now public, only leviathon-nz and me in xtremesystems team ?
http://www.dailytech.com/CERN+Invite...ticle22388.htm
It needs Virtualbox for linux and boinc.
http://lhcathome.web.cern.ch/LHCathome/Physics/
lets crunch some atoms boys !
Phenom II x6 1055T | ASRock 880G Ex.3 | 560Ti FrozrII 1GB| Corsair Vengeance 1600 2x4GB | Win7 64 | M4 128GB
VR Box - i5 6600 | MSI Mortar | Gigabyte G1 GTX 1060 | Viper 16GB DDR4 2400 | 256 SSD | Oculus Rift CV1 + Touch
Joined.
People, be warned, it downloads 220MB WUs and BOINC saya it requires 7629.39 MB of disk space, strangely, it uses a lot less for me atm.
Sadly, for now, it's single-threaded.
Sometimes a good slap in the face is all you need
Bios my arss.....
I can fix this problem with a hardware mod.... Hipro5
"Overclock till death. Overclocking is life." Hipro5
I might have to give this a try
This project is crunching the real results of experiments run at LHC!
So I decided to finally take this project for a test drive ... interesting ... downloaded and install VirtualBox and then join the project like any other BOINC project.
There is a wrapper that initializes the VM, pulls the WU through BOINC and then runs it on the VM all while syncing through BOINC.
Current beta version of the wrapper is only running 1 WU but using 2 cores, I'm sure they'll have if fixed soon.
when this gets multi threaded it will rock.. I love CERNs work..they do awesome stuff..
Work/Gaming: i7-950|GB X58A-UD7|12GB Trident BBSE/XMS3|460GTX|WD 1TB BLK|Pioneer DVDRW|CM HAF-X|Win 7 Pro 64 bit|U2711|HX850|G500|G510
Heatware: jimba86
Bench:Custom Giga-bench|Win 7/XP SP3|WD 36GB Raptor|Dell 22|AX1200|MS intellimouse
Bench 1:i7 930|water 2.0 performer|Gigabyte X58A-OC | 4GB corsair 1866 CL7|GTX 295 Quad SLI
Bench 2:E8500|NHD14|P45-UD3P(2nd PCIEx16 slot broken.. )|2GB Corsair 8888 Cl4|GTX 260 SOC
(Bench 3: In Progress) 4770K|F1EE|Gigabyte Z97X-SOC Force| 4GB GTX1 /8GB Gskill TridentX 2666CL11 ney pro|5870 x3 on KPC tek9 slim 5.0/7.0
Bench 4 E8600|NHD14|REX|2GB Corsair 1800 Cl7|Asus GTX 280
Bench 5 (TBC): FX?|990FX-UD7|Gskill Flare 2000 Cl7|6970
Server/renderbox: G3258|TT Water 2.0|Gigabyte Z87 Sniper M5|8GB Gskill Sniper 2133|gigabyte 5750|FD NODE 804
