Short Intro
So, I had the opportunity to test the two kits from the new GeIL memory line-up: Enhance Corsa and Evo Corsa. First up, the more mainstream Enhance Corsa kit, which comes in the following flavours:
- 1333MHz CL9-9-9-24, 2GBx2 Dual Channel Kit | GEC34GB1333C9DC
- 1333MHz CL9-9-9-24, 4GBx2 Dual Channel Kit | GEC38GB1333C9DC
- 1600MHz CL9-9-9-28, 2GBx2 Dual Channel Kit | GEC34GB1600C9DC
- 1600MHz CL9-9-9-28, 4GBx2 Dual Channel Kit | GEC38GB1600C9DC
- 1333MHz CL9-9-9-24, 2GBx4 Quad Channel Kit | GEC38GB1333C9QC
- 1333MHz CL9-9-9-24, 4GBx4 Quad Channel Kit | GEC316GB1333C9QC
- 1600MHz CL9-9-9-28, 2GBx4 Quad Channel Kit | GEC38GB1600C9QC
- 1600MHz CL9-9-9-28, 4GBx4 Quad Channel Kit | GEC316GB1600C9QC
Pictures of Box and Kit
Test Setup
Nothing special about the test setup. Just a normal Sandy Bridge build.
- Core i7 2600k
- GIGABYTE GA-P67A-UD5-B3(*)
- Coolermaster Silent Pro 1000W
- WD Raptor
- Windows 7 64-bit SP0
- Y-Cruncher
- SuperPI 32M
(*) overvolts 0.02-0.03V on Vdimm from BIOS.
OC Overview Chart
Overview of OC test results. Stability was tested with full SuperPI-32M run at ~ 4.8GHz and then verified with a round of Y-Cruncher (0,1,6). Overall, not much difference between both benchmarks: it either worked or it didn't. As for voltage affecting this kit's overclocking capabilities, it seems that the sweetspot is around 1.5V-1.55V. As you can see from the report, sometimes increasing the voltage made the kit more unstable.
Max Results
Given the results above, I didn't spend that much time pushing the memory to it's maximum. In the end, I reached DDR3-1720 CL9-9-9 SuperPI-32M stable, probably limited by the BCLK of this CPU.
[hwbot=2195091]submission[/hwbot]
Conclusive Lines
This kit is quite clearly designed with only the price and looks in mind. I kind of like the looks, but as the French say "Des goûts et des couleurs, on ne discute pas" (meaning as much as it's not possible to discuss about taste and colors). So, the looks are totally up to you to decide. In terms of performance, this kit seems to be on par with all the other kits in the same price category (~ 52/55 €), this kit being slightly cheaper. But, this depends from region to region. In other words, this kit will do just fine if you're looking for a cheap 2x 4GB kit!
