Just to double check, will the current selection of aftermarket DDC tops fit a DDC2, or have there been significant enough changes in impeller design etc, that a top designed for the 3.2 won't fit the 2?
Thanks.
EDIT: After a bit of research, turns out the DDC2's impeller was larger. I wonder how this affects current top performance, which have smaller inlets to match the smaller impellers.
