
64kB Data Set : 1.7TB/s (737.55GB/s - 1.7TB/s)
128kB Data Set : 1.72TB/s (697.3GB/s - 1.72TB/s)
256kB Data Set : 1.82TB/s (711.51GB/s - 1.82TB/s)
512kB Data Set : 1.6TB/s (716GB/s - 1.6TB/s)
1MB Data Set : 1.46TB/s (822.71GB/s - 1.46TB/s)
4MB Data Set : 1.25TB/s (718.17GB/s - 1.25TB/s)
16MB Data Set : 668GB/s (383.14GB/s - 668GB/s)
64MB Data Set : 252.33GB/s (212GB/s - 252.33GB/s)
256MB Data Set : 90.4GB/s (85.8GB/s - 90.4GB/s)
1GB Data Set : 89.66GB/s (82.39GB/s - 89.66GB/s)
4GB Data Set : 85.29GB/s (76.75GB/s - 85.29GB/s)
16GB Data Set : 68.39GB/s (62.33GB/s - 68.39GB/s)
Sandra Multi-Media
Benchmark Results
Aggregate Multi-Media Performance : 496.17MPix/s
Multi-Media Integer x16 iSSE2 : 392.42MPix/s
Multi-Media Float x8 iSSE2 : 627.34MPix/s
Multi-Media Double x4 iSSE2 : 345.18MPix/s
Benchmark Results
Aggregate Multi-Media Performance : 193GOPS
Multi-Media Integer x16 iSSE2 : 152.6GIPS
Multi-Media Float x8 iSSE2 : 244GFLOPS
Multi-Media Double x4 iSSE2 : 134.22GFLOPS
Sandra Processor Arithmetic
Benchmark Results
Aggregate Arithmetic Performance : 293.4GOPS
Dhrystone ALU : 333GIPS
Whetstone iSSE3 : 258.48GFLOPS
Aggregate Arithmetic Performance : 154.42MOPS/MHz
Dhrystone ALU : 175.28MIPS/MHz
Whetstone iSSE3 : 136.04MFLOPS/MHz
Processor(s) Power : 223.83W
Aggregate Arithmetic Performance : 1310.78MOPS/W
Dhrystone ALU : 1487.84MIPS/W
Whetstone iSSE3 : 1154.79MFLOPS/W
Sandra Crypto
Benchmark Results
Cryptographic Bandwidth : 4.24GB/s
AES256-ECB ALU Cryptographic Bandwidth : 4.45GB/s
SHA256 ALU Hashing Bandwidth : 4GB/s
AIDA64 Extreme Edition (Benchmark only detects 32 cores)
CPU Queen - 65515
CPU PhotoWorxx - 35265
CPU ZLib - 733.5 MB/s
CPU AES - 170024
CPU Hash - 10107 MB/s
FPU VP8 - 3649
FPU Julia - 38706
FPU Mandel - 19693
FPU SinJulia - 9838
Some fun screenshots
