Results 1 to 11 of 11
Thread: hd4850gs bios over 1000MHz!
    Aug 2003
    italy
    please can you unlock the bios of my 4850
    I can not go over 800mhz with the asus bios!
    please help
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    You need a different signature file if you are talking about not being able to go over 800MHz with CCC. Just download a bunch of HD4850 vBIOSes and open them with RBE and extract the signature file from the vBIOS with the highest limits.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Aug 2003
    italy
    thanks for the answer
    there is a bios that has a limit beyond 800 in CCC?
    I tried to open all the bios msi asus gigabyte and asus, but was the highest with up to 800!
    my vga air arrives safely at 800
    i need or modified bios or if you know wich bios is unlocked past 1000mhz!!
    Apr 2004
    United Kingdom
    "Prowler"
    Cooling:
    Jun 2007
    Srbija Vojvodina Pancevo
    use riva tuner and you will not need a mod bios
    No volts, no nothing
    [SIGPIC][/SIGPIC]
    Xtreme 3D Team
    Jan 2009
    Ohio
    Hmm, 800 is about the limit for 4850s anyway, voltmodded. I'd be more than suprised to see a 4850 do more than 800 without special cooling and upwards of 1.5v. ...so I guess I am XD
    I have an ASUS TOP bios I can upload for you, I cant exactly remember how high it goes core wise in CCC but I remember benching my card in the 840 range.
    ...I also made a modded 4850 bios with a 4870 hash, it will start stock at 4870 speeds and is recognised by 3DMark/Windows, driver etc as a 4870, and goes all the way to XXXX speed in CCC (its been at least a year and a half now, I cant remember
    Smile
    Banned Movieman...
    May 2009
    illinois
    i had my 4850 at 875 on the stock cooler for benching only.
    the reference cooler was actually pretty good, but the fan... jet engine...
    Aug 2003
    italy
    guys are wonderful!
    rivatuner works!
    but now I need Vmod!
    around I can not find anything for my pcb red hd4850gs gaiward
    Is this possible??
    Apr 2004
    United Kingdom
    Theres probably some voltage changes you can make with RBE. Doing things via a vBIOS mod realy would be easier than trying to use nasty Windoze software.
    "Prowler"
    Cooling:
    Aug 2003
    italy
    only 1,158v with rbe!!
    there is same vmod with vr??
    thanks
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by Ket View Post
    Congrats, an uneducated post.
    If you want to mod the bios to do 1.15v, be my guest. Thats all that poor voltage reg will do.
    Smile
