+ Reply to Thread
Results 1 to 20 of 20
Thread: Add 2 PSU review - $20 PSU expansion
    Xtreme Addict Mats's Avatar
    Aug 2004
    Sweden
    17
    The module is extremely easy to use. First you grab a spare 4pin Molex lead from your existing PSU and plug it into the Add2PSU module.
    Next plug the 20pin or 24pin main power lead from the secondary PSU into the module. Finally mount the module in your case and route cables as needed.
    When the main system turns on the power will activate the relay and prompt the secondary PSU to activate.
    http://www.ninjalane.com/reviews/modding/add2psu
    Xtreme Addict Vinas's Avatar
    Jan 2007
    Michigan
    38
    Yup that's pretty cool, and simple. But we already have cables that do this... And relays can fail over time, so unfortunately this is already obsolete me thinks.
    Core i7 860 / Apogee XT/960mm rads, 16GB G.Skill Ripjaw X, dual ATi 5870 EK fc [Cu] blocks & bk plates, Panworld PX-40 pump, PPC 1200w TurboCool, 2 INTEL x25m & 1 OCZ Agility III 240GB SSDs
    Intel 4.5GHz LinX Stable Club
    Aug 2004
    Sweden
    17
    WE know.
    Xtreme X.I.P. The Coolest's Avatar
    Jun 2002
    Tel Aviv, Israel
    26
    And that looks pretty expensive for a PCB, relay and a couple of connectors...
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    Core i7 2600K 3.4GHz @ 4.5GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / Storage: Crucial M4 128GB (+ HDDs) / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 4GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Secondary rig:
    Core i3 540 3.06GHz @ Stock / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: FSP ATX350-PNR 350W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
    Xtreme Mentor Utnorris's Avatar
    Sep 2007
    Dallas
    11
    I saw this the other night on Frozencpu. I like it better than the traditional PSU adapters since this can be mounted where the secondary PSU is sitting. Twice as much as the other ones, but it is pretty slick.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    c[_] STEvil's Avatar
    Nov 2002
    Alberta, Canada
    20
    None yet that allow combining of PSU's....
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    YouTube Addict nn_step's Avatar
    Aug 2005
    Klaatu barada nikto
    2
    ultimately a useless feature, since the largest power draw is not the hard or disc drives but rather the graphics card and the CPU and this solution does not correct that problem.
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
    Aug 2004
    Sweden
    17
    Quote Originally Posted by nn_step View Post
    What are you talking about? What does hard drives got to do with it?
    It allows you to use a second PSU for graphics cards or whatever you like (except using two PSU's connected to one 24-pin ATX connector on a motherboard, which I wouldn't do anyway ).
    Aug 2005
    Klaatu barada nikto
    2
    Quote Originally Posted by Mats View Post
    If you use it for the graphics card and there is a voltage difference between the 12v the first and second PSUs provide, you can fry the graphics card. Hence I was speaking of the devices which it could actually power, without risk of being fried.
    Xtreme Member Darth_Penguin's Avatar
    Oct 2007
    1
    Since I dont know the answer to this I have to ask. Why do 2 separate video cards needs the same voltage to run without risk of "frying"?
    Corsair 700D
    Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Zotac GTX480|Intel x-25-M 80GB x 2 / Raid0
    H2O
    |Perfecting the Obsidian series case. Build log to follow soon...|
    Aug 2005
    Klaatu barada nikto
    2
    Quote Originally Posted by Darth_Penguin View Post
    I believe that you parsed my sentence incorrectly.
    the 24 pin of PSU #1 provides 12v to all PCIe cards
    the 6/8 pin connectors of PSU #2 which when connected to a graphics card may not be at the same voltage as what was provided by PSU #1 to the PCIe cards.
    Hopefully that clears up your confusion
    Xtreme Enthusiast defect9's Avatar
    Feb 2009
    Carson City, NV
    21
    isn't that what the vregs on both the mobo and cards are for, to not just smooth, but regulate the power to the proper voltage for optimum operation?
    i7 2600k, 8GB 1866Mhz DDR3, GTX560 Ti, Gigabyte Z68XP-UD4, CM Cosmos 1000 Case, and some green crap everywhere.
    Quote Originally Posted by Alexandr0s View Post
    So you're saying I could use my own pee as coolant?
    Nov 2002
    Alberta, Canada
    20
    Quote Originally Posted by defect9 View Post
    To the cpu/core/ram/etc, yes, but that doesnt separate the rails as they dont connect through the VRM, but rather before the VRM... if they do. Its not really an issue as the rail separation is pretty good these days after the earlier blunders of "multiple-rail" psu's.
