Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Thread: "Best" liquid cooling computer chassis right now?
    May 2010
    Hello guys,
    As title says.
    What would be the best liquid cooling case?
    I got some suggestions:
    LD-PC V8
    Corsair 800D [modded 800D for bottom rad would be smart]
    Silverstone Tenjim 11
    Mountain Mods Ascension & Extended Ascension
    CaseLabs TH10
    XSPC H1 Cube
    If I forgot some new amazing ones, please add them!
    EVGA X58 3x-SLI Classified [with EK Full cover block]
    Sapphire Radeon 5870 [with EK-FC5870]
    Corsair Dominator 1600Mhz (3x2GB)
    Corsair HX 1000W
    Intel I-7 920 with [EK- HF Supreme]
    2x 250Gb Seagate Barracudas
    XSPC RX360 Raidator
    XSPC Single bay reservoir
    6x Scythe Gentle typhoon 1850s.
    1/2" ID, 3/4" OD Tygon tubing.
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Add TJ07. TJ11 is arguably improved TJ07, but imho not enough for it's doubled price.
    Also i don't know if it's right to compare half-custom purpose designed cases together with generic ones. I'd rather make two sections.
    800D | TJ07 | Some LiLi-s | few more
    and CaseLabs/MM/DangerDen/XSPC/LD.
    Feb 2009
    Genoa, north of Italy
    depends on the radiators you need...
    Sorry for bad English.
    May 2010
    Quote Originally Posted by Tile View Post
    Ypu can add MM cases, especially the Ascension series.
    They are already there...? rofl
    and for FFlegend. "Depends on what radiators you need" You can also ask for what radiators should I buy "Depends on what case fits in your room" rofl
    So many bad answers today :P
    Though thanks Churchy!
    Corsair HX 1000W
    XSPC RX360 Raidator
    Xtreme Mentor
    Sep 2007
    Dallas
    It really depends on what your requirements are. I am using a 700D right now that is more than adequate for my purposes. If you are talking endless possibilities then I think the Case Labs case offers the best overall design.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    I am Xtreme
    Mar 2007
    Kavala , Greece
    If you take the price of the case into seriously consideration then Xigmatek Elysium could be a fantastic choice i think.
    Intel Core i7 930 @ 4.1 GHz (196x21 - 1.28v)
    Corsair H50 (2x Noctua NF-P12 in Push/Pull)
    Asus P6T Deluxe/OC Palm Edition
    Asus 4870x2 (Stock)
    3GB G.Skill DDR3 PC3-12800
    3x Seagate Savvio 15K 36GB in Raid 0 on Perc 5/i
    2x Samsung Spinpoint HD501LJ in Raid 0
    2x Western Digital WD6400AAKS
    Creative SB X-Fi Elite Pro series / Logitech Z-5500 THX
    Razer Lycosa Mirror Edition / Razer Lachesis
    Coolermaster HAF 932
    Enermax Revolution 85+ 1250W PSU
    HP LP2475w
    Apr 2006
    Middle of Nowhere
    If money and size isn't a factor, then the MM Extended Ascension is best.
    __________________
    Budgets, Bling, We Need Not These. We Have Science!
    Dec 2009
    New York City
    From a couple builds on the Case Labs build over OCN, seems like a good choice if you are located in US. I heard the quality of the MM cases are pretty fragile compared to other cases on this list, especially the motherboard tray.
    Intel i5-2500K @4.2GHZ
    Gigabyte Z68-UD4-B3
    Custom Loop
    Case Labs TH10
    GTX 260 Black Edition
    G. Skill DDR3-1600
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Quote Originally Posted by prtuc2 View Post
    I can back up your statement since I have both, NO COMPARISON! CL is in a class by itself.
    Feb 2009
    Carson City, NV
    I've been a fan of the small form factor cases with an outboard MORA (or any large radiator) attatched. like with all the cases, it depends on what your hardware-fit requirements are.
    i7 2600k, 8GB 1866Mhz DDR3, GTX560 Ti, Gigabyte Z68XP-UD4, CM Cosmos 1000 Case, and some green crap everywhere.
