Thanks for those tips.
Perhaps I should just play a bit more with my 1055t. I was just fiddling to see what my highest overclock can be but voltages <1.5V won't pass 3dmark when running 4.2GHz.
As for the HT thing, I read somewhere that it is better to have you HT the same as you NB.
I'm running my Corsair H50 in a push pull config, but in summer here it gets to around 37 degrees Celsius.
So at the moment, when the cpu voltage is set to 1.35 and jumps to 1.39 or so under load and my temps in summer are around 56 degrees.
Maybe I should be slightly braver with voltage for benchmarking purposes :-/
