Well.... with the CPU used for Llano, this was expected ( cpu perf ) ... now looking on gpu side ( HC give something like 80% more perf of the Intel IGP for games ) ... This can only look good for the next APU Trinity with a better CPU.
CPU: - I7 4930K (EK Supremacy )
GPU: - 2x AMD HD7970 flashed GHZ bios ( EK Acetal Nickel Waterblock H2o)
Motherboard: Asus x79 Deluxe
RAM: G-skill Ares C9 2133mhz 16GB
Main Storage: Samsung 840EVO 500GB / 2x Crucial RealSSD C300 Raid0
Well ive read canucks, and glanced for few others.
Seems like a dream chip for the overclocker on a tight budget.
If you are willing to learn how to oc these.You can have +30% or even more gaming performance.
Cpu wise its "enough" for all the mundane stuff people do ,and gaming wise, its usable too.
Im actually building most computers for customers with some sort of IGP and a cheap athlons nowadays.Thats going to be a great step forward.
I agree totally.
Said many times already, in poorer countries it will be very popular chip. In wealthy countries it will be popular thanks to OEM systems shipping with Llano.
Regarding articles I must agree Hardware Canucks review stands out as best in many regards. Though it is worth reading few more as well to gain better picture of performance and OC headrom. On OC front the spread is quite high, ranging from 3.5GHz to 4GHz. Either overclocking this platform needs some more attention than recent approach of set multi / voltage and you're done, or there is quite a freq. headroom spread between samples.
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
I wonder if you can undervolt it even lower than 0.444V at idle.
________________
Main:
Phenom II x6 1090T BE|Crosshair IV Formula|Corsair 4x2GB DDR3|Sapphire HD5870|Adaptec 2405 + Hitachi Ultrastar 15k 450GB SAS, Toshiba MBD2147RC 146GB 10k SAS, Samsung F3 1TB, Seagate Barracuda Green 2TB 5900RPM, WD Black 2TB, Seagate Barracuda ST2000M001 2TB|Asus Xonar Essence ST + HD600|Corsair HX850|HPZR24w|Fractal Define XL Black|Windows 7 X64 Pro
Backup/Storage server:
HP Proliant ML350 G4|2 x Xeon "Nocona" 3GHz|4GB DDR1 ECC|Storage (SCSI): 3x10k 72GB + 10k 300GB + 15k 300GB + Ultrium460 tape drive|Storage (SATA): Adaptec 2810SA + 2 x WD Caviar 250GB RAID0 + Seagate 250GB|Windows Server 2008r2 Datacenter
Other:
HP Proliant DL380 G5|Xeon 5150|4GB FB DDR2 ECC|HP Smart Array P400-256MB cache|3x10k 146GB SAS in RAID 0 + 10k 146GB SAS|2x800W|ATi FireGL V7700|Samsung 226BW|Windows Server 2008r2 Enterprise
HP DL320 G5|Xeon 3150 2.13GHz|1GB DDR2 ECC|2x80GB RAID 0|Windows Server 2008r2 Standard
Laptop:
HP 8560w|i5-2540M|2x4GB DDR3|AMD FirePro M5950|Samsung 840 Pro 256GB|Windows 7 X64 Pro
What is worth considering is how will game developers view this chip. Obviously this is only the first generation and thus, there won't be enough of them to go round. Once we hit 'trinity' next year (I believe that is the BD version), then there will be a substantial base of low spec PCs/Laptops that are capable of running the latest games. This could be a problem for Intel, as it doesn't seem to have anything to throw at AMD over these chips.
It will be interesting to see how these chips slot into the games market.
Well, we don't know yet how will compare Bulldozer to Intel CPU's .... Trinity will effectively be build around Bulldozer, during AFDS, AMD have explain Trinity gpu will be VLIW4, rumors state a Juniper version in VLIW4. Let's imagine Bulldozer is competitive with Sandybridge line up and add a gpu who can perform close to a HD5770: as you said, this can be really a problem for Intel in this part of the market.
what is the point of making a onboard gpu in those performance range? you cant game properly and it is way beyond enough for htpc purposes.....
we going shh around the corner
Ok, thank you for the reply.
