hmm windforce result looks like SLi run?
That can't be single card :O. or is 275.33 crazy driver?
Sof lod can only ad 1-5 fps at most, not really huge effect with 580
this my sli run
this my sli run
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
The performance is the same if you disable the iGPU on M4E-Z
Born to lose, live to win!
Is there any bios for P8Z68-V Pro ? or only for ROG boards ?
GAMING: Intel Skylake Core i7 6700K 4.6GHz || Corsair Hydro Series H110i GT Extreme Performance || GIGABYTE Z170X Gaming G1 || Corsair Dominator Platinum 32GB DDR4 3000MHz CL15 Quad Channel Kit || GIGABYTE GeForce GTX 980 Ti G1 GAMING 6GB DDR5 384-bit || AVR Onkyo TX-NR809 || Monitor Audio Bronze BX2 + BXCentre + BXFX + BXW10 + Logitech G430 || SSD Intel 750 Series 400GB PCI Express Gen3 | SSD Samsung SM951 Series 128GB M.2 PCIe 2280 | 2x WD 3TB Green + 64GB SSD Cache || Razer DeathAdder Chroma + SteelSeries QcK Heavy || Logitech G910 Orion Spark || Cooler Master Cosmos II || Corsair AX1500i 1500W || BenQ 1ms Professional Gaming XL2730Z 27" || Philips 4K UltraHD 55PUS6501/12 55" || Windows 10 PRO 64-bit
If someone stands in the way of true justice, you simply walkup behind them, and stab them in the heart.
[QUOTE=Vivi;4906056]hmm windforce result looks like SLi run?
this my sli run
Is it sure to which you speak????
It is a single card.
If exchange option in nvidia inspector, point is improved much.
2010 MSI MOA Grand Final #4
2011 MSI MOA APAC #2
2012 MSI MOA APAC #4
2012 MSI MOA Grand Final #1 Champion
What option in Inspector? That does look like SLI run indeed...
For those interested of performance difference between M4E and M4E-Z here you have 2D comparison and 3D comparison. Enjoy!
I tested oc_windforce's tweak and it works very good. No image alteration at all...
it also look like nature cap increases with this tweak.
So if it works with 275 or 285 we will see some nice dual card runs
20FPS boost at stock speeds on 580 with DH. dont know if its the "tweak" you guys are talking about, but I bet it is.
I dont want to step on any toes... so I will keep quiet "other" than saying that I can confirm it does not affect image quality
P.S._ : i dont want to give away the tweak but if you can let me know if im on the right track
stock 580, 2600K @ 4.6 - DH gives 640FPS w/o tweak. with tweak 660. didnt test further and I did it in windows 7 x64 if you are wondering why the fps is a tad low.
*edit*
very sneaky oc_windforce. good testing skills for sure. so as it turns out i was wrong and may have stumbled onto something else. will test in xp now and verify.
Current Status - Testing & Research
I found a way to boost nature fps about 60fps (With one litle change...)
I didnt try other than nature, tough it makes most difference on score anyway.
Is that the tweak when u using default GTX580 card and 4.2GHz gulftow? dont wanna say that i found exactly same tweak when im not sure of it yet
And yes, im using win7 too since this is with mine 24/7 OS.
Edit: Compared SoF's and winforce's scores and it looks like difference in nature is about 60fps too ^^
X58: R3E & XPOWER | 980X | GTX580 | 3x2gb MGH-e | Dimastech | AX1200
s775: RE | E8600 | GTX285 | 4x1gb D9GTR | P&C 610W
SB: 2600k | Asus P8P67 & Gigabyte UD4 | GTX 460 1gb | 550W Cougar
people...
anyone can explain how a newer bios can boost like this the performance????
