Although a lot of people have turned into a Sandy Bridge system,there are even more left with the 1366 socket platform witch is still the high end platform of Intel.After the discontinue of Elpida Hyper chips,finding a good overclocking triple channel memory kit is not easy.
When KINGSTON send me this kit,I looked around for overclocking reviews and the best results I found was 2000Mhz at stock timings. Without high hopes on overclocking potential I started pushing the modules.Soon enough I was surprised finding out that this kit that costs only about 140€ here in Greece,has so much to give.
I want to thank KINGSTON and HWBOX for supplying this memory kit.
Let's see some results.
2000Mhz@stock timings without added vdimm was easy.
2000Mhz@7-9-7-24 reached also at default vdimm.
Maxing out at 2024Mhz@7-9-7-24.Extra voltage didn't help @trcd9
Changing the trcd from 9 to 10 aloud me to feed the modules with extra voltage and take off in the frequency scale.
2200Mhz@7-10-7-27 with 1.72vdimm
Maxing out at 2212Mhz@7-10-7-27
Loosing the timings @9-12-9-31 and adding a little bit extra vdimm,the memory started flying
2400Mhz@9-12-9-31 1.76vdimm
Maxing out at2466Mhz@9-12-9-31 way beyond the rated speeds.
At this point(and a little bit earlier) I felt that my 980's IMC was having a hard time,so I decided to mount my cascade and make him feel a little better,so I could squeeze every last Mhz this amazing kit had to give.
Cooling the IMC alluded me to to reach the magic number of 2500Mhz
2502Mhz@9-12-9-31
