Results 1 to 16 of 16
Thread: Thinking of starting some mining...
    Mar 2008
    As above really, heard about it a while back, had a quick go on me 4870X2, but kept giving failed work units (or whatever they're called) and I couldn't be bothered to look into it
    However, I've started playing eve, and apparently you can pay in bitcoins, and I'm upgrading 2 pcs gpus anyways, so thought might aswell get some which can mine, what would you guys recommend?
    Looking at a £300 ish budget
    One PC is my LAN rig, so only has a 450W SFF PSU, so may be limited in what cards it can run, other has 750W so shouldn't have an issue regarding cards.
    Been looking at picking up some 583/5/70s?
    Or should I look at a 6xxx?
    Does memory make a difference (will I see any difference between a 6950 1gb and 2gb?)
    Edit:
    Obviously I'd still like it to be a gpu upgrade for gaming etc (not a massive upgrade, but certainly not less powerful)
    The LAN PC currently has a 4850, and my main a GTX260.
    Jun 2009
    New Jersey
    Here is a list of cards and what they can do and for the dollar amount. https://en.bitcoin.it/wiki/Mining_hardware_comparison
    I think the best bang for your buck is the 5830 or the 5850 depending if you can still find some. If not the 6950/6970 would be better but you are also jumping up 100$.
    Memory has no effect on bitcoin mining. Actually must of us down clock the memory to run at a slower speed like 300-350 mhz to cut back on electric and heat from the cards.
    Main Rig
    Gigabyte z78x-OC Bios F5n
    i7-4770k batch L310B492 Malay @ 4.5ghz with HT 1.2v
    Samsung Green 8GB 2x4GB MV-3V4G3D/US DDR3 1.3v 30nn
    HiS ATI HD 6950
    Corsair Force GT 120 GB Sata3 SSD (boot drive) on Intel sata3 controller port0
    Samsung 320GB HD322GJ 7200 RPM 16M cache on Intel sata3 controller port1
    Sony Optiarc DVD-RW AD-7240S on Intel sata3 controller port4
    CORSAIR CMPSU-850TX PSU
    Swiftech MCP655-B Pump
    EK Suppreme HF Cpu Block
    Swiftech Mcres Micro Rev 2 Reservoir
    Black Ice GTX Xtreme 360 Radiator
    Server
    HAF 932
    Gigabyte z77x-UD3H F13
    i7-3770S batch 3212B621 supports VT-D and low power
    32GB 4x8gb Muskin Enhanced Blackline 10-10-10-27@1.65v
    Vmware vSphere ESXi 5.0u1
    4x500GB Hitachi Deskstar 7K1000.D Raid 10 on a IBM M1015 <- DataStore
    Sapphire HD 5850
    Mar 2008
    Yeah I've been looking at that, prices aren't that comparable sadly to the UK, new 5850s go for around £160, and even 2nd hand ones are more pricey than £100 (equiv of 161usd)
    Am tempted to just go all out and get 2 6950s for my main PC, and then a 5870 for my LAN one. But tis a fair amount of monies :/ (looking at £500ish)
    Mar 2009
    ATL/CLE/YYZ
    Since you're upgrading, I'd go with 6xxx series cards... they'd be best for gaming. That being said, now's not a great time to be getting into bitcoin. The exchange rate is pretty deflated and the difficulty is quite high. Currently, a 6970 will make about 0.2 BTC a day. After electrical and factoring in that you can't mine while gaming, I'd say you wouldn't be making a significant amount to justify the heat and noise.
    XS WCG: Voiding warranties for a good cause. Join us!
    Mar 2008
    Heat/noise isn't an issue whatsoever, just thought it would be good if I could make any money whatsoever, but now I'm not so sure :/
    Mar 2008
    Another question:
    Could I have a 5850/5770 in the LAN pc
    Then a 5870 and a 6950 in the main? Using the 6950 for mining/gaming, then the 5870 just for mining?
    And what PSU would you recommend for a 5870+6950 / 2x6950 combo?
    Got a 750W CoolerMaster atm, which I think should be fine
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    I ran a pair of 5870's on a corsair tx750 OK before I spread things around a bit. Not sure how the coolermaster compares
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    Mar 2008
    Ok cool thanks.
    I'm not worried about running 2 cards, only about running 3/how the mining works with 2 different cards (6950 and 5870)
    Although it's not looking like I'll put the 5870 in the LAN box, then 1 6950 in my main, with a potential upgrade in the form of another 6950 a little bit later (depending how the mining goes)
    Mar 2008
    Just a bit of an update.
    Got a 1gb 6950 and a 5870
    Currently running the 6950 in my main PC, tis mining at around 320mhash
    5870 is in my LAN rig, need to look into mining for linux though, any guides for a non guiminer way?
    Thinking of picking up another 6950 for my main PC (for around £130-140) although not sure how the heat will be, considering having to run the card at stock, with 100% fan, and is sitting at around 70 :/ Seems to be pulling 420W (with a 920 @ 4.2)
    No idea if this will all be worth it, but will be fun giving it a go
    Xtreme Cruncher
    Jan 2009
    Glad to see that there are new people coming despite recent market fluctuations
    SB 2600K
    MSI P67A-GD65
    8GB 1600/CL8
    GTX580
    64GB SSD
    4TB
    Xonar DX
    BeQuiet Straight Power 680W sleeved
    in
    Cosmos 1000, modded
    TC PA120.3+XSPC RX240mm+XSPC RASA+DDC1T+OCLabs top+EK Multioption 150+ EK-FC580
    Mar 2008
    Yeah, well, was planning a gpu upgrade anywho, and so thought I'd switch (atleast for a bit) from crunching F@H to this.
    Having major performance issues with linux though, although don't know if that's because it's linux, or because it's ati (getting no performance increase going from a 4850 to a 5870/6950 :P)
    Xtreme Cruncher
    Jan 2009
    The issue must be the way how you set it up
    This may help:
    https://bitcointalk.org/index.php?PH...a&topic=7514.0
    SB 2600K
    MSI P67A-GD65
    8GB 1600/CL8
    GTX580
    64GB SSD
    4TB
    Xonar DX
    in
    Cosmos 1000, modded
    Mar 2008
    Gave up on linux, since couldn't get satisfactory performance in wine regardless (tis my LAN PC) so just shoved XP on there.
    Now getting 7-800 MHash/s
    With the looks to get another 6950 for the main PC, which I won't run in crossfire, so that when I want to game, I can just stop the one miner
    May have to upgrade me PSU though (or swap it around with the more powerful 850W silverstone in the family PC which they got since I couldn't be bothered to take mine out at the time :P) due to number of connectors, since I don't like using molex>>6pin adaptors.
    Jun 2005
    Or if you want to game while mining, just put the miner on lowest priority (aggression), and see if works
    Mar 2008
    OOh, haven't seen that, linky to more details?
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    choose a lower number of AGGRESION parameter if using phoenix (phatk) or higher -f parameter if using m0mchil (pobclm)
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
