* SILVERSTONE TJ 11 W.C. By MR. YAKUZA *
* This project will be updated as we receive the components. *
COMPONENTS OF LIQUID COOLING
* SILVERSTONE TJ11
* AX1200 CORSAIR
* EK Dominator Ram - Plexi / Nickel EN
* HF Aquacomputer kryos Cuplex
* FB EK-EK waterblocks RE3 - Acetal / Nickel
* Bitspower Black Freezer VG-NGTX580 x2
* EK D5 DUAL TOP 2 LOOPS
* Laing D5 Vario 12v (Swiftech MCP655) x2
* Lamptron Touch Sleevings Cables
* BlackIce 240 SR1
* BlackIce 480 SR1
* Nidecs GT 1850 rpm x6
* SilverStone FF101 Grille x6
* EK-EK waterblocks Multioption RES X2 - 250 Advanced
* Additive Red Mayhems
* Transparent Tygon 19/13 x3
* Prolimatech PK-1 x2
* Scythe Bay Adapter 3.5 to 5.25 HDD Rafter
* Velcro-Danger Den D5 ( 3M ) x7
* Carbon Vinyl 3M x2
* Silver KillCoil
* 5-Way AlphaCool Collector HF G1 / 4 Deep Black x2
* Adapter 1 / 4 IG G1 / 4 BLACK MATE Rotable 90º Bitspower
* Bitspower Compression Fitting 19/13mm MATE BLACK x15
* Plug 45 º G1 / 4 Bitspower MATE BLACK x10
* Q Adapter Bitspower MATE BLACK x4
* Adapter 45 º Bitspower MATE BLACK x4
* Plug Bitspower G1 / 4 MATE BLACK x10
* Stand Phobya 4x120mm Radiator
* Stand Phobya 2x120mm Radiator
* BitFenix 24-pin ATX Extension Cable 30cm Black
* BitFenix 12v 8-pin EPS Extension Cable Black x2
* BitFenix 6-pin VGA Extension Cable Black PCI Express x2
* Bitfenix VGA 8-pin PCI Express Extension Cable Black x2
* BitFenix Adapter 3-pin Black 90cm x6
* BitFenix Adapter 3-pin Black 60cm
* BitFenix x4 SATA 20cm Molex Adapter Black
* Nzxt Sata cable 4 in 1 20cm
* ColdZero P-Clip 16mm (Pack 10)
* ColdZero P-Clip 19mm (Pack 10)
* ColdZero P-Clip 3mm (Pack 10)
* ColdZero P-Clip 6mm (Pack 10)
* ColdZero P-Clip 9mm (Pack 10)
POSSIBLE SKETCH
The hardware to use is the same as I have in my signature.