    Xtreme Addict god_43's Avatar
    Jan 2009
    28
    Quote Originally Posted by STEvil View Post
    what about the 8 pin connector at the top of the motherboard? would we need an adapter cable for that as well; if we were to use two psu's?
    [MOBO] Asus CrossHair Formula 5 AM3+
    [GPU] ATI 6970 x2 Crossfire 2Gb
    [RAM] G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 1600
    [CPU] AMD FX-8120 @ 4.8 ghz
    [COOLER] XSPC Rasa 750 RS360 WaterCooling
    [OS] Windows 8 x64 Enterprise
    [HDD] OCZ Vertex 3 120GB SSD
    [AUDIO] Logitech S-220 17 Watts 2.1
    Nov 2002
    Alberta, Canada
    20
    depends on how things were set up..
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (HotWeather)
    103
    hmmm not interesting
    i5-2500K + Asus P8P67 Deluxe + Mushkin Blackline 8GB - 2133C10 (Hynix BFR) + Asus HD7970 DirectCU2 TOP + Samsung S22A300B
    EK SupremeHF + EK VGA HF + Swiftech 655 + XSPC ResTop + BlackIce GTX360 + LamptronFC2 + NMB-MAT 130CFMx3 Antec 1200W OC Version
    Compaq CQ20 / Lenovo Y450 / Note II / Tab Plus / iPhone 5 / iPad 3
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120
    Xtreme Enthusiast Humminn55's Avatar
    Dec 2008
    3
    I've seen just such setups used for years by more than a few people (PS#1 supplying everything with power except the PCI-e cables and PS#2 supplying just the PCI-e cables to the gpus), and have never heard of rampant numbers of video cards frying.
  18. #18
    Jan 2009
    28
    Quote Originally Posted by Humminn55 View Post
    lol well i was about to make such a setup myself...but i think i will spend the 9.99 for the adapter cable just to be safe.
  19. #19
    Xtreme Enthusiast owikh84's Avatar
    Dec 2008
    MALAYSIA
    122
    Quote Originally Posted by Vinas View Post
    My TJ07 comes with this 24pins splitter cable in the box.
    RAM: DomP 2800C11 2X4 + TridentX 2800C11 2X4 + TridentX 2666C10 2X4 + Team 2600C10 4X4 + RipZ 2400C9-11-10 4X4 + Flare 2000C7 2X2 + Pi 2200C7 2X2 + RipX 2133C8 6X2 + GTX4 3X2GB + KVR 1333C9 2X2
    3770K @ 5.0 | MVE WC | 3x 7970 WC | 2x M4 256 raid0 + 2x WD 1TB + ST 2TB | AX1200 | Z5500 + Xonar D2X | U3011 | LD V8 || WC: 2-loop | EK HF + EK M5E + 3x D5 EK Dual Top + EK-TOP + 2x EK 250 X2 Adv + 3x 480 Rads | 3x EK FC7970 | 16x GT | Primo Blood Red
    3770K @ 5.0 | MVE | 2x M4 128 | AX1200 | Dimastech EasyDual v2.5 | U2312HM || WC: HF + D5 EK Top + EK X2 250 Res + 2x RX360 + 12x GT | EK FC7970 | Arqtik Quad TEC
    i7 920 D0 4.5 GHz, 2150Mhz 8-8-8-24-1T, EVGA E760 | 4.4 GHz, 2100MHz 7-7-7-20-1T, EVGA E760 | 4.557GHz, 2170Mhz 8-8-8-24-1T, EVGA E760| i7 920 D0 4.5GHz, 2150MHz 8-8-8-24-1T, R3E
    XS Successful Trades:
    G.Skill RipjawsZ 2400C9 4X4GB - sold to easegantini | G.Skill RipjawsX 2133C8 2X2GB - bought from Dumo | 2600K 57X - bought from newhit | 3770K 6750 - bought from Viss | 3770K 6750 - sold to Sniper | 3770K IMC 2800+ - bought from Dumo | G.Skill Pi 2200C7 - bought from websmile | 3770K IMC 2933+ - bought from Viss | DomGT 2kC7 3X2GB - sold to _AntLionBR_ | G.Skill Pi 2133C8 - bought from websmile | DomP 2800C11 - bought from Alex-Ro | Pi 2000C7 - bought from websmile | GTX4 + KVR 1333C9 - bought from TaPaKaH
  20. #20
    Xtreme Addict SexyMF's Avatar
    Nov 2005
    Auckland, New Zealand
    5
    As long as your 0V point from each PSU is tied together then you are ok. This is done via the GPU power sockets anyway.
    The ability to parallel up PSU's depends on the circuit of the SMPS.
+ Reply to Thread
