http://www.newegg.com/Product/Produc...&Tpk=HD%205830
Newegg jacked up the price a bit unfortunately. $129/pop isn't too shabby for 300MH/s at 200w or so TDP. Problem is these no longer pay themselves off in a week or two.
ungh.... bought a 6870 yesterday.....
Try my multi-threaded prime benchmark!
If you like it and want to see more - bitcoin me!!
1MrPonziaM4QT2S7SdPEKQH88BGa4LRHJU
1HaxXoRZhMLxMJwJ52VfAqanSuLuh8CCki
1ZomGoxrBqyVdBvHwPLEERsGGQAtc3jHp
1L33thAxKo1GqRWRYP5ZCK4EjTMUTHFsc8
dang you guys are still putting money into this? I'm not sure how much longer mining is going to be profitable..
Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
Cruncher #3: 8-core Xserve 1,1
T400 for non-crunching
"But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
I hear you on that shoota; I ts been around a month I believe and I haven't even made enough to pay for my 2 5830's/. The price drop isn't helping either. This also does not include the additional cost of electricity. Tonight I was honestly thinking about maybe selling my 2 5830's to one of the guys that want to continue. Will have to give it some thought. I need to try and figure out how much they cost me to run ea mo
Main Rig
Gigabyte z78x-OC Bios F5n
i7-4770k batch L310B492 Malay @ 4.5ghz with HT 1.2v
Samsung Green 8GB 2x4GB MV-3V4G3D/US DDR3 1.3v 30nn
HiS ATI HD 6950
Corsair Force GT 120 GB Sata3 SSD (boot drive) on Intel sata3 controller port0
Samsung 320GB HD322GJ 7200 RPM 16M cache on Intel sata3 controller port1
Sony Optiarc DVD-RW AD-7240S on Intel sata3 controller port4
CORSAIR CMPSU-850TX PSU
Swiftech MCP655-B Pump
EK Suppreme HF Cpu Block
Swiftech Mcres Micro Rev 2 Reservoir
Black Ice GTX Xtreme 360 Radiator
Server
HAF 932
Gigabyte z77x-UD3H F13
i7-3770S batch 3212B621 supports VT-D and low power
32GB 4x8gb Muskin Enhanced Blackline 10-10-10-27@1.65v
Vmware vSphere ESXi 5.0u1
4x500GB Hitachi Deskstar 7K1000.D Raid 10 on a IBM M1015 <- DataStore
Sapphire HD 5850
Does anyone have a BIOS that will work on this (actually, the other one that was $109). I have this and another 5830 maxed at 875Mhz and 900Mhz, and would love to get them up to 1Ghz and get closer to 300MHash than 270MHash
Work/Game System - ~24/7 WCG
ASUS P8P67 PRO / i7 2600k @ 4.1Ghz / Gigabyte Radeon HD5870 / 4x4GB Corsair Vengeance @ 1600Mhz 9-9-9
HTPC -~24/7 WCG
Gigabyte GA-Z68AP-D3 / i7 2600k @ 4.0Ghz / Sapphire Radeon HD5830 / 2x2GB Mushkin Enhanced Essentials @ 1333Mhz 9-9-9
XS WCG Team Forum - http://www.worldcommunitygrid.org/
Snagged 1 more to fill up my last PCIe slot. makes 6 58xx cards
based on my BTC calculator http://www.kaptain.me/btc_calc.php
it will take about 47 days to pay off a 5830 + electricity cost
312 Xeon Threads + GTX 1080 + GTX 1070 + BFL Monarch 700
As for now next difficulty change doesn't look too bad. Low price = people running away from bitcoin.
bit the bullet and got one.
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
People still buy these things? Damn, I have one just kicking about in my closet doing nothing.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
I'll look for it; its posted a few times in the original thread
Try This
I have come across a 5870 ...200$ wondering if I should pick it up and get on the train by some luck I have come across a board cpu to run it on also just need a psu. If I get on it I will look to add another 5870 and am prepared to be a little patient (famous last words im sure :P).
Your thoughts guys .... I am getting into it hoping to make money and am pretty sure if I even make half the value of the 5870 I can easily sell it to cover up the difference.
Hey I found a 6990 on CL, good price or no?
http://tampa.craigslist.org/hil/sys/2488024589.html
Price looks good to me if the card is aok. Had many Nv cards go up in smoke but 6990s seem to be built like tanks.
Have a quality PSU to go with it and you're easily in for 800Mh/s+.
if you can see the card running before you buy it....
I bout one on CL but didn't have a good experience
seller showed it to me running... and i thought that was all good.
took it home and ran it and the VReg overheated in 1 or 2 minutes.
I can't mine with it... payed $600 for it and it is worthless to me now...
so make sure you see it running... and that u have GPUZ up and showing all the temps...
right now trying to get mine fixed through HIS but they don't reply often to their tickets.
note: just because i bought a lemon doesn't mean you will
You're right, being safe is better than being sorry.
Let the guy show you the card running Furmark for at least 10 minutes with OC BIOS. 100deg+ is no issue, it just needs to be stable at these settings.
Received my 8530 today got it installed. Had issues trying to get Afterburner to see both cards and allow me to adjust the 5830 along side my 5850.
I was able to overclock the card to 1010 on the core It might even go higher. With my 5850 clocked at 810 pulls about 320 MHash. The 5830 clocked to 1010 pulls 310 MHash.
The thing I notice is that each gpu is not pegged at 99% usage. They will drop down to about 90% so MHash rate will change also. Is this normal or is this a sign that I am pushing my PSU?
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
It might be you need to give them a core to run on. First, see what happens with nothing else running. What you describe is what I saw when running WCG on all cores at the same time.
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
Right now each gpu has its own worker. Each worker has it own core associated with it and only those 2 cores are running. This is done with 1 instance of GUIMiner.
So this maybe just the way it is.
Also want to confirm these saphire extreme 5830 do not have voltage control correct?
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
Found a newer version of Trixx supports switching between multi gpus version 4.0.2
This also allows me to adjust voltage on the 5830.
http://www.sapphireselectclub.com/ssc/TriXX/TriXX.aspx
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
Just installed it and it worked. In the Trixx under the logo in the top left do you have the drop down box to select either video card? Or Can you see the video cards but wont allow you to overclock them?
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