But since you mentioned the voltage being gated to more sections (than on normal CPU's) does overclocking (thus using higher voltage) have an impact as well (could it be more prone to damage than normal CPU's because of the other components?). I'm just guessing here so correct me if I'm wrong.
________________
Main:
Other:
Laptop:
Any overclocking test with the GPU turned off? I saw 4.6Ghz at OBR blog. At 32nm HK the K10 arch should work faster than 4.0Ghz, don't you think?
Main: Windows 10 Core i7 5820K @ 4500Mhz, Corsair H100i, 32GB DDR4-2800, eVGA GTX980 Ti, Kingston SSDNow 240GB, Crucial C300 64GB Cache + WD 1.5TB Green, Asus X99-A/USB3.1
ESXi Server 6.5 Xeon E5 2670, 64GB DDR3-1600, 1TB, Intel DX79SR, 4xIntel 1Gbps
ESXi Server 6.0 Xeon E5 2650L v3, 64GB DDR4-2400, 1TB, Asrock X99 Xtreme4, 4xIntel 1Gbps
FreeNAS 9.10 x64 Xeon X3430 , 32GB DDR3-1600, 3x(3x1TB) WD Blue, Intel S3420GPRX, 4xIntel 1Gbps
I can imagine that Intel is advancing it's GPU tech as quick as it can. If direct compute and openCL become more widespread, then trinity based CPUs will be a major breakthrough (IF BD is better in the CPU area). It will cerainly be a platform that the latest games could be played at resolutions and settings that would be enjoyable to most.
The llano is certainly showing what the future holds. It's the bargain basement level at the moment, but will no doubt raise the standards of both intel and AMDs next gen CPU/GPU hybrids.
you can definitely have a good enough gaming experience with this IGP, most of the games will run with good framerate and graphics... obviously this is not good enough for the 1200p AA8x 100fps people, but for 720p and around there it's fine.
I upgraded a PC with an old 7300GT to a HD5570 DDR3 (only slightly better than this IGP), and it was running a slow dual core (core 2 2mb l2 at 2.4ghz), and instantly that PC could run most games well enough, F1 2010 at 1280x1024 and so on...
talking about 5570, I wonder why is not possible to use one in crossfire with the llano IGP, only 6000 series...
but isn't the 6550D based on the redwood arch?
here you can see a 6750 and a 5770 working in CF (both juniper gpu..)
http://www.overclockers.com/sapphire...?utm_source=pr
Here's our 37 page review: AMD A8-3850 @ lab501.ro
Our sample OC only to 3.7GHz @ 1.52v, but the memory clocks were pretty amazing: 2160MHz 7-7-7-21 1T with Hyper sticks and 2650MHz 8-11-8-27 1T with PSC
Born to lose, live to win!
Did you notice any problems with Hybrid CF (except the fact that many games have no gain from CF)? According to some reviews there are serious micro-stuttering problems.
yeah come to think of it, people may be forgetting or downplaying having proper directx 11 support. at least it means someone with a crappy computer could bring home a game and play it. haven't we all done that, played a game at low res and low settings? has anyone benchmarked llano with crysis 2 to see what settings get 25fps? lowest visuals and 1024x768? that is better than a lot of old games I like.
Simple, it didn't, it ran in 10.1. The fallback of DX11 is DX10.x so every DX10 card can run DX11 games, you just can't use any of its related features (mostly tesslation).
Preformance at stock is pretty much there where it was expected (from the mobile reviw), but whats nice is the oc potential.
It's interesting to see an IGP which can finally compete with discrete cards but the 100w TDP is a bit too much for an HTPC system. I believe it's the 65w parts that will make Llano shine.
Any news when they will be out?
