Hello guys
This is my review that 2 months to complete, hope that you like it :
The rest of the review is here :
http://www.egypthardware.net/vb/t589.html
It is in Arabic but you can use google translate
Hello guys
Core i7 920 @4.25 with Noctua NH-D14
Asus Rampage III Extreme
6GB Triple Channel OCZ Blade DDR3 2025 9-9-9-24-1T
HD6990+HD6970@950Mhz/6Ghz GDDR5 Tri-Fire
3 BenQ 2420HD 1080p 24" Widescreen LCD in Eyefinity
OCZ Vertex 3 Max IOPS 120GB SSD + Many HDDs !
X-Fi Titanium-Cambridge SoundWorks DTT 3500 Digital
Seasonic X-850
2xBenq 1640 - LiteOn iHAS120-Pioneer 111L - Samsung 203B - NEC Optiarc AD-7200S DVD+/-RW burners
NZXT Phantom Red Edition
You're CPU imited with 4 cards.
Sandy Bridge is needed to give it that little extra boost as the i7 920 doesn't quite have enough power to handle the driver overhead of 4 cards.
Seasonic X-850
It seems that Crysis 2 benchmark was flawed , retested and updated charts
Please tell me if there is any other "fishy" result
Seasonic X-850
good review
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
Could you do Crysis 1 benchmark?
Using the bencmark tool can you do a run of Assault Harbor?
Eeh, I don't think you can really make a blanket statement like that. [H] found that a SB was needed over their nehalem i7, but their nehalem chip was clocked a paltry 3.6ghz or something. This rig (I'm assuming looking at the sig) is a 4.25Ghz I7 with DDR3 at 2025.
--Matt
My Rig :
Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
I have a screen grab of a 5+Ghz 2600K holding back Tri-SLI GTX 570's...
So yea, I can says He's CPU limited
I'll bite. Please show us a screenshot depicting a 5Ghz 2600k as a bottleneck for a tri-sli GTX570 setup. Also, since it wouldn't be relevant otherwise, show me proof that a 4.2Ghz Nehalem chip with 1012mhz ram is a bottleneck for a 6970 quadfire setup. I can see 3 games where scaling stops past 3 cards in the charts above, but I'm interested in seeing how a single screen grab can confirm a cpu bottleneck as the cause.
--Matt
My Rig :
