X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 4 of 4
Thread: Alphacool Cape Cora 1042 Radiator Review
    Xtreme Supporter
    Apr 2011
    Devon UK
    by Dark Mantis
    A rather inovative product from Alphacool here this time. Instead of the usual old black radiator that has a couple of fans
    bolted to it to help cool it down this is a purely passive design. It is made from anodised aluminium tubing extrusions which
    incorporate many fins externally to help make the cooling surface area much greater.
    It consists of a modular construction and so in theory any size is achievable. The 1042 comprises 10 of these aluminium
    extrusions as the main parts. To enable a comfortable fit on the outside of my case I only used nine but they seemed to perform
    as well anyway and certainly looked more the part. The kit has a very accurate and clear instruction manual which is aimed mainly
    at construction and fitting. I should point out that when constructing it a little bit of silicon grease or something like that
    does ease the insertion of the fittings with the o-rings attached into the tubes.
    These ally tubes are each 420 mm long with an internal diameter of 12 mm. Running through the centre of each tube is a restrictor, a
    piece of solid rod, to stop too much liquid from running through each tube and also to make sure that the actual cooling surface
    (the outside) contacts more of the hot water.
    Alphacool uses small spring clips made of steel to hold the units together especially until permanent fixing is enabled. There is
    one at each end and they seem to be sufficient as a temporary fixing. Supplied are a number of modular connectors made from a
    dense black plastic material which have double O rings on each connection point.They are T- shaped and the smaller part inserts
    into the aluminium tube just by push fit. There is one top and bottom. these then join together longtitudinally to make an array.
    Included in the kit are metal end connectors which fit by the same method and seals. These enable any normal 1/4" BSPP connector
    to be screwed in to finish the job. There are two blanks ends and two for barbs or for whatever fitting you prefer.
    The kits come in either Black or Silver anodised finish which also helps stop corrosion. It might be worth stating here however
    that a protective additive would be prudent to be added to the coolant liquid to stop galvanic corrosion.
    Once the kit is finished being assembled it should be permanently attached to something solid. I used the outside of my system
    case.The cooling towers are already pre drilled to take the included screws. As mentioned in the beginning this is purely passive
    by design which makes it also totally silent, another bonus. Obviously fans could be fixed to the matrix if even more performance
    was required.
    Wherever you choose to locate it you need to make sure that there is an adequate free airflow not stuck next to a wall or
    something similar. As long as there is sufficient airflow around the radiator it seems to work very well even though it is
    passive and not helped by any fans. I had it attached to my Gigabyte GA-P67A-UD5 with an Intel i5 2500K and 16 GB of Corsair
    Vengeance memory and proceeded to run Prime95 for over an hour with a maximum temperture in the low 50C. The temperature before I started
    was already 30C so I think that the radiator performed very well.
    There are a couple of downsides. One of which is that the construction is aluminium and the connections are only push fit
    although fairly tight. I did manage to blow one off when filling but that was using a higher pressure than would be normally
    encountered in use. On the positive side it is silent, a big plus, and efficient. For such a seemingly large device it isn't too
    greedy when it comes to filling with coolant, which is something to consider if you like to use some of these expensive mixtures.
    I had no trouble purging the air from the system but I was using a high powered pump the Alphacool VPP 655 along with the Cape
    Cora Bullseye reservoir. My system took around a litre of coolant to fill it.
    I like the look of it and it was certainly more attractive than the standard black radiator. It is not cheap at 119.95€ but
    probably no more than a similar sized standard unit. There is also the added benefit that it is totally customisable. You can
    make the finished article any size you want.
    I would award this radiator kit 8/10.
    Supplier: Alphacool
    Official Gigabyte UK Forum Moderator
    Jul 2010
    Birmingham, United Kingdom
    I was very interested all the way till the point that you said it was made from aluminium all the way though
    If it was a copper pipe with aluminium over the top then thats fine but pure aluminium is a complete no no.
    Xtreme Supporter
    Apr 2011
    Devon UK
    Yes I know and that was my first thought when I encountered it. However it is totally anodised which, at least in theory, should alleviate the corrosion aspect.
    Mar 2005
    even alumunium i still believe this was an alternative for cooling down the oc thing, and don't forget corrosion aspect
    Ghz Was Not Everything.......
