Hello all
I am a little confused when it comes to voltages on my board in the BIOS, I set LLC to standard, vcore 1.275 and the recommend dram voltage of 1.6, save and exit, I come back into the bios and check the status tab. It states vcore is 1.248 instead of the 1.275 I specified ... It states the same for DRAM, 1.580 instead of the 1.6 I manually selected, what reading do I go with? Also LLC standard intel specs or 1 for slight vdroop?
Any help appreciated
