I would argue that there enough people who haven't experienced degradation, despite running high frequencies AND voltage, that it surpasses the margin of error of the sample size of those who have experienced degradation...
But for what it is worth, frequency and voltage often share a positive causal relationship. As frequency goes up, it becomes necessary to increase voltage etc. Since the two are inextricably tied in one direction (frequency leads to voltage), you're only able to actually test the effects of voltage as a single variable (and this is assuming you keep temperatures the same between both tests - unlikely), but with frequency you are not able to, unless you count increasing the frequency to the max the a single voltage point will allow for, but then that may not be high enough to cause degradation. With that said, it may be impossible to know if frequency causes it.
But I would hazard that at stock voltage @ 4GHz, your proc will likely outlast your need for it.
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
- You may not post replies
- You may not edit your posts
Forum Rules
