I can't believe no one mentioned the logo!
It is very nice, clean and simple, and this is coming from a graphic designer.
[SIGPIC][/SIGPIC]
i3 530 @ 4.2 ghz, evga FTW, 4 gig gskill trident @ 1600 6-8-6-24, XFX 4870 1gb, corsair 620hx, 2 x kinston 64gig ssd raid0, 300 gig Velociraptor, 2Tb WD green,
Tagan black pearl (lian-li v2000)
Water: mcp655, mcr320 with ultra kazes, GTZ, mcr60, micro-res,
black primochill, bitspower comp. fittings
I need clear!!! :-) Is the second picture clear or uv blue?
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
no 1/4" ID, 3/8" OD love again
Hey
Any News on a uk suplier?
Really Would love a pack :P
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
PROJECT :: The Xtreme (WET) Dream!!!
PERSONAL H2O BESTS :
E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.6GHz i7 920 @ 4.6GHz
PERSONAL AIR BESTS :
Sempron140 @ 4Ghz (Stock Cooler) i7 3960x @ 5.4ghz (Air Cooler)
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
Wow, that looks great. Although, since my fittings cost way to much money, I won't be switching from 7/16 id / 5/8 od.. even though my tubing should be thicker.. 3/16th thick tubing... but it looks great. Even better turns than lrt. If they start making 7/16.. i'll buy for sure.
All I use and recommend is 7/16" ID / 11/16" OD Tygon. Fits so much more securely than 1/2" ID on 1/2" fittings, regardless of clamp style. On 1/2" tubing it's way too easy to tighten a clamp around one of the barbs on a barbed fitting and have it slip between the barbs, generating a leak. I used to use two herbie clamps per fitting on soft 1/2" tubing but 7/16" does the job so much better.
3/16" wall is fine if your loop has graceful bends, or if you use 45/90 degree fittings, which I don't like to use in high flow loops, so I prefer the 1/8" wall.
WS
Actually 7/16 id 5/8 od is 3/32 inch wall thickness, ie thinner than 1/8 inch thickness of 3/8id 5/8od and 7/16 id 11/16 od. (Wall thickness is OD-ID x 1/2, since measuring width whole tubing, ie walls measured twice), chart. 1/8 inch thick is what you want for tight bends without kinking, I dont like anything thinner, but just my preference, and typically you wont find anything thicker in tubing sizes we use.
Awesome looking tubing, I will be getting the 3/8id 5/8od (1/8 inch thick) for my next build, and I assume this stuff is plasticizer free since for water cooling.
Asus Crosshair IV Extreme
AMD FX-8350
AMD ref. HD 6950 2Gb x 2
4x4Gb HyperX T1
Corsair AX1200
3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
The DF "picture" is a logo done by Rocky and is not to show the wall thickness or bend radius...it's just the logo that is on the package. The wall thickness is the industry standard 1/8" or 3mm. If I altered the wall thickness all the different brands of barbs and compressions on the market would not fit and everyone would be mad at me 0.o
Before someone posts to tell me that 1/8" wall thickness is not the ONLY standard I meant the standard for the heavy wall variety of course. The 1/16" will also be coming to market. There will also be a tube and cutter only kit, a barbs and clamps in a six or 8 pack kit, and a new compression fitting I designed in a 6 or 8 pack kit that I hope will bring down the price of compressions a little as a "bulk" type buy for builders.
Little update. Checked the tracking and it shows arrival in Portland at Danger Den Friday August 19th. US Resellers (Performance PC's and Frozen CPU etc.) Should have it by about August 26th.
I still have some of the original Primochill Nightmare Flex around here somewhere . . . .man that stuff sucked hard. Worst water-cooling tubing evar
"Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
that damned stuff that was the consistency of gummy worms. Back before Primochill filed bankruptcy at Voyeur Mods when Danger Den used to sell their tubing and coolants. Knowing the history of different companies and their relationships makes this new product stuff fun to watch from the sidelines . . .
Behave now
More choices is good for modding and makes everyone elevate their products and designs.
That reminds me. While I was developing Dream Flex I ended up testing hundreds of feet of PVC tubing and one thing I for sure would like to improve on is that PVC smell. I have scented tube all ready to go but the consensus was that the market might not like that. By scented I mean a very mild and pleasant scent like bubblegum for the blue tube, strawberry for the red etc. Not super strong like a car freshener type smell. You would have to get pretty close to the tube to even smell it--the point is more that it does not have that PVC shower curtain smell. Spent a month getting the black to have a nice coffee bean smell and got vetoed at the very end.
So what do you guys think about lightly scented tube to get rid of the PVC smell? I might add it to a little of the next run as a sort of market test if there is any interest.
See...I guess that is why I got vetoed lol. My thinking was if it does not add any cost to the tube to make it not smell like a PVC shower curtain why not? The question I got was "what if the customer doesn't like the smell however slight of strawberries or bubblegum or w/e?".
Does this stuff scale (turn white on the inside) over time? How long?
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
"Artificial intelligence is no match for natural stupidity."
It is anti-microbial so if your not running "hard" water there should never be any scaling I would think.
