Ive been asked and hounded and asked about making some for a long time... so ......
Finally im going to release a limited run of pre-mixed liquid in so called blood red. (due to the time its taken me to come up with the mix and the amount of dye needed to create it)
Now this is as close as i can get it to blood red how ever its still not perfect (have you ever seen blood you can see though lol)
This is a mixture of my pre-mixed liquids, Blue, red and UV pink to create it.
Any way ill let the picture do the rest of the talking.
I may make it into a limited run dye as well but that wont be for a few weeks.
The syringe in the picture is only a few cm's across as to show it in a real thin tube. It much darker in normal 3/8 th Tubing.
Any comment please let me know ...
As per the norm i only sell the pre-mixed liquids to re-sellers so you'll need to keep any eye on if they stock it or not. I don't ship pre-mixed liquids out of Europe my self but im sure if you do like it and want it one of my re-sellers will sell some to you.
*** WARNING ***
This WILL stain you system i have no doubts in my mind.
So any way if you would like to create this your self its quite simple this is the Mixture Ratio for 1 Ltr of liquid.
(hold onto you hats it uses lots of dye to create)
60 drops of Mayhems Dye Red
5 Drops of Mayhems Dye Deep Blue (new strong version)
10 drops of Mayhems Dye UV Pink
Per 1 Ltr of liquid........ (see why i say it WILL stain now)
The test time of this was 9 months in a system and it did stain all tubing, it did stain the edges of the res, it did stain the water block slightly. It did not block, gunk up or create any mystical supprises in the heat killer it was tested on.
Mick
