I'm building my first chiller. I've built a few single stages, so I have some experience, but chiller is a bit different. I'm using Teco 5.3k btu rotary, 1.3kw luve condenser, 10 plate heat exchanger. As expansion valve, I'm using two 0.8mm captubes, each is 150cm long, refrigerant is pure R507.
My question is what pressures I should expect, when unit will be loaded using 550W tea heater (I can't find photos with manifolds anywhere on this forum). So far, I have about -25C liquid temp idle, but on 550W it's +2C, and pressures are 17 barg discharge, 2.2barg suction. Unit seems to be undercharged (suction accumulator isn't cold), but It may be caused by bad vacuum, I'm almost sure, that there is some air in unit which makes my pressures so high. But before I charge it once again, I'd like to know roughly what can I expect. Maybe captube is a bit too long, I have no idea. Help will be appreciated
