Results 1 to 10 of 10
Thread: Core i7 920 Progress
    May 2005
    Here is my Overclocking journey for my Core i7 920 thus far. My Vdimm is set to 1.6V and my VTT to 1.3V... Here are some results:
    3.8Ghz (181x21)
    1.35625V (Vcore)
    1.30V (VTT)
    Stable for 75 runs using LinX
    Temp: 77, 75, 73, 71
    4.0Ghz (191x21)
    1.35625V (Vcore)
    1.30V (VTT)
    Temp: 78, 77, 73, 71
    Since I reached my goal of 4.0Ghz, I began to drastically lower the Vcore.. With all settings remained the same as above, I began to use:
    1.3375V Vcore
    Stable for 75 runs of LinX
    Temp: 77, 75, 74, 71
    1.330V Vcore
    Stable for 75 runs of Linx
    Temp: 74, 72, 72, 68
    As you can see, the temperature began to decrease as Vcore decreased. So I continued to reduce my Vcore (and soon VTT once I find a stable Vcore) to determine my lowest limit:
    At 1.275V Vcore, I get a BSOD (One that i couldnt find in the guides. Something like 0x000009C) when running LinX
    At 1.28125V Vcore, LinX detects an error at 1hr 41 mins.
    At 1.28125V Vcore and 1.35V VTT, I get the same BSOD as above, but much quicker.
    So I guess bumping up the VTT didn't help, so I increased the VTT to 1.281750V and Im continuing to run LinX.
    1. Any suggestions at this point? Im not sure what the usual Vcore would be for 4.0Ghz. Mind you, I still havent touched the CPU PLL or IOH Voltage and Im not sure what this should be set to. Bios reads 1.10v for CPU PLL.
    2. Would lowering the multiplier to 19x and using 210 blck to achieve the same 4Ghz help to reduce the vcore needed?
    Thanks for your help!
    Core i7 920 D0 Stepping (Coolermaster Hyper 212)
    EVGA X58 3-SLI (132-BL-E758-A1)
    Corsair XMS3 Dominator 6GB (8-8-8-24)
    Corsair 850HX
    Diamond HD 6970 2GB
    Windows 7 64-bit Ultimate
    Apr 2006
    Ohio State
    You would probably need more vtt/qpi to put the bclk to 210 but you can try it. I ran at 4.0 stable with 1.325 , can't remember the vtt but I believe it was about the same. I could do 4.2 as well (200x21) but that took about 1.385-1.4 and about the same vtt. I never had heat problems (67-70c under load with my venomous-x, but I generally just ran 4c/4t)
    Jun 2009
    New Jersey
    0x09c is qpi/vtt most likely, but increasing vcore helped. In your case since you were lowering vcore while maintaining qpi/vtt most likely vcore. You can try increasing qpi/vtt.
    And unless you like your cpu try to keep runs down to 20-25 runs max. no need for 75 runs you are just gonna kill your cpu.
    Main Rig
    Gigabyte z78x-OC Bios F5n
    i7-4770k batch L310B492 Malay @ 4.5ghz with HT 1.2v
    Samsung Green 8GB 2x4GB MV-3V4G3D/US DDR3 1.3v 30nn
    HiS ATI HD 6950
    Corsair Force GT 120 GB Sata3 SSD (boot drive) on Intel sata3 controller port0
    Samsung 320GB HD322GJ 7200 RPM 16M cache on Intel sata3 controller port1
    Sony Optiarc DVD-RW AD-7240S on Intel sata3 controller port4
    CORSAIR CMPSU-850TX PSU
    Swiftech MCP655-B Pump
    EK Suppreme HF Cpu Block
    Swiftech Mcres Micro Rev 2 Reservoir
    Black Ice GTX Xtreme 360 Radiator
    Server
    HAF 932
    Gigabyte z77x-UD3H F13
    i7-3770S batch 3212B621 supports VT-D and low power
    32GB 4x8gb Muskin Enhanced Blackline 10-10-10-27@1.65v
    Vmware vSphere ESXi 5.0u1
    4x500GB Hitachi Deskstar 7K1000.D Raid 10 on a IBM M1015 <- DataStore
    Sapphire HD 5850
    Xtreme Mentor
    Aug 2008
    Australia
    75 runs with max mem, that is a bit overkill and must take you forever!
    20 runs should be fine, its only one stress test, try using prime as well. As said above, 09C is usually Vtt but vcore can help, hard to say exactly what is causing it without experimentation.
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
    May 2005
    The reason why i ran 75 runs with max memory was based on a X58 OC guide I found on the EVGA Forum:
    "Once you have your vcore in a good spot, run 50 - 75 Tests with ALL memory to be sure your Vcore and VTT voltage's are stable. You can quit here and risk having a crash someday, or run prime95 blend for at least 12 hours. "
    http://www.evga.com/forums/tm.aspx?&m=81651&mpage=1
    How long would you guys suggest running Prime 95 and MemTest (I remember there was a particular test that was very stressful)?
    Corsair 850HX
    Diamond HD 6970 2GB
    May 2005
    So today, I started to test now with Prime 95. When I turned HT on with either 4 threads, or 8 threads, I BSOD right away. Here were some errors I got:
    0x0000003B
    0x000000101 (usually means not enough vcore, vtt, pll)
    0x0000001E
    My temperatures were also much higher as well. With HT off, my temps were usually mid to high 60's. With HT on, temps were mid to high 70's during testing.
    Currently, I'm running 4.0 Ghz, with HT off, using 1.29375V for Vcore, and 1.3V for VTT, stable in LinX for 75 runs.
    How much more Vcore and VTT is needed if I wanted to use HT? Does Hyperthreading really provide significant performance boost? It seems like it needs alot of voltage.
    Corsair 850HX
    Diamond HD 6970 2GB
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by turok_t View Post
    0x0000003B
    0x0000001E
    it dont take much more around .02-.06 on v-core
    dont need more vtt
    but the temps get 5-20c hotter with ht
    hotter the chip the more juice you need
    75 runs lol
    i test 20min linx 20min prime n gaming
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
    May 2005
    In regards to running stress tests for a long time, here is the question I posted on other boards:
    "If I run these tests for such a long time, will it damage my CPU? I dont want to over stress the poor lil chip"
    Here is the response I got:
    "No, it is heating and cooling cycles that cause electronics damage - as long as you stick to the official limits. The hotter it gets, the more extreme the cooling cycle and therefore the lesser the life - but not by a big difference with std OC temps. So the length of time you run the test makes no difference. It's not like an engine, where it has mechanical wear over run time. "
    Corsair 850HX
    Diamond HD 6970 2GB
    Xtreme Mentor
    Dec 2007
    Everyone will have different opinions on how long to test for stability and what test is the best to use.
    There are fanatics that will run linx 500 times, and others that wont run it at all. As long as your PC does the things you use it for without issue, thats all that matters in the end.
    There are other ways to test that are more fun than watching loops of LinX or blend. You could try SuperPI 32m, then HyperPI 32m, WPrime 1024m and set number of threads to 4 or 8 depending on weather or not you are using HT, run the different 3D benches, play the games you like to play. If it passes those and does everything else you want it to with no problems, who cares if someone else doesnt like it because you didnt use the exact method they use.
    May 2005
    Quote Originally Posted by OC Nub View Post
    Thanks for the reassurance, I kinda knew that real world environments matter the most, I just wanted to verify with u experts 
    Thanks for the reassurance  kinda knew that real world environments mean the most just wanted to confirm with you experts 
    Corsair 850HX
    Diamond HD 6970 2GB