    Quote Originally Posted by Alexandr0s View Post
    So you're saying I could use my own pee as coolant?
    Aug 2007
    Arlington VA
    add TJ 09. Can put 2x120mm at the top, and two 1x20 at the intake and back fan.
    AMD Phenom II BE, ASUS Crosshair II formula, 8gb ddr2 800, 470 SLI, PC P&C 750, arcera RAID, 4x OCZ Vertex2, 2x samsung 7200 1tb, HT Omega Clario +
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    I haven't filled mine up yet, but the XSPC H2 is another option for major rad space in a more conventional single wide tower shaped case.
    It'll hold a 480 up top:
    And at least a 320 or 420 in bottom.
    I could see putting a 480 in bottom with just a few holes drilled and possibly a 560 in bottom with a bit more work.
    Jun 2005
    Madison, WI
    Mountain Mods.
    \Project\ Triple Surround Fury
    Case:
    Mountain Mods Ascension (modded)
    CPU: i7 920 @ 4GHz + EK Supreme HF (plate #1)
    GPU: GTX 670 3-Way SLI + XSPC Razor GTX670 water blocks
    Mobo: ASUS Rampage III Extreme + EK FB R3E water block
    RAM: 3x 2GB Mushkin Enhanced Ridgeback DDR3 @ 6-8-6-24 1T
    SSD: Crucial M4 256GB, 0309 firmware
    PSU: 2x Corsair HX1000s on separate circuits
    LCD: 3x ASUS VW266H 26" Nvidia Surround @ 6030 x 1200
    OS: Windows 7 64-bit Home Premium
    Games: AoE II: HD, BF4, MKKE, MW2 via FourDeltaOne (Domination all day!)
    Xtreme Mentor
    Sep 2007
    Dallas
    I have two MM cases and to me the CL case beats them out easily. That being said, if you want a single wide type case, there are a lot of choices, 800/700D, TJ07, MM Pinnacle, XSPC are just a few.
    Desk Build
    W/C System
    Feb 2009
    Quote Originally Posted by LLiH View Post
    what can we say whitout any information about your (future?) system? if you say "tell me the best case for liquid cooling" people just tell you what they like or something that maybe you don't need...
    with the lc in your signature for example you don't need a big case... the BEST case for liquid coling with multiple loops isn't a TJ or a Corsair, that's sure...
    May 2010
    Quote Originally Posted by FFlegend View Post
    If you can't answer. Then don't answer. You are wasting your time.
    I'm not here to talk about debating. Please.
    Corsair HX 1000W
    XSPC RX360 Raidator
    Apr 2005
    To me, it's whatever case you want, a pack of Dremel cutting wheels, and a good friend to help you knock out stuff and have a good time.
    I don't like the idea of a "pre-ready" case. I'm using a Fractal Design Define XL (though I'm not doing what Malik and Phaseshift are doing AT ALL) and I think that with the sound dampening and all it's pretty perfect.
    Ask 10 people, get 12 opinions. But there's mine.
  18. #18
    Sep 2008
    No TJ07? Lolwut?
  19. #19
    Feb 2009
    Montreal
    Quote Originally Posted by RollerBall View Post
    No TJ07? Lolwut?
    Because new cases came out since 2006?
    I've recently been impressed by Case Labs and LD Cooling cases (if I go phase, it's probably with LDC). I personally own a MM and while it is large and spacious, the assembly / finished product is not the best in the world.
  20. #20
    May 2008
    Ontario, Canada
    Silverstone TJ07. None of the Corsair cases that I have seen (or really many others) allow what the TJ07 allows. That is, a 480 radiator at the bottom that intakes and exhausts air without ever getting anywhere near the main components. That means, cool fresh air from the outside goes in through the radiator and the hot air goes out at the bottom, never flowing over your components.
    Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
    Video: 2x Sapphire 6950 Toxic 2gb @ 6970 Switch @ 880 / 1350 | Asus VG248QE |
    Audio: ODAC+O2 => JH|13 Pro | STX => ATH-AD700X / Audioengine A5
  21. #21
    Mar 2006
    Sunny Lizardland
    Love my Cooler Master ATCS 840, and am in the process of building up another for my brother, but they aren't "ideal" H2o cases in the mold of MM or CL, they're just amazingly fine- looking, reasonably priced "regular" cases. Where the ATCS really shines is in the quiet department. For a case that's not intended as a "silent" case at stock, they're amazingly easy to get near-silent with very, very little work.
