Hi guys,
I bought Mountain Mods U2-UFO case , and i would like to share with you some pictures ,
The good think with Mountain Mods that, you can modify the left, right, front, back and top panels, also you can select between full tower or square cases.
For me i select U2-UFO which is 18"x18" because it has a big space inside with excellent air flow.
The case delivered totally dis-assembly without instructions or sketch, but it was very easy to assembly.
These are the left, right and top panels
these are the front and back panels
these are the base and motherboard tray and the horizon brace and the 5 x 5.25 inch optical drive cage
I make some holes in the MT for the cables
These are the Screws and wheels
And after 10 minutes the case finish
more pictures tomorrow , i have to go to work now
