Results 1 to 5 of 5
Thread: H60 vs Silver Arrow
    Feb 2009
    H60 vs Silver Arrow
    If the H60's rad is thicker, it will perform much better since the rad gets pretty hot during full load even with the monstrous delta fan.
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    So the Silver Arrow performs better than the H60 unless you make the H60 sound like a vacuum cleaner. Interesting I guess. But going with a noisy fan kind of defeats the purpose of going with water cooling in my opinion.
    To that extent you can beat all of those results with a Thermalright Archon in stock configuration, except for possibly the H60 with Delta fan and shrouds.
    I am Xtreme
    Dec 2007
    he used it as an exhaust, make it intake and you might see a few C drop
    i spy a few fans up top to pull all that hot air right out anyway
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
    Aug 2004
    Los Angeles, Ca USA
    Maybe not. You would be sucking up warm air from the power supply if you have it as intake.
    Feb 2009
    Quote Originally Posted by MaxxxRacer View Post
    Yup, warm air from both the PSU and the GTX 470 "hair dryer"