    Components
    Case: Cooler Master ATCS840/ PSU: Seasonic X750/
    Mobo: Gigabyte GA-z68xp-ud4/ CPU: i5 2500k 4.2-4.8 GHz @ auto/
    VGA: EVGA GTX570 SC 940, 1880, 4500 @ 1.1v (Lucid dGPU)/ Memory: 8 Gb G.Skill DDR3 1866
    Storage: Corsair Force 3 120Gb SSD, Samsung 470 128Gb SSD, WD Scorpio Black 750 (Scythe Quiet Drive)
    OSs: Win7 HP x86_64/ Kubuntu 11.04 x86_64
    Cooling
    CPU: Koolance CPU-370/ GPU: Koolance VID-NX580/ Rads: XSPC RX360, Swiftech MCR-220QP/ Pump: EK-DCP 2.2 (softmount)
    Fans: 3x Noiseblocker m12-S1 @~500-750rpm, 3x Scythe GT 800 @~450-800RPM, Cooler Master 230mm (softmount) @300 RPM
    Tubing: 3/8" x 5/8" Primochill LRT (black)
    Fittings: Koolance compressions and 45/90 degree fittings
    Certified Quiet PC Loony
  22. #22
    Apr 2005
    I swear I'll throw something if someone else mentions TJ07. My best friend bought one and it was the worst assembled case I've ever seen. All the money they pay for the Murderboxes must be to straighten out Silverstone's crappy work beforehand I swear, not a hole lined up like it ought to have.
    I miss the days of the WaveMaster. Or the PC-60. So many of these "liquid cooling" cases just look like junk. (this is a statement of opinion.)
  23. #23
    Mar 2006
    Sunny Lizardland
    Quote Originally Posted by Kayin View Post
    ...I miss the days of the WaveMaster. Or the PC-60. So many of these "liquid cooling" cases just look like junk. (this is a statement of opinion.)
    ...Which is one reason I love the ATCS so much. It's understated and gorgeous in a very old-skool way. Like a 2009 door-less wide-body version of the WaveMaster.
    Components
    Cooling
  24. #24
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Just buy one of these....
  25. #25
    Oct 2010
    Sydney Australia
    I would like to add I have a mountain mods extended ascension and couldn't be happier with it. The fact it so modular and flexible with changes to any panel possible making future upgrades a simple matter. Also having custom panels made for you is pretty cool too.
    I started out modding a single thermaltake case which turned into a monster with a 2nd custom dedicated external water cooling case. It was a bit messy and not very attractive.
    I think the new CL cases have taken most of the benefits of MM cases and refined it so they are less industrial mechano set looking and more high performance enthusiast cases. The layout of CL is not as flexible IMHO but they do look better than MM. I think my case is big, but I think the sizing dimensions of some of the CL cases makes them look bigger, but without necessarily more space. I like having a wider case and am now considering some future upgrades that wouldn't be possible in the CL.
    How does 7 GTX 360 rads with a quad D5 single loop sound? And that's without modding the case in anyway, no cutting, drilling, nothing. Can a CL do that? Not that im knocking them, I actually quite like their attention to detail.
    I am Intel of Borg. Resistance is futile. You will be assimilated. Borg Homeworld - Blog
    i7 3930k @ 5Ghz AC Kryos Silver - Asus Rampage IV Extreme - 4 way SLI 3GB GTX 580-UD @ 1000/2200 - 16GB Corsair GT DDR3-2000 RAM - 4 x GTX 360 rads w/ 24 x CM push-pull fans & shrouds - Aquaero 5 XT controller, 6 PA2 Ultras - 2 Flow meters - 2 x Enermax 1500W PSU - MM Extended Ascension Horizon XL-ATX Case - 2 x Koolance 452x2 Res and 4 x D5 pumps - 3 x 24" Acer H243H Surround LCD
