As title I'm interested in how you guys know all is good. With folding gpu it would just fail if I went too high but this??
I only have 2 cards with voltage control if that is important...the others seem to have that blanked out in overdrive
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
From what I have seen with my own cards. The 6950 has voltage control while my 5850 does not. Either card acts the same. If the clocks are unstable the system will lock up. Some times if your lucky the display driver will just crash and you can try again. Also you may notice that your MHash/s will be more stable less fluctuation. The best my 5850 will do is 820 on the core. The 6950 will do 910 @ 1.212v.
My 6950 is also my daily use system. I have only ran into a few websites that I have to stop mining if I want to view them. Other wise the system locks up.
Main Rig
Gigabyte z78x-OC Bios F5n
i7-4770k batch L310B492 Malay @ 4.5ghz with HT 1.2v
Samsung Green 8GB 2x4GB MV-3V4G3D/US DDR3 1.3v 30nn
HiS ATI HD 6950
Corsair Force GT 120 GB Sata3 SSD (boot drive) on Intel sata3 controller port0
Samsung 320GB HD322GJ 7200 RPM 16M cache on Intel sata3 controller port1
Sony Optiarc DVD-RW AD-7240S on Intel sata3 controller port4
CORSAIR CMPSU-850TX PSU
Swiftech MCP655-B Pump
EK Suppreme HF Cpu Block
Swiftech Mcres Micro Rev 2 Reservoir
Black Ice GTX Xtreme 360 Radiator
Server
HAF 932
Gigabyte z77x-UD3H F13
i7-3770S batch 3212B621 supports VT-D and low power
32GB 4x8gb Muskin Enhanced Blackline 10-10-10-27@1.65v
Vmware vSphere ESXi 5.0u1
4x500GB Hitachi Deskstar 7K1000.D Raid 10 on a IBM M1015 <- DataStore
Sapphire HD 5850
I noticed that the display drivers fail and restart when not stable. So I just backed down to a comfortable level
Also concerning overclocking.. I think temperature correlates with reject rates. I don't know though if this is memory or core related.
I see nobody has mentioned stale/fail rates..... anyone noticed a connection?
By upping the voltage on a gtx465, I was able to reduce the stale/fail rates from 10% at 750mhz to 1% at 820mhz. Same temps and memory speed (with a higher fan speed of course).
