i may have talked my roommate into getting a router upgrade.
at present we have the highest possible tier (at least to my knowledge) generically available to standard consumers.
at present, again, we have the modem, a linksys 10/100 (standard router) and a 10/100/1000 linksys switch
we have 4 active PC's running, more or less non-stop. (soon to add in at least 1 more)
we have 3 phones that are also used on our wi-fi.
there are 3 (soon to be 4) WoW players, 1 heavy torrent'r and more or less typical use otherwise online.
i have an external drive.
~ from this drive there are 3 PC's that stream video from it within the home network.
~ it streams videos to others/family over the intar-weebs. (anywhere between 2 to 6 people (different locations across the USA)
~~ they watch the videos, download/upload random misc, pictures, videos, software, etc.
there are also 2 (sometimes 3) xbox live accounts playing online as well.
overall things run smoothly, but i seem to be getting the router to lock up. (seemingly at random) appears that this is happening more and more likely/common. a simple re-set (pull power, wait 10 seconds) then everything seems fine until it happens again.
there are also on occasion where th network lags up pretty bad as well.
hardware, special modem to allow for increased speeds.
standard linksys router
linksys switch, (capable of 10/100/1000)
now I am thinking of trying to get another router and rather than the norm, go for a gigabit.
i am somewhat limited on budget, but am willing to spend a bit more now and get something that will last and cover what is done, rather than get a 'just for now' fix.
to date i've been pretty much primarily linksys/cisco, but have had minimal experience with belkin and netgear. i've had bad luck in the past with d-link. never really had much, if any experience with other brands.
i would be ok with going with a different brand, but i have zero idea where to start.
i need suggestions on a gigabit router, preferably wireless capable and a minimum of 4 ports. as mentioned previously i've a switch i can run to for extra wired connections.
price tag, i would like to stick to somewhere between $50 to $125, obviously the lower the better, but i am a firm believer in you get what you pay for.
hopefully i didn't blabber too much but gave you the info needed to be able to answer any possible questions, but am sure i missed something.
(oh, as a note, i am aware for the PC to be able to use the full capabilities it would need a 10/100/1000 ethernet on each PC. i know 1 or 2 of the PC's have that onboard, while the others i am unsure. i've been told an intel nic may be best for that aspect.)
any suggestions on appropriate routers/nics would be appreciated to.
Tons of thanks appreciated for any assistance!
