I have verified compatability of the LSI 6GB sas expander used in a supermicro chasis. Here is what hw info on the cli lists:
Code:
# cli64 hw info
The Hardware Monitor Information
[Controller H/W Monitor]
CPU Temperature : 55 C
Controller Temp. : 39 C
CPU Fan : 3350 RPM
12V : 12.099 V
5V : 5.107 V
3.3V : 3.376 V
IO Voltage +1.8V : 1.856 V
DDR3 +1.5V : 1.552 V
CPU VCore +1.0V : 1.056 V
Analog +1.0V : 1.040 V
DDR3 +0.75V : 0.768 V
Battery Status : Not Installed
[Enclosure#1 : ARECA SAS RAID AdapterV1.0]
[Enclosure#2 : LSI CORPSAS2X36 0717]
5V : 5.030 V
12V : 11.920 V
Fan1 : 0 RPM
Fan2 : 0 RPM
Fan3 : 0 RPM
JBOD_Fan1 : 0 RPM
JBOD_Fan2 : 0 RPM
Power Supply 1 : FAILED
Power Supply 2 : FAILED
Temperature : 40 C
GuiErrMsg<0x00>: Success.
Code:
# cli64 vsf info
# Name Raid Name Level Capacity Ch/Id/Lun State
1 ARC-1882-VOL#000 Raid Set # 000 Raid6 80.0GB 00/00/00 Normal
2 ARC-1882-VOL#001 Raid Set # 000 Raid6 65920.0GB 00/00/01 Normal
Code:
# cli64 disk info
# Enc# Slot# ModelName Capacity Usage
1 01 Slot#1 N.A. 0.0GB N.A.
2 01 Slot#2 N.A. 0.0GB N.A.
3 01 Slot#3 N.A. 0.0GB N.A.
4 01 Slot#4 N.A. 0.0GB N.A.
5 01 Slot#5 N.A. 0.0GB N.A.
6 01 Slot#6 N.A. 0.0GB N.A.
7 01 Slot#7 N.A. 0.0GB N.A.
8 01 Slot#8 N.A. 0.0GB N.A.
9 02 Slot 01 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
10 02 Slot 02 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
11 02 Slot 03 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
12 02 Slot 04 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
13 02 Slot 05 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
14 02 Slot 06 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
15 02 Slot 07 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
16 02 Slot 08 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
17 02 Slot 09 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
18 02 Slot 10 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
19 02 Slot 11 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
20 02 Slot 12 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
21 02 Slot 13 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
22 02 Slot 14 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
23 02 Slot 15 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
24 02 Slot 16 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
25 02 Slot 17 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
26 02 Slot 18 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
27 02 Slot 19 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
28 02 Slot 20 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
29 02 Slot 21 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
30 02 Slot 22 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
31 02 Slot 23 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
32 02 Slot 24 Hitachi HUA723030ALA640 3000.6GB Raid Set # 000
This setup only showed a timeout error once and the disk later failed and has been fine sine then. It shows read/write speeds just around 2 gigabytes/sec. What your event history look like and hw info? I am thinking the expander is not really compatible or something.
