No, this is precut to max length of 30mm. See our installation guide here. Typical tubing length to link MCW82 to Bridge is ~40mm
Fitting: link removed
CC
Upper and lower ports: yes, definitely.
CC
CEO Swiftech
Hmm, ~ 40mm .. won't four from these + four from these fit instead of fittings/tubing?
Or if D-fitting's quick disconnect joint is preferred to rotary one, then four of these + four of these.
Of course, price might get higher then that of 8 barbs + it might be a little bit less leak safe. And better looks of "hard tubing" might be lost behind SLI bridge. And because of smaller ID of those extenders it might be tiny bit more resistive to flow. Crap, i see only drawbacks.
Ok, let's budget this in details:
Recommended "soft" Linkage for a standard SLI/CF setup:
MCW82 already includes 1/2" barb fittings. Cost = 0
1/2" Barb fittings: (2 pairs at $5 each): $10.00
Worm-Drive Hose clamps (8) needed @ $.73 each: $5.8
Tubing 1/2' - Cost $1.00
Total linkage cost: $16.80 + shipping
Hard Linkage with After market parts:
4x extenders at $6 each = $24
4x Male/Male adapters @ $9 each = $36
Total linkage cost: $60 + shipping
For a show machine, hard linkage will look cool, but functionally tubes + barbs are hands down best bang for the buck.
CEO Swiftech
