Results 1 to 20 of 20
Thread: Help! XP won't load.
    Xtreme Cruncher
    Dec 2008
    Los Angeles/Hong Kong
    So I force restarted my ancient XP laptop a while ago.
    After booting, it proceeded into the advanced options menu, the one that lets you go into Safe Mode.
    The weird thing is, all the letters are in strange fonts. After I select a boot mode, the laptop would restart itself halfway through the boot screen, causing in indefinite cycle.
    Can anyone help me with this? The laptop has loads of precious data in it and I really don't want to lose it.
    Team XS: xs4s.org
    Xtreme Cruncher
    Dec 2008
    Basically, the laptop will encounter a BSOD during the splash screen, causing in infinite loop of restarting.
    Team XS: xs4s.org
    Jun 2008
    Tokyo, Japan
    Use Ubuntu Live CD to Backup Files from Your Dead Windows Computer
    One of the easiest methods to access your data is to simply boot off an Ubuntu Live CD
    http://www.howtogeek.com/howto/windo...dows-computer/
    Xtreme Cruncher
    Dec 2008
    So there's no way of fixing it?
    Team XS: xs4s.org
    I am Xtreme
    Aug 2008
    or ubuntu on usb, i have this for work purposes
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Save the files first, then, set about sorting out the windows problem. Just in case the process messes the drive even more
    Then
    Buy a portable drive to back up your stuff!!!
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    Oct 2007
    Mid UK. Lift a few rocks, eventually you will find me.
    Back up the files as advised, then attempt a repair with a windows CD.
    Fun Box: Asus P8Z68-V GEN3++Corsair AX850++i5 2500k@4.5Ghz-1.272v++Corsair A50++2x8Gb Corsair Vengeance++MSI R7970 Lightning++Audigy2 Plat-EX++TBS 6280 DVB-T2 tuner++256Gb OCZ Vertex 4.500Gb Caviar Black.500Gb Seagate Barracuda++Sony AD7240s++Lian-Li PC-60++Linux Mint/Win 7++Asus P238Q
    Work Box: Gigabyte H61MA-DV3++Corsair HX620++i5 3450@stock++2x8Gb Corsair Vengeance++120Gb OCZ Agility 3++Linux Mint
    Quantum theory in a nutshell: It's so small we don't know where it is, it could be here, it could be there.
    Just 'cos it's legal don't make it right.
    Xtreme Cruncher
    Dec 2008
    Seems like the laptop does not support booting from my external drive...
    What now?
    Team XS: xs4s.org
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Remove drive and hook it up to desktop, You may need an adapter, copy the important stuff off onto the external drive.
    or if you fancy an adventure...
    run the laptop off an ubuntu cd ( or stick as Hondacity mentioned) and do it all in linux. You might want to talk to poppageek and DA (among others) on this
    Xtreme Cruncher
    Dec 2008
    Nahh, I don't think I can handle Linux..
    Might sound a bit stupid, but does a laptop drive plug into an IDE adapter? It is fairly old, from around 2005.
    Team XS: xs4s.org
    Xtreme Cruncher
    Oct 2006
    Kansas
    to stop the loop: Press f8 right before the windows splash screen, or advanced start-up options screen in this case. Disable Automatic Restart on Failure. It will proceed to try to boot. Read BSOD, figure out problem, boot happily or reinstall windows!
    But yes, backup the data in a manner already suggested above!
    Black Ultra Aluminus case
    Intel Q6600 @3.6ghz
    Abit IP35 Pro
    4GB Corsair XMS2
    XFX Radeon 5770
    1TB Samsung F3 (boot)
    Windows 7 Pro
    Watercooling: Swiftech GTZ, 320QP with yates, D5 and Black PrimoFlex LRT tubing
    6+ years and still running strong!! Not the most Xtreme anymore, but ya gotta do what the budget says ya gotta do!
    Jun 2008
    Tokyo, Japan
    Quote Originally Posted by lkiller123 View Post
    Yes there are laptop drives that are IDE, you will need a 2.5" to 3.5" Hard Drive Bay Adapter if you have a 2.5 drive and you wish to slave it to desktop machine that has IDE.
    something like this
    http://www.newegg.com/Product/Produc...82E16812203012
    Jun 2008
    Tokyo, Japan
    You could try this
    How to Perform a Windows XP Repair Install
    http://www.michaelstevenstech.com/XPrepairinstall.htm
    Xtreme Cruncher
    Dec 2008
    Wow, thanks for the advice everyone.
    Jbartlett, I've tried it, but as I said on the OP, there are still unreadable characters when I reach the boot options screen.
    dctokyo, does this work? http://www.amazon.com/External-Enclo...2825882&sr=8-1
    I'm kinda thinking about using plugging that in to my computer and then repairing it with a XP CD. Would that work?
    Team XS: xs4s.org
    Jun 2008
    Tokyo, Japan
    Hi lkiller123, it should work as the one that I posted before, you should be able to see your data on the drive, but you will not be able to repair the HDD unless it is set to a boot drive.
    Did you check to see if your BIOS supports booting to a external CD/DVD drive? If it does, then you need to set the boot priority to have the laptop to boot from the CD/DVD first.
    Xtreme Cruncher
    Dec 2008
    I did check the laptop's BIOS: no luck.
    I've just order the enclosure, I will see how it goes.
    Thanks for the help so far mate!!
    Team XS: xs4s.org
    Apr 2010
    In a world beyong borders
    If you take the risk, disassemble the laptop and remove the RAM and battery for a short time.
    SAINT19
    Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
    Max overclock archived, 1090T @ 6.5GHz
    Phenom II X6 1090T BE @ 3.8GHz and NB @ 3000MHz both with 1.325V on BIOS
    Gigabyte 890FXA-UD5 Rev. 2.0 with F4 BIOS
    Crucial Ballistix Tracer 4GB (2x2GB) DDR3 1600 8-8-8-21-1T
    MSI GTX 680 Lightning 2GB
    Corsair Force GT 120GB SSD + Hitachi 2x500GB HDD
    EK Supreme HF Full Nickel + MCP655-D5 + MCR320-QP
  18. #18
    Mar 2009
    In a van down by the river
    If none of the above works (surely one of the tips will) the hard drive dock with IDE will allow you to recover data but when my oldest computer died and I had forgotten the password the data was unavailable in Windows. Had to use Linux to recover emails, invoices etc.
  19. #19
    Xtreme Cruncher
    Dec 2008
    Adapter came, and seems like the drive is shot...
    Which disk recovery software would you guys recommend?
    Team XS: xs4s.org
  20. #20
    Apr 2010
    EASEUS data recovery is very good
    Sent from my Android using TapaTalk
    SAINT19
