I am considering a redesign of my evaporator but am concerned with the ability to reliably bend 1/2" coil to fit inside a 5.875" ID pipe. So I was considering splitting the evaporator into two identically sized coils at 3/8" for easier coiling around a smaller radius. I would use two separate coils of exactly 10' in tubing length and split after the TXV using a distributor.
Is this a viable option given appropriate design?
