That's very cool. I didn't see any yellow, orange, or white there?
\Project\ Triple Surround Fury
Case: Mountain Mods Ascension (modded)
CPU: i7 920 @ 4GHz + EK Supreme HF (plate #1)
GPU: GTX 670 3-Way SLI + XSPC Razor GTX670 water blocks
Mobo: ASUS Rampage III Extreme + EK FB R3E water block
RAM: 3x 2GB Mushkin Enhanced Ridgeback DDR3 @ 6-8-6-24 1T
SSD: Crucial M4 256GB, 0309 firmware
PSU: 2x Corsair HX1000s on separate circuits
LCD: 3x ASUS VW266H 26" Nvidia Surround @ 6030 x 1200
OS: Windows 7 64-bit Home Premium
Games: BF3, Crysis 3, Dead Space 3, MW2 (Dom only), TR2013
Thanks!
Well they are there for sure, maybe the controller was set a little too fast to see the difference.
I would love to make a window in my fractal case just like yours. I can't get over how nice the flush window looks. I am wondering if the best way to approach it would be to cut to short then file down the side panel until flush? I don' think my side panel is as thick as yours was, would you suggest still doing it?
The Following User Says Thank You to d3v0 For This Useful Post:
You can always try it
I would do it the same as I did. But when it finally fits lay the panel AND acrylic on it's flat side, so the will both be flush.
Then just use strong glue to keep in on its place on the back side.
Great ! Now you need to find some time for gaming. You got the gear!
The Following User Says Thank You to Dk_vr For This Useful Post:
God. this is a well worth thread to read ! AWESOMENESSSS !
- Le Quebecois -
- - - BTTB - - -
EVGA X79 FTW - I7 3820 - PH-TC14PE - 16gb G.Skill 2133mhz - EVGA GTX 670 + Accelero TTII
Tecnofront HWD BenchTable - Antec TPQ-1200-OC - 2x Agility 4 256gb - Surround Asus VE278Q 5760x1080
- - - HTPC - - -
Asus Z77-m Pro - 2500K - NH-C12P - 2x4gb G.Skill Ares 1600mhz
Asus GTX 650 TI - X25-M 80gb - Enermax Naxn 550w - Lian Li PC-C60B
- - - NAS/Server - - -
Gigabyte H77m-D3H - G2020 - 2x4gb G.Skill 1600mhz - 2x 1TB Black - 1x 2TB green - CX430M
Forum Quebecois, si tu parles francais !
The Following User Says Thank You to Boulard83 For This Useful Post:
Jaw dropping! Never seen a copper put in a better use!
Someone didn't take their happy pills today!
Holy cow, the beast (of a card) awakens.
Wonderful!
FC looks perfect, I'm waiting impatiently for the practical test (temps & flow)
Really, reeeaalllyy AMAZING! this worth every second of your time working! I wish to be there helping you, and givin' ideas :P
Keep modding!
Very cool, now make three more for a quad SLI setup.
Too bad 2 of these already is a quad SLI setup :P
And the promised update
It all didn't start as I want to last week.
It started with one m3 hole that didn't align.
Forgot the pci bracket holder.
And the bottom border of the backplate.
So, let's get the dremel.
Appears this is possible to do
And the raw file.
Made the OD of screw hole smaller.
Love these cutters!
No contact with the backplate anymore.
And backplate screw holes align.
Covering it up. (Even if you can't see it)
Already ordered some thermal pads from Highflow.
And the package arrived I've been waiting for
I have to say, all the tiny scratches that were already there are even more visible now in the right light.
However I'm really satisfied!
Want the EKWB plate in the same style
And the next problem ...... POM
When I just got the POM there was a little scratch on it.
I thought lets remove that with some P2500 .....
Well ..forget it.. wish I had asked someone with knowledge before I did that
So eventually had to sand the complete top ... what a mess .
When I just touched it with a nail it already had a scratch on it.
It's like high carpet, when you chuck it in 2 different ways.
After some google, reading, and asking people I found out there are a few ways to recover it.
Machining it again, flaming it, sanding it in lots of grits
I chose the way to sand it like I lap a cpu. (And never again
Started with P150, after that P240 (30 min)
You can see you can still easily scratch it with your nail
90 minutes with P600, P1000 and P1500
Next day my arms already didn't want to go further .. let's continue :P
P2000 it is.
P3000, starts to look like something.
After sanding 3.5 hours I'm done with it
Borrowed something from the marsII's younger brother.
I'm satisfied!
Not able to scratch it anymore with my nails or any other softer object then POM. (Weird stuff)
This is easier then I thought.
Put in the rubber, cut it on the exact size and glue it together holding it for 10 seconds.
The 'O-ring glue' smells like superglue. (And sticks to your fingers the same fast way)
I'm done with it for this week :P
Next week hopefully testing it on pressure and the mounting!
Hackintosh Lover
I take it you like Asus?....
I do hate the feser 1 watercooling liquid though... it used to stains my see throw tubes...
Yeah I really like Asus products, always have :P
Not going to use Feser in my future projects. This was just to test on leaks since it is the most UV active coolant.
Hackintosh Lover
^^ Agree always preferred their Mobos and GPUs...
- You may not post replies
- You may not edit your posts
Forum Rules
